Old Apr 01, 2002, 08:33 PM
pbrokaw is offline
Find More Posts by pbrokaw
Madison WI
Joined Feb 2002
3ED Gearbox
Guys:
What kind is the GB that gary used and where do you get it.
pbrokaw is offline Find More Posts by pbrokaw
Old Apr 01, 2002, 08:35 PM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
It's the Great Planes GD-600. He sells them.
www.gwmp.net
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Apr 01, 2002, 08:47 PM
pbrokaw is offline
Madison WI
Joined Feb 2002
Thanks Jeff
Do you think that combo would work in a LT-25 on ten cells.I am flying mine on a Mag Meyhem but it is a little slow to climb decent.
I figure if it will make a 3ED fly that good, a LT 25 would not be too bad.
Perry
Old Apr 01, 2002, 08:56 PM
Fayetteville, GA
Joined Oct 2000
I assume you are talking about the Endoplasma with the 4.6:1 ratio on 10 cells.
Should be nice....just can't run full throttle full flight. The com and brushes won't last long with extended WOT.
What prop and gear ratio are you currently using?
What's your current all up weight?
Old Apr 01, 2002, 09:06 PM
pbrokaw is offline
Madison WI
Joined Feb 2002
Jeff:
I am running a Master Airscrew 12/8 E-prop
3/1 GB ratio.
17 amps at WOT(not enough I know)
5.5 pounds
Perry
Old Apr 01, 2002, 09:17 PM
AirVenture is offline
Find More Posts by AirVenture
He wasn't always evil
AirVenture's Avatar
SW Wisconsin
Joined Jul 2001
pbrokaw, nice to see a flyer from Wisconsin. I'm about an hour and a half soutwest of you near Platteville. Where do fly out of? What kinds of planes?
-Brett
AirVenture is offline Find More Posts by AirVenture
Old Apr 01, 2002, 10:13 PM
Fayetteville, GA
Joined Oct 2000
I assume you are not on 10 cells right now. That would put your system in the high 20's WOT.
According to the calcs...you will get about a 35 degree climbout with a 10 cell endo / 4.6:1 box.
Or you could gear it higher with an MEC box and swing a larger prop at the expense of pitch speed.
Also...try the APC E series props...less current than the MA Electrics.
Old Apr 01, 2002, 10:51 PM
pbrokaw is offline
Madison WI
Joined Feb 2002
Brett:
Send me a e-mail:
<pbrokaw@merr.com>
I call Muscoda Home on the weekends!(40 mins from you)
Perry
Old Apr 01, 2002, 10:53 PM
pbrokaw is offline
Madison WI
Joined Feb 2002
Jeff:
Yes,I am running ten cells,there must be something wrong with my set-up.I think it is the ESC(Dymond D50)
