Old Apr 25, 2010, 12:27 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by Red5 View Post
Help me decide which servos to use where.
Her is what I have:
1- Hitec HS-81mg
1- Hitec HS-82mg
2- HS-55
2- GWS S3002STD
2-CIRRUS CS-25BB
So which would you use where?
Building now so if you could suggest asap it would be appreciated.
Also- Did you guys put screw through the fuse and mount a box for the servos or just use 30 minute appoxy?
This is my first build. So I need some more advice.
55's in the wing, 82 in the tail.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Apr 25, 2010, 07:52 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
55's are not good enough for ailerons.
You either need another 81 or 82 and put a pair of those in the wings, or use the 81 & 82 in the wing and 55 on the tail.
..a
Old Apr 25, 2010, 10:09 AM
You down with EPP?
Houston, Tx
Joined May 2009
..a
I was just commenting on what he had. I went with 65hb's all the way around.
But I must say, I have never had a 55 crap out on me. I use them in most of my planes now, even a pylon.
Old Apr 25, 2010, 12:07 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I was responding to Red5. HS55's are great servos, and yes, they are fine on pylon models as well, but the ailerons on the Siren are too big for the 55's.
..a
Old Apr 25, 2010, 12:37 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I avoid HS-55s like the plague :O
If/When I build the new wing for my Siren, it will have either HS-65HBs or Hyperion DS09s. This plane is more of a budget plane for me, so I used HS-81s for the ailerons. I wouldn't recommend this though, I would recommend better servos
Thekid3418 is offline Find More Posts by Thekid3418
Old Apr 25, 2010, 01:06 PM
Red5 is offline
Find More Posts by Red5
United States, KY, Prospect
Joined May 2004
Is the 82 good enough for the tail? Did you guys use 2 part epoxy or did you build a case to hold the rear in place?
Red5 is offline Find More Posts by Red5
Old Apr 25, 2010, 01:51 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I have had good experiences with goop so far. Its what I used in my Siren, as well as my Escape pylon model. If you choose to use epoxy, I would use very long cure. At least 1-Hour epoxy, maybe longer
Kid
Old Apr 25, 2010, 02:23 PM
flightmare is offline
Find More Posts by flightmare
The frigin Catalina wine mixer
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
install 2 small blocks of wood onto the tail servo,about 3/8 by 3/8 square is about right.then use 2 small wood screws through the fuse like on page one..
I didnt use any goop with this ,3 yrs and still good..Just make sure the blocks dont split and the screws bite soundly...
flightmare is offline Find More Posts by flightmare
Old Apr 25, 2010, 02:51 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
82 is WAY overkill for tail, and too heavy.
I blocked mine in too - this is covered in the review.
..a
Old Apr 25, 2010, 04:38 PM
nate 1001 is offline
Find More Posts by nate 1001
nate 1001's Avatar
PA
Joined Jul 2003
Unfortunetly, the first flight with the new setup didn't happen. The person I got to throw it messed up. I told him to throw it after I turned the motor on. I powered up and he moved like he was throwing it but then hesitated so I shut it down. He then wound up again and threw it right into the ground. The battery pack rammed into the back of the esc and ripped the capacitors off. I can't fix it because it also ripped the solder pads off. So back to castle it goes and more waiting.
nate 1001 is offline Find More Posts by nate 1001
Old Apr 25, 2010, 05:13 PM
You down with EPP?
Houston, Tx
Joined May 2009
Well I got to the field (20 minute drive), and I forgot my tools as well as forgetting to set the brake. Of course I could not remember all of the stick movement instructions so........... still no maiden. It will definitely happen mon, tues, or wed evening.
Old Apr 25, 2010, 08:16 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Guys, look at the video of my test glides to see how far this thing glides from a straight & level toss. Unless you absolutely trust the launcher, just do it yourself. As long as the surfaces are level, the model is just going to glide straight ahead until you get your fingers on the sticks!
..a
Old Apr 25, 2010, 10:51 PM
nate 1001's Avatar
PA
Joined Jul 2003
I know it glides well as I have flown before on less power. I usually launch it myself but was nervous with the amount of power this setup has. I wanted to be ready on the sticks in case something happened. Next time, which probably will be about 2 weeks until the esc comes back, I'll most likely try by myself.
Old Apr 26, 2010, 06:12 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You can launch it power-off, then light it up.
..a
Old Apr 26, 2010, 07:22 AM
nate 1001's Avatar
PA
Joined Jul 2003
Won't it torque if launched without the motor on? The other setup I had was very low power compared to this one so I wasn't worried about it.
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
