This thread is privately moderated by DEATHspiral, who may elect to delete unwanted replies.
Old Apr 01, 2002, 09:19 PM
DEATHspiral is offline
Find More Posts by DEATHspiral
Trader Rating: 0
San Diego, CA, USA
Joined May 2001
Trader Rating: 0
GLOW/GAS .25 wing (80mph)
If you've flown zagi's for combat, and you want more power, speed, climb, and durability, here is a wing capable...but the only draw back is it being glow. With a .25 motor, it's capable of flying in excess of 80mph. The wing is made of EPP. The motor is mounted with nylon bolts which will break, and eject the motor should you have a run in with the ground, a fence, a parked car, or anything in its way. This plane is as durable as a ZAGI 3C and will allow you to do low aerobatics without the penalty of destroying your plane like other balsa planes.
I bought a few extra kits, but never needed to build anymore. This is the end all for anyone wanting to learn how to fly low and perform tricks.
The TufFlight Predator design was inspired by the great flying wings flown in open R/C combat over the past decade. With minimal parts count and many pre-shaped mating surfaces, this kit is ready for covering after one evening.
Very lightly loaded, the Predator will turn or loop in less than 30 feet at full throttle. Low drag design allows fast speeds, and good glide for landing with power off. Compact size and no field assembly means you'll go from the car to the air in minutes.
Items included in kit:
durable foam wing cores
wing/engine mount internal bracing
balsa elevons
durable engine mount
corplast fin/handle
illustrated 28 page instruction manual
Items needed to complete:
Equipment:
.25 -.28size engine
Elevon mix capable TX and 3+ channel RX -- (throttle, elevons), or 4th servo and "Y" harness for dual ailerons
aileron extension (used as switch/charging)
battery: 270-600 mAH
3 servos: standard, mini, or micro servos OK, but metal gears recommended in smaller servos
Parts:
2 rolls UltraCote covering (UltraCote is superior to all other coverings for durability and repairability)
4-6 oz. fuel tank
fuel tubing
control horns
push rods
engine mounting hardware
Adhesives:
3M-77 Spray adhesive
Goop brand adhesive
. masking tape
Predator Specs:
Wingspan: 48"
Weight: 2.5 - 3.0 lbs
Rec Engine: .20 - .28
Radio: 3 channels
Wing Area: 600 sq in
Attached is what the completed predator looks like. If you fly zagi and want more, this is it.
I'm asking $25.00 plus 7.00 for shipping.
DEATHspiral is offline Find More Posts by DEATHspiral
Old Apr 02, 2002, 09:24 AM
GregG is offline
Find More Posts by GregG
Trader Rating: 21
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Trader Rating: 21
Hey, I like the catchy name you've chosen for it.
GregG is offline Find More Posts by GregG
Building a 2-piece Kadet LT-25 Wing rcav8r2 Sport Planes 58 Mar 25, 2006 12:33 AM
Question Glow to gas conversion marshallcowboy Engines 5 Dec 15, 2004 11:48 AM
Glow Planes / Thick Wing Observation Phat2Wheel The Builders Workshop 9 Oct 27, 2003 09:25 AM
GLOW/GAS EPP WING (80mph) DEATHspiral Aircraft - Electric - Airplanes (FS/W) 9 Apr 08, 2002 11:09 PM
GLOW WING .25-.28 (80mph) DEATHspiral Aircraft - Fuel - Airplanes (FS/W) 0 Apr 01, 2002 09:14 PM
