Old Apr 07, 2010, 06:49 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by Thekid3418 View Post
I had my first bad encounter with my Siren this weekend. I took it to the park to try our some new power systems. I started with the new set of RFM 14.5x14 blades that I recieved a couple weeks back. These worked well, but to my untrained eye didn't offer much of an advantage over the Aeronaut 14x12 blades. The initial acceleration was slightly less, while the top speed was slightly higher. Both props drew nearly identical amps according to my ICE 100 Lite. This flight went off without a hitch, and I was very pleased
After this flight I switched back to my Aeronaut 13x11 blades with 4s-2500mah 30C batteries (very very tired old cells!). This netted me a prop rpm of about 9900 according to the ICE once again, it also was around 105A and 1450W. I told my dad to hold on tight and we went for the launch. My first impression was "this is AWESOME!". Absolutely fast climb as well as a very high top end speed. The first climb went off without a hitch, but when I came back around to climb for the second time, this is when things went wrong. At the top of the climb I shut off the motor and there was a strange "popping" noise. Just after the noise, I saw something falling away from the nose of the plane, but I wasn't sure what.
My initial reaction was that I had either
1) Thrown a blade
2) loosened the pinion in my GB
I guessed (2) because the prop was free-wheeling on the way down. After a stressful landing attempt I managed to set the plane down with just a small tick in the leading edge of one of the blades. Upon further investigation, the spinner cone AND prop-nut had come off, meaning the collet prop adapter could slide right off! I am very fortunate to not have lost the yoke/blade assembly that day.
Now, to diagnose what happened. What I believe happened is because of the aggressive brake (in hind-sight it was on "Hard/.1 Delay/fast ramp"), the prop nut spun itself off, taking the spinner-cone with it. This seems very unlikely, but it is the only explaination that my pea-brain could come up with. Because of this I have changed the brake settings to "Hard/.2 Delay/Medium ramp". Hopefully this results in no more issues. We searched for some time for the spinner cone, and alas could not find it again. This is not too critical though, as I already have an RFM 38/6 Spinner waiting to be used with my NEU P32 and RFM 14.5x14 once the GB arrives
All the best,
Kid
Seeing that I only have "brake or no brake" option, I am going with no brake. With my luck the brake will yank the firewall right out the front. If the folder never stops turning so be it.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Apr 07, 2010, 06:52 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The prop will be acting like a giant airbrake.
..a
Old Apr 07, 2010, 07:37 AM
You down with EPP?
Houston, Tx
Joined May 2009
..a
It will have to be, until I can get an ESC with a soft brake.
If there is a potential in-flight disaster, it will definitely happen to me.
Robj, want to chime in?
Old Apr 07, 2010, 07:55 AM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Definately run a brake! If you're using a Turnigy ESC or similar the brake will not be aggressive enough to cause any problems! I can tell you from a brief experience that flying with the prop windmilling is no fun at all!
Thekid3418 is offline Find More Posts by Thekid3418
Old Apr 07, 2010, 09:14 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Kinda what the kid said. The turnigy brake will still allow some freewheeling on a fixed blade prop, at least mine it does. I don't know anything about the folding props but it would seem once they fold back they would not freewheel even with the turnigy brake. Maybe it takes more to push them back than I know.
robj is offline Find More Posts by robj
Old Apr 07, 2010, 10:23 AM
You down with EPP?
Houston, Tx
Joined May 2009
Well I will try it. But....if my motor breaks off....ARRRH!!!
Old Apr 07, 2010, 10:42 AM
You down with EPP?
Houston, Tx
Joined May 2009
I meant chime in about my mid-air disasters.
Old Apr 07, 2010, 11:01 AM
robj is offline
robj's Avatar
Joined Nov 2008
Oh, you've had 4 in 2 months, I was number 3, lastest at TEFF in Austin. You also had 2 other crashes at TEFF.
How about that!!
Old Apr 07, 2010, 12:05 PM
You down with EPP?
Houston, Tx
Joined May 2009
How about that!!
I have crashed 3 planes due to pilot error in the last year, two strykers and one electrostik.
Everything else has been a mid-air or spontaneous combustion.
Old Apr 07, 2010, 12:22 PM
robj is offline
robj's Avatar
Joined Nov 2008
hehe, and 27 due to "non pilot error"?? Not counting running into Howard while landing!! That was a hoot, but very glad the plane made it through with only minor damage.
Old Apr 07, 2010, 04:10 PM
flightmare is offline
Find More Posts by flightmare
The frigin Catalina wine mixer
flightmare's Avatar
USA, CA, Buena Park
Joined Oct 2006
Johnny
Set the brake hard,and spool it up on the bench,cut power..Do this a few times and see what happens..When you do go for the maiden.Apply power slowly,and roll out of the power slowly...this should give you a softer brake...
flightmare is offline Find More Posts by flightmare
Old Apr 07, 2010, 10:22 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by flightmare View Post
Johnny
I'll give it a shot, I only have one brake setting, on and off.
I just held a 5S Absolute in hand while the owner powered it up with a 16x17 prop. Neu motor pulling 150+ amps. Castle 180 ESC on board.
I thought I was going to take off with it. Kind of scary!
Old Apr 08, 2010, 09:40 AM
robj is offline
robj's Avatar
Joined Nov 2008
I didn't want to hold that thing!!
Old Apr 08, 2010, 09:19 PM
Red5 is offline
Find More Posts by Red5
United States, KY, Prospect
Joined May 2004
**** WITH A BUDGET OF 150 FOR BATTERY, ESC AND MOTOR****
I want it to go FAST and have close to unlimited vertical. I plan on runing either a 3s or 4s. What combo do you recomend? Preferably something somewhat cost effective.
Looking for recomendations. If you can provide a link to HobbyKing or whatever it would be helpfull. I'm still learning the lingo for the various motors and such.
Red5 is offline Find More Posts by Red5
Old Apr 10, 2010, 08:29 PM
Red5 is offline
Joined May 2004
ttt
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
