Old Apr 08, 2005, 06:44 PM
hul is offline
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
separate BEC for retract servo?
I'm using 3s LiPo but don't want to run the retract servo on the SBEC.
Thinking of making a simple BEC out of a 7805 voltage regulator for just the retract servo.
This should not get hot for the occasional use the retracts see, may have to use a small heatsink. If the servo stalls the regulator should protect itself (overcurrent or overtemperature) and not cause a problem for the rest of the system.
What do you think?
Thanks, Hans
hul is offline Find More Posts by hul
Old Apr 08, 2005, 07:51 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
What do you think?
Thanks, Hans
Sounds good to me.
It should save the BEC from excessive loads.
Don't forget to filter the 7805's output with a cap. (.1uf is big enough to stop internally generated oscillations). The 7805 can draw allot of idle current if it oscillates.
Gary
Gary Warner is offline Find More Posts by Gary Warner
Old Apr 09, 2005, 02:29 AM
hul is offline
hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
Thanks, Gary, didn't know about the oscillations.
Hans
Question extra battery needed for retract servo? fullscalepilot87 Fuel Plane Talk 8 Mar 23, 2007 08:44 AM
Discussion Esc and separate battery for rcvr/servo Jack Hyde Electric Sailplanes 13 Feb 03, 2006 08:07 PM
Looking for retract servo coloradoz Aircraft - General - Radio Equipment (FS/W) 0 Feb 20, 2005 12:27 PM
Retract servo for the GWS Zero or P51 doc-e Parkflyers 7 Mar 28, 2004 06:49 PM
Separate battery for a retract servo? How? tim hooper Electric Plane Talk 17 May 05, 2003 06:15 PM
