Old Jun 23, 2010, 08:48 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by flightmare View Post
Johnny
nibble out the old one,then use the drum sander to take out the rest..
I think straight epoxy is good..I tack mine in place with Ca,then lay in a nice fillet around the perimeter.
Layout the holes for the motor prior to installing the firewall..
While you are at it ,make extra firewalls for other applications..leave them big,you can turn them down in a drill motor for a perfect fit...
How snug should it be without glue? Should it fit tight in the fuse before glue?
I have the stock firewall out by the way, trimmed it up and it's ready for a new one.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 23, 2010, 09:54 PM
flightmare is offline
Find More Posts by flightmare
The frigin Catalina wine mixer
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
Originally Posted by John Lueke View Post
McMaster Car has G10 fiberglas plates in 1/16, 1/8 etc thickness. A 12x12 sheet will give you enough material to make a bunch of motor mounts. Stick some paper on it and draw the diameter that you want, mark the motor holes on the correct diameter and sand and drill. Takes about half an hour from start to finish.
Xlnt info John...Was wondering where one might acquire a larger supply..
I'm in..
flightmare is offline Find More Posts by flightmare
Old Jun 23, 2010, 09:59 PM
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
It should stay put on its own...Then tack it in...
Old Jun 23, 2010, 10:57 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
For my motor mount I...
1) dremel the old mount to weaken it.
2) punch it out with a hammer and screw driver.
3) make a new one to size (~39mm dia) out of the thickest plywood possible (for my P32 it is 1/4" ply). Circuit board also works great in this position, as mentioned.
4) drill out motor holes.
5) mount motor.
6) Wrap motor in wax paper or tape.
7) apply a fair amount of JB Weld epoxy to the mount and to the position it will sit in the fuse.
8) slide the mount/motor assembly forward through the wing getting as little on the inside of the fuse and you fingers as possible.
9) Roughly position and pull forward so it is a tight fit
10) apply a large fillet of epoxy to the area available (avoid you motor or gb shaft)
11) Mount spinner and set final alignment so it is level with the front of the fuse (unless you want down/right thrust).
12) hang upside down and allow to set for at least 14 hrs (24 is best!)
this has held up to 2400W in my Siren and 1500W in my Escape.
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old Jun 24, 2010, 03:49 AM
You down with EPP?
Houston, Tx
Joined May 2009
thanks for the detailed info Kid.
This is one of the handful of jobs in this hobby I have been avoiding, but I am determined to get this right. Better the Siren to practice on over my new Flash II Carbon. I had a professional make me one for that beauty... David Hauch
Old Jun 24, 2010, 07:57 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I like epoxy between the mount and nose, so a nice tight fit, but then pull it out, run a bead around the edge, then push it back in. You want a fillet on both the front and back sides..
..a
Old Jun 24, 2010, 09:40 PM
You down with EPP?
Houston, Tx
Joined May 2009
..a
Backside? How would that be effective? You can't apply after it's in place.
Old Jun 25, 2010, 06:41 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
For additional support when you bump the nose on landing..
Sure you can, use a long stick - bamboo skewer..
..a
Old Jun 25, 2010, 08:46 AM
You down with EPP?
Houston, Tx
Joined May 2009
..a
Will do.
Old Jul 12, 2010, 10:07 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Well, compliments of my nice brand new Turnigy 3s-2200 45/90C, I got to try 6s with my Siren today at the AMA field in Muncie Indiana. To say I was blown away would be an understatment! The collective flight line was giggling after launch. Vertical speeds I would assume were around 110-120mph. I believe this takes the Siren into true "hotliner" catagory.
This is around 2200W of power. And it takes the Siren to true "spec" height in a mature of 3 seconds. Andy, I will get a video tomorrow and post it just for you in the following days. I think you will agree it looks like 2200W this time!
Kid
Old Jul 12, 2010, 10:17 PM
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
Kid
Nice Kid..
Old Jul 13, 2010, 01:58 AM
You down with EPP?
Houston, Tx
Joined May 2009
Wow, and I though It was booking it at 900w.
I have been flying it with the ARC 36-55-1.5 for the past week. It's an entire different experience from the Turnigy motor.
Old Jul 13, 2010, 07:15 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Looking forward to it, Kid.
What servos are you running?
..a
Old Jul 13, 2010, 04:28 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
..a
HS-81 for the ailerons (marginal, but they appear to be working).
Hs-56HB in the tail (I think this is it, though it may be a 65, its been so long since I put it it!)
so far i've had nothing but positive control and never flutter
Old Jul 13, 2010, 05:20 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I'm using 56's on ailerons and a 55 on tail. I'm thinking an upgrade may be in order, but before power, I'd need to do something about those servos! No problems on ~1000W though..
..a
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
