Old Jun 05, 2010, 09:53 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Don't take this the wrong way, but that doesn't look like 1500W..
What's your RPM?
..a
Old Jun 05, 2010, 10:07 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
What's your RPM?
..a
You're right, its not over-whelmingly fast. It spins right around 8300 RPM. I think my pitch speed is just too low. That, combined with the slim prop means its not as quick as you might think. Also, keep in mind that mine weighs in at 1665g or 59oz, which I believe to be pretty heavy.
Vertically it won't blow you away. But it maintains a lot of energy due to the weight. Also it is very fast in the down lines.
Lastly, a couple things to consider
1) the video doesn't really do it justice. It is a very impressive plane.
2) the power system was designed around 6s, so more power will really make it shine.
3) Lastly, the motor is never run horizontally. So its never really allowed to gain speed. I suspect it is capable of 110-115mph in level flight, but I don't want to test this!
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old Jun 10, 2010, 11:33 PM
nate 1001 is offline
Find More Posts by nate 1001
nate 1001's Avatar
PA
Joined Jul 2003
Finally got my speed control back. Test flight went great. 3 seconds of motor is all that is needed to get up. The plane held up fine just have to fine tune somethings. There is a warp in the wing that hopefully I can get out, as the faster you go the more it turns. So confirmed that it will hold up to almost 2000watts.
nate 1001 is offline Find More Posts by nate 1001
Old Jun 11, 2010, 12:19 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Hey Nate, congrats on getting your plane back in the air! That is always a relief!
Would there be any way for you to get an exact (or pretty close) reading of your power and your RPM? I would love to do a comparison between your 3s/outrunner and my 5s(6s)/inrunner...
Kid
Old Jun 11, 2010, 04:03 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Got my Siren just about ready to again.
This time around I will use the same Rhino 4s 2150mah with a Turnigy 36mm 2000kv turning an APC 6x4 sport. A fixed apc prop with a 6" diameter should eliminate worries of firewall ripping out. I think this is a very safe setup for this airplane.
I will take video ASAP so you guys can see some 6" vs. 14" props.
I haven't done a bench test yet but I anticipate around 850 watts. Should be good for a relaxing flyer vs. my Flash II project that will be insane.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 12, 2010, 03:10 AM
You down with EPP?
Houston, Tx
Joined May 2009
After some bench tests, the APC 7x5 sport seems to be the sweet spot I was looking for.
976 watts
67 amps
Rhino 4S 2150mah 30C
Old Jun 13, 2010, 06:46 PM
You down with EPP?
Houston, Tx
Joined May 2009
wing repair?
Got it
Old Jun 13, 2010, 08:12 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Maybe remove the covering from the top surface and either epoxy or CA glue the problem area. Then recover or cover in tape.
Just my .02
Kid
Old Jun 13, 2010, 09:56 PM
You down with EPP?
Houston, Tx
Joined May 2009
;0 -
Old Jun 14, 2010, 03:05 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Test completed on 6s. Everything held up to bursts at ~9000rpm. Should unload slightly in the air, and once it unstalls I believe the current will drop to more like 100A which should be about perfect!
Kid
Old Jun 17, 2010, 09:36 PM
You down with EPP?
Houston, Tx
Joined May 2009
Evening flight June 16
Here is a quick 2 min video of my Siren taken yesterday.
Siren June 16.wmv (2 min 23 sec)
Old Jun 17, 2010, 10:31 PM
Outback Joe is offline
Find More Posts by Outback Joe
September 2010
Outback Joe's Avatar
United States, OR, Lakeview
Joined Oct 2009
Nice Johnny, Looks like you have the plane dialed in better, sounds good too...
Outback Joe is offline Find More Posts by Outback Joe
Old Jun 19, 2010, 10:37 PM
rclab1 is offline
Find More Posts by rclab1
USA
Joined May 2010
deleted....
rclab1 is offline Find More Posts by rclab1
Reply With Quote  (Disabled)
Old Jun 20, 2010, 06:35 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
That would be a pretty low-power system for a model like the siren..
..a
Old Jun 20, 2010, 01:50 PM
rclab1 is offline
USA
Joined May 2010
is there a PowerPackage combo deal for the Siren?
(esc, brushless motor, prop....etc.....)
what site sells them?
thank you.
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
