Old Jun 20, 2010, 09:57 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by rclab1 View Post
is there a PowerPackage combo deal for the Siren?
(esc, brushless motor, prop....etc.....)
what site sells them?
thank you.
My power package cost me $62 (ESC/motor/prop)
Unorthodox setup, but the video is two posts above, you make the call.
The only disadvantage to a small prop with 1000 watts is if you stall or you need to get out of trouble, you need WOT. 1/3 throttle will get you moving, but if you need to bust out or go straight vertical, you need to floor it.
This is my first experience with 7 and 8 inch props on a glider of this size, but it works when you want a cheap setup. You just need the watts.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 20, 2010, 10:05 PM
rclab1 is offline
Find More Posts by rclab1
USA
Joined May 2010
JohnnyRocco123,
great vid up above like you said, but I think over 900 watts for a
newb like myself is too much.
Im coming from a Radian which has 180 watts.
is there a powerPackage thats more like 300-400 watts?
do you think the 300watts is too low? may stall a lot?
I think 400 watts is better.
where do you get your electronic powerPackage?
(esc/brushless/prop etc....) great price what you had....
I'm interested !
rclab1 is offline Find More Posts by rclab1
Reply With Quote  (Disabled)
Old Jun 20, 2010, 11:34 PM
You down with EPP?
Houston, Tx
Joined May 2009
JohnnyRocco123,
I'm interested !
It's all from hobbycity. The model numbers are in the video.
I tried this plane out on 500 watts the first time around. It didn't have enough authority in 15mph winds. It was a disaster. It wasn't until I moved up to 800-1000 watts that I felt like the power was fitting.
Moving from a Radian to a Siren is a big jump if you haven't flown with ailerons before?
If you have experience with ailerons I would say this is perfect. It is my first "hotliner" although I have hopped up gliders in the past.
The thing that I had to get used to is the giant wing. You have to be careful turning at low speeds. It sinks like lead if you stall out. That's why a bigger prop would probably be a good idea for a newbie. IMHO.
I fly little pylon racers and figured it would be like flying a giant one.....nope. Not at all.
One more thing. If you don't have decent power, you will be all over the throttle, non-stop. Power is good for these planes. All it takes is 3 to 4 second bursts and you are across the sky or way vertical. Then you can float around and try and catch a thermal.
Old Jun 21, 2010, 01:08 AM
flightmare is offline
Find More Posts by flightmare
The frigin Catalina wine mixer
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
hello....
do you guys have a video of the Siren with
the motor/esc combo from the ParkZone Radian?
or something in that setup.....
I want to put my Radian brushless motor/esc
(if it works) in the Siren........
RC
refer to page 1 of this review on a primary setup for your first time Warmliner.These are good starting points on motor,esc,props etc.
From there, glance through the rest of the review,talk to allot of people,and ask tons of questions..The more info you get,the better..Most of the mistakes have been made already at other pilots expense,you just need the patience to sift through all the info and determine if it suits you or not..
Flight...
flightmare is offline Find More Posts by flightmare
Old Jun 22, 2010, 06:24 PM
You down with EPP?
Houston, Tx
Joined May 2009
firewall support
During a flight the other day I noticed a different kind of vibration noise. After inspecting, I didn't find anything solid. But while I had it down I decided I should beef up the firewall, so I don;t have to worry about it.
What's the best way to do this?
If I put a layer of fiberglass cloth over the firewall and load it with epoxy, which cloth thickness? Do I overlap it?
Do I just drench it with epoxy and then sand it down and re-drill my holes?
Is there an alternative or better method?
Thanks guys
Old Jun 22, 2010, 08:04 PM
John Lueke is offline
Find More Posts by John Lueke
John Lueke's Avatar
Miamisburg OH
Joined Dec 2003
How thick is the stock firewall? With the power you are running there may not be enough mass in the firewall/fuselage joint to handle even a small imbalance in the prop/spinner. Also, make sure all of the motor mounting screws are tight. You may want to beef it up from the inside to get more glue joint area between the firewall and the fuselage.
John Lueke is offline Find More Posts by John Lueke
Old Jun 22, 2010, 08:58 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Replace it!
..a
Old Jun 22, 2010, 11:03 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by Andy W View Post
Replace it!
..a
Ok, you say replace it. Sounds like a good idea, but how do I do it without destroying the front of the fuse? I'm a foamie/balsa guy, I have no experience making mods or fixes on something like this. In the last fuse, I just about tore a hole through the bottom trying to get the battery tray out.
Old Jun 22, 2010, 11:16 PM
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
Go to radio shack or michaels..from Radio shack,buy a piece of printed circuit board,and make one.Michaels has some real fine plywood,like 1/8 or 3/16 thick..they come in like 1'x1' foot squares..
For removing it,just use your handy Dremel tool and cut it out..once you get it down close to the fiberglass,use the small drum sanding disc and finish it off...
Old Jun 23, 2010, 12:18 AM
Outback Joe is offline
Find More Posts by Outback Joe
September 2010
Outback Joe's Avatar
United States, OR, Lakeview
Joined Oct 2009
I removed mine and rotated it for the new motor.
See it here.
http://www.wattflyer.com/forums/show...1&postcount=13
I have to tell you that if yours is like mine there is little or no epoxy on the back or sides of the firewall. Once you remove and reinstall it with the correct amount of epoxy it will be much stronger.
Outback Joe is offline Find More Posts by Outback Joe
Old Jun 23, 2010, 12:59 AM
You down with EPP?
Houston, Tx
Joined May 2009
Circuit board over ply? I'm thinking mine cracked from tightening screws with lock washers. I didn't over-tighten either.
When I glue the circuit board back in should i use straight epoxy or should I put some fiberglass filler in it?
I'm off to try and pry the other one out.
Old Jun 23, 2010, 05:12 PM
rclab1 is offline
USA
Joined May 2010
Siren, Lots of questions....
deleted
Old Jun 23, 2010, 06:00 PM
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
One piece wing...Its big..
Old Jun 23, 2010, 06:11 PM
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
Johnny
nibble out the old one,then use the drum sander to take out the rest..
I think straight epoxy is good..I tack mine in place with Ca,then lay in a nice fillet around the perimeter.
Layout the holes for the motor prior to installing the firewall..
While you are at it ,make extra firewalls for other applications..leave them big,you can turn them down in a drill motor for a perfect fit...
Old Jun 23, 2010, 07:45 PM
John Lueke's Avatar
Miamisburg OH
Joined Dec 2003
McMaster Car has G10 fiberglas plates in 1/16, 1/8 etc thickness. A 12x12 sheet will give you enough material to make a bunch of motor mounts. Stick some paper on it and draw the diameter that you want, mark the motor holes on the correct diameter and sand and drill. Takes about half an hour from start to finish.
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
