I just tried that, put motor on the frame without gear, runs fine, no strange noises. On the brushed motor I am using a Piccolo plastic pinion (not sure what tooth it is) that I 'loctited' on, and on the Feigao I have a 9tooth pinion that Like90 put on for me, I think its the one for the Zoom. Quote:
So it has a kv of 4680. However, I doubt its the motor because I still get that noise weith my brushed motor. This is really wierd (and annoying), becuase I seem to have cancelled evrything out, tried everything out, but I still get it... Thanks all, Duane
I don't like the sound (no pun intended) of the 1 - 2 mm up / down on the main gear. I saw this on an AeroHawk where I (badly) made a CF main shaft and did not get the main gear to seat properly... it made a horrible noise and was eating the brass pinion and plastic main gear.
I know that you have had your heli running with the BUSHED motor. But could you do that again just to find out if the sound is different and how different that is? It could be that the noise coming from resonant which only appears at some certain speed. If the motor fully assembled to the chassis runs fine on its own then I think you are ok. But yeah, the noise is disturbing.
Latest blog entry: PrintRBot assembling completes &...
Joined Nov 2002
Hi Minimole,
I've got a humblebee in which some times i do hear a high pitch "screeching" noise. After checking around, i have found out that it is coming out from the main motor. Taking out the motor and spinning the motor shaft by hand causes the same sound. I hope this is the problem for you as it's easy to fix. Just change motor
| Thread Tools | |
| Question Electric Motor break-in Please Help | propjobbill | Power Systems | 4 | Oct 18, 2004 10:30 AM |
| Question EDF50 motor confusion GWS please help | clytle374 | GWS (Grand Wing Servo) | 3 | Aug 24, 2003 09:06 AM |
| Astro motor timing problems - (please help) | harryo | Power Systems | 9 | Feb 19, 2003 07:46 AM |
| Weird noise coming from my AF 05 | twinster2 | Power Systems | 1 | Nov 17, 2002 05:30 PM |
| FS F-16 Motor mount instalation?..please help | Vincent | Electric Ducted Fan Jet Talk | 2 | Nov 03, 2001 05:15 PM |
