This thread is privately moderated by DEATHspiral, who may elect to delete unwanted replies.
Old Apr 01, 2002, 09:14 PM
DEATHspiral is offline
Find More Posts by DEATHspiral
Trader Rating: 0
San Diego, CA, USA
Joined May 2001
Trader Rating: 0
GLOW WING .25-.28 (80mph)
If you've flown zagi's for combat, and you want more power, speed, climb, and durability, here is a wing capable...but the only draw back is it being glow. With a .25 motor, it's capable of flying in excess of 80mph. The wing is made of EPP. The motor is mounted with nylon bolts which will break, and eject the motor should you have a run in with the ground, a fence, a parked car, or anything in its way. This plane is as durable as a ZAGI 3C and will allow you to do low aerobatics without the penalty of destroying your plane like other balsa planes.
I bought a few extra kits, but never needed to build anymore. This is the end all for anyone wanting to learn how to fly low and perform tricks.
The TufFlight Predator design was inspired by the great flying wings flown in open R/C combat over the past decade. With minimal parts count and many pre-shaped mating surfaces, this kit is ready for covering after one evening.
Very lightly loaded, the Predator will turn or loop in less than 30 feet at full throttle. Low drag design allows fast speeds, and good glide for landing with power off. Compact size and no field assembly means you'll go from the car to the air in minutes.
Items included in kit:
durable foam wing cores
wing/engine mount internal bracing
balsa elevons
durable engine mount
corplast fin/handle
illustrated 28 page instruction manual
Items needed to complete:
Equipment:
.25 -.28size engine
Elevon mix capable TX and 3+ channel RX -- (throttle, elevons), or 4th servo and "Y" harness for dual ailerons
aileron extension (used as switch/charging)
battery: 270-600 mAH
3 servos: standard, mini, or micro servos OK, but metal gears recommended in smaller servos
Parts:
2 rolls UltraCote covering (UltraCote is superior to all other coverings for durability and repairability)
4-6 oz. fuel tank
fuel tubing
control horns
push rods
engine mounting hardware
Adhesives:
3M-77 Spray adhesive
Goop brand adhesive
. masking tape
Predator Specs:
Wingspan: 48"
Weight: 2.5 - 3.0 lbs
Rec Engine: .20 - .28
Radio: 3 channels
Wing Area: 600 sq in
I'm asking $25.00 plus 7.00 for shipping.
DEATHspiral is offline Find More Posts by DEATHspiral
Discussion Chilliwack Fly in aug 25 to 28 Ron Electric Flight Events 45 Sep 06, 2006 09:53 AM
Discussion Looking for first Glow warbird(.25-.40) Airplane boy Fuel Warbirds 7 Jun 27, 2006 06:56 AM
Discussion PHX-25 @28 amps??? Sandyc Castle Creations 7 Apr 27, 2006 04:47 PM
Discussion Building a glow wing. bobdabuilder Flying Wings 22 Jan 16, 2006 04:34 AM
GLOW/GAS .25 wing (80mph) DEATHspiral Aircraft - Fuel - Airplanes (FS/W) 1 Apr 02, 2002 09:24 AM
