Old May 20, 2010, 10:53 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I have never installed a firewall in a hotliner before. Is there anything else you use other than this industrial epoxy?
http://www.westmarine.com/webapp/wcs...1529&langId=-1
Do you make a ring for the firewall to sit flush against or do you just epoxy it and set it?
Any pointers or how to for a job like this? I want to make sure this thing never comes out unless I want it to.
Thanks guys
BTW, this won't be for a Siren it will be for a Flash II
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old May 21, 2010, 05:26 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You don't need expensive marine epoxy, just a reputable brand and make sure you have a small fillet on both sides..
..a
Old May 21, 2010, 07:01 PM
flightmare is offline
Find More Posts by flightmare
The frigin Catalina wine mixer
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
Johnny,
What I do is just tack weld the firewall in with Ca,not much,maybe 3 or 4 small little dabs..
Just enough to hold alignment.When satisfied with it,I run my fillets.
flightmare is offline Find More Posts by flightmare
Old May 21, 2010, 07:33 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by flightmare View Post
Johnny,
Everyone seems to be saying the same thing. Sounds like a plan. I am going to make a fiberglass/epoxy paste. Since I will be running small props, I think I am going to install as straight as possible.
Old May 24, 2010, 08:51 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Well, I have had a chance to test the props more in depth. They were
Aeronaut 14x12
RFM 14.5x14 (slim)
Current draws are nearly identical, with the RFM drawing perhaps a little less (this is hard to say, as I flew part of the flight, and then landed and switched props. So the recorded values the RFM drew less, but this was on less then fresh batteries). The initial thrust is slightly higher with the Aeronaut, so acceleration is a little faster initially. But, after this the RFM takes over. It is much quieter (I can't emphasis this enough! It appears to be almost silent compared to the Aeronaut. Sound is generally a good indication of efficiency, so this bodes well for the RFM blades), as well as offering much higher exit speeds at the top of the climb. Lastly, it folds nicer to the fuse, though this is hardly noticeable performance-wise while gliding. Lastly, the RFMs I suspect will be more robust, but this is just a gut feeling as they have both held up perfectly so far at ~8500 RPM.
Just thought it would interest some people, although it appears most don't run as large of props on their Sirens. The RFM is better to me, BUT at almost 2.5X as expensive as the Aeronaut, its up to your discretiom whether the performance is worth it!
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old May 25, 2010, 05:12 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The RFM is almost certainly drawing more current in flight. It would be more stalled if you're measuring on the ground..
..a
Old May 25, 2010, 09:50 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
..a
All measuring was done in the air, using my ICE controller.
The voltage was only slightly different from one flight to the next (about .4V), but the current dropped 10A from the 14x12 to the 14.5x14. I would say that looking at the logs it appeared that the 14x12 did unload slightly towards the top of the climb, but not much.
Kid
Old May 25, 2010, 10:45 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I stand corrected - wider blades on the aeronaut optimized for thrust vs. speed, makes sense..
..a
Old May 26, 2010, 10:51 AM
fwolf15 is offline
Find More Posts by fwolf15
Germany
Joined Jan 2007
but be careful, the specs says maximum 9000 RPM, so with the RFM cfk you will have more security stock. The result of a broken prop is often much more expensive than only the costs of a cfk prop.....
rgds
Wolf
fwolf15 is offline Find More Posts by fwolf15
Old May 27, 2010, 11:10 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
rgds
Wolf
Yes, this is something I believe I included in my write-up. That for the peace of mind the RFM prop is a better choice.
Also, I can appreciate the limits of a folding prop, as I have had a couple cheap ones rip apart, one of them taking the motor shaft with it :O so I will never come close to pushing a folding prop again (live and learn!). If/when I ever go 6s, I will only be running the RFM prop, as in the case I will be up around 9500-10000RPM, which is well beyond how far I would like to take the Aeronaut prop. Lastly, if the prop does infact fail, I acknowledge that I am pushing things to the limit, and if it fails it will be only my responsibility!
Kid
Old May 27, 2010, 04:04 PM
airboss/oc is online now
Find More Posts by airboss/oc
California Style
airboss/oc's Avatar
United States, CA, El Mirage
Joined May 2007
without having to read all 68 pages , already read the first 10 , hows the Siren flying ? is it fast ? how fast ? can you show some pics of the battery set up and RX placement ? I am in need of more speed and my 36% Sbach is fast but I need more
airboss/oc is online now Find More Posts by airboss/oc
Old May 28, 2010, 05:52 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
No, it's not super fast. It's a beginner hotliner, some call it a warmliner - more like an acrobatic sailplane.
There's video posted in the review and in posts just a couple of pages back that shows how it flies..
..a
Old May 29, 2010, 08:33 PM
California Style
airboss/oc's Avatar
Joined May 2007
..a
thanks that was the answer I was looking for
Old May 30, 2010, 11:57 AM
You down with EPP?
Houston, Tx
Joined May 2009
For ludicrous speed, I decided to go with the Flash 2 Carbon. It's supposed to have one of the toughest wings in it's class.
Old Jun 05, 2010, 09:25 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Heres the video we have all been waiting for. I finally have my Siren dialed and the aileron problem is gone. It really is flying GREAT right now. I told myself that if I can get 5 perfect flights out of it on 5s, i'll move up to 6s.
So I have 3 down, 2 to go. Then it'll be time for another video
Great Planes Siren 1500W (5 min 51 sec)
Kid
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
