| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 |
Oooooo
If I was an AXI, my face would be stinging from that slap! Ha ha ha Great Review BTW Andy - Thanks! Would your recommendation by the Kontronic Motor then? Or ??? thanks! |
#62 |
That sickening crunch..
Kontronik's are nice motors - pricey but no more than other quality motors like Hacker, Aveox, Neu, etc. You can get "sport" power with outrunners, but for high power you're generally better off with a geared inrunner.
There are a great many motors that fit the bill, but I suggest staying below the full "05" sized motors (i.e. B40 vs B50 in Hacker, Fun 480 vs 500 or 600 with Kontronik), and choosing a wind that allows you to spin a good sized prop (12-15" or so) at reasonable power levels (10 cells seems to be the sweet spot for this model, and no more than 60-70A to prevent ripping the wing off!) ..a ..a |
#63 |
I was leaning towards an AXI Outrunner only because it is what I am familiar with. I have a half dozen electric planes and they all have outrunners. I was also planning to go lipo on the siren, again because it is what I am familiar with. But the Siren is my first attempt at a warmliner type plane, so I am stepping into unfamiliar territory. And I will definitely defer to others who know way more than I do about these types of planes and their associated power systems.
Having said that, would I be better to steer away from lipos as well? It seems their weight savings and accompanying performance gains would be an advantage? IS the main reason to use Nimh batteries their relative inexpensiveness? And if you are willing to recommend specifics, which inrunner brand and type do you favor? thanks again andy. I appreciate your knowledge. |
#64 |
Andy, uh, me again ... rereading his thread, do you know if all of the Jeti ESC's have such a harsh brake I.E. you cannot ramp it to a stop? I was going to maybe go Jeti but I have only ever had one Jeti ESC and it was an older one. I normally use CC's but was seeking to start trying other ESC's.
#65 |
Brakes of Jetis
I own two Jeti Advance regulators (40A and 18A), and both have different brake modes available.
#66 |
Juan, what are the brake modes? Reading on Hobby Lobby, they don't give too much information ... can you provide more detail, either from your experience or from the Jeti documentation? You ended up going with the AXI 2820/10, did you not? Have you flown it yet? If yes, what are your observations and opinion on its performance?
#67 | |
You and I disagree on this, but the axi is about the perfect motor for this plane. As its an inexpensive 500 watts. Its performance is more than adequate. That said, the Kontronik was better than my 2820/10 setups in the bandit. I am would say the 2826/10 would be very close to being the equal of the kontronik (granted this was on older 1700 aup cells).At any rate, I am going to bring my AXI siren to SEFF so we can compare notes and come to some agreement (even if its to agree to disagree) |
#68 |
Hey soho ... you have your siren in the air currently, on the 2820/10, right? What kind of climbouts do you get? Are we talking vertical or 45 degree or?? If you are 500 watts, that sounds like vertical to me, as the plane isn't over 5 pounds is it? What prop/spinner are you running?
thanks to all for the info ... I just printed out the "other"siren thread, parts I and II. It'll take me a while to wade through all of that and I am sure my questions are answered in there. Thanks to all for your patience in answering them again here! |
#69 | |
I have not used yet the 2820/10. I have used the Jeti's with a 2808/20 and a 2208/34. In soft mode the controller makes the motor "whine" so you can cut yourself. After buying the Ion from Tower, I was able to contact Josef Palacek, the maker of Ion/Hoot, and I also have now an Ion Pro, so I still don't know what destination will the Siren have. Any opinion on using it motorless for slope or towing? Regards. |
#70 |
By the way, time ago I was *able* to convert a GP ElectryFly 30A brushed controller from hard brake to soft brake by trying mistakenly to connect the batteries to the output cables.
I heard a "pop" and, voilą, I got soft brake. In fact no brake at all. It seems the transistor in charge of shorting the motor brushes was blown. I still use it with a Slinger. Any valiant? |
#71 |
I used a 2826/10 in the first siren. I have sold both. I bought a second one to mess around with. It will have a 2826/8 not sure about the power or the prop, but I will be running tests later this week I hope to maiden the new setup on Wednesday.
Jay |
#72 |
.. if outrunners could handle 60-80A, I'd be a little more inclined to use them.
..a |
#73 | |
Also its about watts... So if you aren't getting enough amps add some volts |
#74 |
Let me get this straight. An AXI 2826/10 motor is comparable to the Fun 480-33? Would this be suitable for the Electrifly 8cell pack? What kind of amps are being pulled with this setup, and what prop was used? Sorry for all the questions, don't know much about this stuff.
#75 | |
| Thread Tools | |
| Article Great Planes Wright Flyer ARF Review | Michael Heer | Parkflyers | 21 | Jun 22, 2008 07:13 PM |
| Sold Great Planes Siren Hotliner ARF | Steve H. | Aircraft - Sailplanes (FS/W) | 1 | Sep 13, 2006 04:28 AM |
| Sold Great Planes Siren Hotliner Sailplane | glide | Aircraft - Sailplanes (FS/W) | 6 | Oct 08, 2005 02:20 AM |
| Sold Great Planes Siren Hotliner EP ARF 79" (NIB) | trw43 | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 03, 2005 08:20 PM |
| Great planes siren?? Hotliner or warmliner? | argarre | Electric Sailplanes | 3 | Sep 01, 2004 09:16 PM |
