Old Apr 10, 2010, 10:22 PM
flightmare is offline
Find More Posts by flightmare
The frigin Catalina wine mixer
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
Hey Red,
150.00 budget may get you up to"fast",but unlimited vertical in a 2m plane will not be cheap..Alot of guys went with outrunners in the Siren.They are affordable ,and can swing a pretty good size prop.
flightmare is offline Find More Posts by flightmare
Old Apr 11, 2010, 07:27 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
There are at least a dozen different power systems discussed in this thread.
..a
Old Apr 12, 2010, 11:03 AM
Red5 is offline
Find More Posts by Red5
United States, KY, Prospect
Joined May 2004
..a
I'm still in the learning phase of brushless motors, ecs's and LIPO batteries. I was hoping for a few links for stuff that I could just buy. Guess I don't need the best set up. But I'd like something fast. I don't plan on competing with this plane. Just flying it at teh park and such. Now I'm concerned that the DX-7 radio I just bought may not even work with the siren. (sucks) But I do have a couple of other 72 Mhz transmitters and such. I just hope I have enough channels to utalize things like flaps and such.
So if you are shopping for your own siren and want to post links to affordable ways to power this plane it would be appreciated.
I found my 4s batttery doe snot fit into the fuse. Can I cut / trim the opening of the fuse to get the battery in there or would that be a mistake?
I guess the best thing for me to do is to go to the local sailing club in Louisville and ask those guys for direction.
Red5 is offline Find More Posts by Red5
Old Apr 12, 2010, 11:26 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Here is my setup that I am about to maiden, it has been used on this thread by others.
Turnigy 480L 1370kv
http://www.hobbycity.com/hobbyking/s...idProduct=9384
Turnigy 60 amp ESC (same site)
3S 2200mah (same site)
13x7 Graupner Folding prop. (google it)
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Apr 12, 2010, 12:01 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Motor:
http://hobbycity.com/hobbyking/store...idProduct=7393
Batteries:
2x http://hobbycity.com/hobbyking/store...idProduct=8932 wired in parellel (3s-4400 20C)
ESC:
http://hobbycity.com/hobbyking/store...idProduct=3727
Spinner:
http://hobbycity.com/hobbyking/store...idProduct=5564
Prop:
http://www.espritmodel.com/index.asp...OD&ProdID=3539
Aeronaut 12.5x9
This setup should give you good consistancy. You're not pushing anything, but you will still get good vertical performance (over 1:1 thrust to weigth I would think) as well as straight line speed. You'll have to watch motor temps though, as that will be the weak link if there is one.
Total Cost:
$104 plus shipping. Well within your desired price range!
Thekid3418 is offline Find More Posts by Thekid3418
Old Apr 12, 2010, 01:02 PM
Red5 is offline
Joined May 2004
Originally Posted by Thekid3418 View Post
Motor:
Batteries:
ESC:
Spinner:
Prop:
Aeronaut 12.5x9
Total Cost:
Thanks guys... Buying now.
---- Motor and spinner are onback order. What would you suggest if I wanted a faster motor? Any other places for the spinner?
Old Apr 12, 2010, 01:16 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
You can get a similar spinner (40/5/8) from espritmodel.com as well. But it will be 3x the cost! It will be of the same or higher quality though.
For motor, perhaps look into the 35-48 1100kv Turnigy motor. If going with this motor, you will have to go with a smaller prop. So make sure you let us know if you go with it.
If looking for a higher quality, yet affordable motor, i would look into the hyperion or scorpion outrunners. Something in the 175g (bigger is better!) or heavier range, with a kv around 850-1150. This will allow you to maintain spinning a fairly large prop while still being efficient.
Kid
Old Apr 12, 2010, 01:37 PM
You down with EPP?
Houston, Tx
Joined May 2009
Kid
That Turnigy 3548 will fit in there without rubbing the motor wires???
I would figure you would have to route the wires outside the fuse and back in.
Old Apr 13, 2010, 09:06 AM
Red5 is offline
Joined May 2004
Old Apr 13, 2010, 09:09 AM
You down with EPP?
Houston, Tx
Joined May 2009
I guess he would have included that info if needed.
Old Apr 13, 2010, 09:29 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I don't know if you would have to, I went with an inrunner
I would guess that you'll have to take the wires outside the fuse and then bring them back in slightly behind the motor. Or, you could glue them to the inside of the fuse, which might give you enough space. Either way, it is manageable to use the big outrunner, and much more efficient then most of the other cheap options!
Old Apr 13, 2010, 09:37 AM
Red5 is offline
Joined May 2004
Which one would you suggest?
Old Apr 13, 2010, 10:15 AM
You down with EPP?
Houston, Tx
Joined May 2009
I am using the Turnigy 480L 1370kv from HC. Under $20.
With a 13x7 on 3S I am pulling 53 amps.
Old Apr 13, 2010, 12:14 PM
Red5 is offline
Joined May 2004
Do you have a link to this motor? Does it offer enough power to make things interesting?
Old Apr 13, 2010, 12:50 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
http://lmgtfy.com/?q=Turnigy+480L
..a
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
