Can you really blame it on the model when it wasn't being flown how it was intended to be flown? Not to mention, its been said many times to fix the motor mount, its a known problem...
Are you sure there wasn't a problem with the prop. What brand 8x5 were you running? You were certainly turning too many RPM for it regardless of manufacturer, as the highest rating out there is 16k, and you must have been past that. Theres a chance you threw a blade, or even just a miss balance could have shaken the motor loose. Sucess comes from preparation kid |
Not being flown how it was intended to be flown? That's interesting, did you see the video? How would you say it is intended to be flown? I gave it 3-4 seconds of throttle at most. Wasn't doing any crazy G-Force moves. There wasn't a problem until I put a folder on it. I should have stuck with the APC with the prop adaptor, but that's not how it was intended to be flown. |
The plane was not designed for full throttle blasting passes in level flight. It was ment to climb, then glide etc. etc. Im not saying that I fly the model exactly how it was designed to be flown. But if/when it fails (and I hope it doesn't!) I certainly won't be saying that it is Great Planes problem. It seems unlikely that the motor mount would just "shoot-out". The failures in the past have come from the brake stopping to aggressively, in which case all that torque is transmitted to the firewall. To have it just pull out would indicate some other issue, one that hasn't been experienced by anyone else in this thread to my knowledge. |
Did you remember to put the screw in the elevator servo arm? If not, that most likely caused this failure. I've learned that lesson the hard way. Also, make sure you clip the antenna wires down so they fit inside the fuse. If they stick out, the drag can induce enough flutter to break that firewall clean off. I bet next time you'll put a streamer or small parachute on your motor. Cheers |
United States, CA, Rocklin
Joined Jan 2006
Johnnyrocco123, how did your airframe fare the rest of the flight after your cog drastically changed?
I've had it happen to me for just an instant when the noise alerted me to something horrible happening. Even after immediately shutting down the motor, the front end of my airframe was in shambles. Luckily the motor stayed hanging by the wires and I was able to keep control bringing into a decent landing. This was all due to throwing a blade. |
..a |
When the motor shot out, the CG did drastically change!! It did a few flips, but I regained control and landed it smoothly. I was lucky the battery stayed in place and plugged in, as well as my ESC.
I didn't have a problem until I put the folder on. It lasted all of a minute before it happened. I don't understand why these folding props are rated at such low RPM's. 12K, 16K??? Who would run a folder like that? GP Siren aside, all I have ever seen in hotliners is 1500 - 3000 Watts. These were spinning folders way past these RPM's. Bottomline, the Siren is not for me. If I get into another, it will be better quality that can take some power. AND MORE ROOM IN THE FUSE! Kittman: Thanks for the excellent advice as always. |
The folding prop you were using is not a high performance part. It's designed for small sailplanes using moderate power systems.
The RFM folders used on hotliners are most definitely rated for high power use, although as they are much larger and higher pitch (17x18 for example) they don't typically spin much above 10k RPM. Takes about 3kW to get there, though! ![]() ..a |
Aero-naut has a website with specs on all their products. The page for the props with recs for max rpm can be found here:
http://www.aero-naut.de/en/products/...ropellers.html I thought this might be helpful for those considering a variety of motor/battery/prop combinations so the limits can be understood and hopefully avoid catastrophic failures of the power systems. |
For example, my model is at 1600W (or today in the cold 1520W) and turns just over 8k RPM. Much lower then the ratings by even Aeronaut. And RFM is certainly stronger then that, or so I suspect. Kid |
| Thread Tools | |
| Article Great Planes Wright Flyer ARF Review | Michael Heer | Parkflyers | 22 | Feb 15, 2010 02:42 PM |
| Sold Great Planes Siren Hotliner ARF | Steve H. | Aircraft - Sailplanes (FS/W) | 1 | Sep 13, 2006 03:28 AM |
| Sold Great Planes Siren Hotliner Sailplane | glide | Aircraft - Sailplanes (FS/W) | 6 | Oct 08, 2005 01:20 AM |
| Sold Great Planes Siren Hotliner EP ARF 79" (NIB) | trw43 | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 03, 2005 07:20 PM |
| Great planes siren?? Hotliner or warmliner? | argarre | Electric Sailplanes | 3 | Sep 01, 2004 08:16 PM |
