Old Jan 03, 2011, 09:35 PM
Retired Aero Engineer
ronhowell's Avatar
United States, CA, Cypress
Joined Oct 2010
Originally Posted by gotboostedvr6 View Post
3.2mm shaft with 10mm of overhang is more then enough meat for our use
Of course it's enough! As I stated, the prop collet depth is 10mm. The problem is you can't use it on the Magellan setup, for the interference/clearance reasons I stated.
Read what I wrote again. If you can't visualize the problem, maybe I should show some photo pix.
ronhowell is offline Find More Posts by ronhowell
Old Jan 04, 2011, 10:57 AM
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
I read your post " The effective motor shaft length is only 10 mm" as the shaft extends past the bulkhead 10mm because to be effective it would have to be usable.
A pic would be great
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Jan 04, 2011, 01:46 PM
ronhowell's Avatar
Joined Oct 2010
Yes, I can see how my description could be misunderstood. I suppose I should have said "the INSTALLED effective motor shaft length available for the prop collet is reduced to around 1.5mm". Not enough for a safe installation I think.
Old Jan 06, 2011, 12:15 AM
MISTERSCOTT's Avatar
Sonora, Califonia
Joined Jan 2002
Ron,
It took two and a half weeks for my HK order to arrive.
Good Flying,
John
MISTERSCOTT is offline Find More Posts by MISTERSCOTT
Old Apr 03, 2011, 06:12 PM
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
It only took me about 4 years to finish this but it flew ...
I just put in my box-stock Sirens first (and only flight...) and much to my delight it went remarkably well
With the brushed motor '600' throttle at about 66% the model was hand launched and with the zero/zero setting on all surfaces and balanced about 1/3 from LE it took to the air in a controlled manner. More power = stronger climb of about 40 degrees with ease.
This model glides FAST. after about 8 minutes with some wide circle thermaling, i set up for a very-very-very long approach and needed all of it. About 150~200yds into the wind was enough to land and exhale.
I am really glad i learned to fly the power planes like the eflite T-28 because this required more power flying skills(watching out for tip stalling, adverse yaw, stall avoidance with motor control, etc) than RES glider skills.
When i bought the box-stock plane/motor/esc package i had just reentered the hobby after about 18 year abscence and put the model aside as too fast and different for my skill set. I had the building skills part of the process but the motor and aileron/elevator part of it was way beyond my RES Oly2 and free-flight flying skills.
Moving forward 3+ years and actively building/flying for the past 2 years, i finished up the assembly by substituting the 1lb nicads for a 2200mah 40c 7.4 HK lipo, still using the Tower brushed '600' motor,30A+ brushed ESC and folding prop.
The biggest part for me was figuring how to make all the wiring for battery and esc work in the narrow fuse and mounting it all securely. As it went the Airtronics 6ch 2.4ghz RX sits in the rear most fuse cutout under wing hold down screw(antenna sticking out vent hole), esc in next forward fuse cutout , and 2s lipo battery velcro'd on a removable cut down paint-stiring stick that slide in/latches to last forward fuse cutout. The esc, motor, and lipo are all connected by EC3 plugs which i find much easier to use than the Deans.
This week i will move the controls from ch2 only to ch2 + ch6 so i can set up the spoilerons (must have..) and aileron differential. I really miss my ch 4 rudder after learning how to use it
It was worth learning the prop flyer skills to mesh with the glider platform and am looking forward to flying it again....in a much more open space.
Siren Package = http://www3.towerhobbies.com/cgi-bin/wti0161p?&I=LZ1158 but dump the nicads and nicad charger, they are a waste of money since lipos came down in weight and cost.
john s.
jswain is offline Find More Posts by jswain
Old Apr 04, 2011, 02:08 AM
Sonora, Califonia
Joined Jan 2002
Alright John,
Glad to see another of these good flying planes in the air.
I still am flying mine about twice a week when its not raining.
Its more fun when its windy...
Good Flying,
John Scott
Old Apr 04, 2011, 08:10 PM
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Originally Posted by MISTERSCOTT View Post
Alright John,
Good Flying,
John Scott
I need to fly mine more but the performance just isn't what I was hoping for. I bought it used with the kontronic motor, gearbox, and esc combo. maybe I was expecting to much out of it.
Hance is offline Find More Posts by Hance
Old Apr 05, 2011, 01:54 AM
Sonora, Califonia
Joined Jan 2002
Hi Hance,
I think you could use more power. See my post #1118 on previous page, plenty of warmliner peformance, feels like a hotliner in my brain...
Not too expensive, two batts., ESC, and motor cost less than your motor did when new!
Good Flying,
John
Old Apr 05, 2011, 07:17 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
What battery and prop?
As stated throughout this thread, the model will handle significantly more power. With a higher-rated ESC and better batteries, you can push that motor to close to 1000W *in short bursts*..
..a
Old Apr 05, 2011, 08:38 AM
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
..a
I am using 3s 2200 30c packs. I can't remember which prop and am out of town working so no way to find out right now.
Old Apr 05, 2011, 09:27 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Oh wow, then yes - you are probably right around "stock" power and it flies *exactly* as intended by the manufacturer. That is about half of what most of us fly on, however. Double you battery capacity (i.e. 4000-5000mAh) and get an 80A ESC or better, and prop for 80A or so (I think the 14.5x14 is on mine still)..
..a
Old Apr 05, 2011, 10:08 PM
United States, NJ, Roseland
Joined Apr 2009
Andy, what about the hyperion 3032-8 on this plane 3S 5000 should net 1100 watts with a 17x8 prop 85 AMPS.. 38 mm diameter
hidaven is offline Find More Posts by hidaven
Old Apr 06, 2011, 05:20 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
No idea, never owned a Hyperion motor.. 1100W is a lot, though..
..a
Old Apr 06, 2011, 07:40 PM
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
..a
Thanks for the advice. I am guessing you are running two packs in parallel to fit that much capacity in the plane. I didn't know the kontronic could handle that much power even in short bursts I feel an upgraded esc is in the works. I used to have a multiplex blizzard that was around 650 watts if I could get the siren up to that level of performance I would be happy.
If the kontronic dies I will throw a ritewing motor in it I have one on order that will take 2000 watts if you don't pound on it all the time.
Old Apr 06, 2011, 08:32 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Last pack I flew was a 3s 3850 if I recall correctly, no issues getting that in.
..a
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
