Go Back   RC Groups > Aircraft - Sailplanes > Electric Sailplanes
Old Oct 13, 2009, 08:58 AM   #676
nate 1001's Avatar
4:1 with an 18 inch prop and it would have to be steep also, like a 13 or higher
nate 1001 is offline Find More Posts by nate 1001   Reply With Quote
Old Oct 13, 2009, 09:07 AM   #677
Afaik maximum propsize is 15 inch, I've heard from a other guy that his 16" will not fit.
rgds
Wolfgang
fwolf15 is offline Find More Posts by fwolf15   Reply With Quote
Old Oct 13, 2009, 09:22 AM   #678
nate 1001's Avatar
Then I guess that won't work
Old Oct 13, 2009, 09:36 AM   #679
That sickening crunch..
Andy W's Avatar
Graupner has a spinner with a 1/2" aluminum backplate that I have used in several situations to allow me to get a larger prop on a hotliner or sailplane.
..a
Andy W is offline Find More Posts by Andy W   Reply With Quote
Old Oct 14, 2009, 04:16 AM   #680
How about a 2826 with the gearbox on it and a 6 cell lipo. That should be able to swing a pretty big prop and get over 1000 watts for quite a bit of climb
one more detail is missing: which kind of 2826? /06 or 08 or 10 ?
here some results frome drivecalc for the different motors in combination with an 15 x 13 Aeronaut and a 4:1 standard gear on a 6S battery:
2826/06 :
53 A
6200 RPM
3704 gramm thrust
104 km/h speed
1070 Watt input
2826/08
28 A
5200 RPM
2600 gramm thrust
87 km/h speed
590 Watt input
2826/10
19 A
4600 RPM
2000 gramm thrust
77 km/h speed
400 Watt input
rgds
WOlfgang
Old Oct 14, 2009, 03:37 PM   #681
nate 1001's Avatar
So it still would work. 3700 grams = ~ 8 pounds of thrust at 80 mph. Sound pretty good
Old Oct 17, 2009, 07:27 PM
Serafin
This post is temporarily hidden while Serafin edits it.
Old Oct 18, 2009, 09:07 AM   #683
Originally Posted by Serafin
I post this so no one would make my mistake and crash their Plane.
Do not mix your battery before you fly. I put a used battery in my Cularis. After take-off battery die and I was to low to recover. Was in a turn and wing stalled. Not enough room to build up speed and nosed dive into ground. I had a camera on the plane so you are getting front row seat on this crash.
Two weeks later I added fiberglass to nose area of plane so I can crash again. I landed plane and slide into crub nose first. I realize i bended motor shaft a week later after I posted this video on You Tube. Once again, front row seat.
ENJOY
wrong thread???
Old Nov 07, 2009, 04:46 PM   #684
share your knowledge
Hi Fellow Siren flyers, I just got a new Siren, and have been reading a lot of your threads about this plane. Since my model is still unassembled, I want to glean as much info as possible about necessary mods and setups. The biggest question I have right now is what to do with the outer wing joiner and the joint itself. My planes AUW will be 3.25 lb. The specs say it should weigh between 3 and 3.5 lbs. As I get used to the Siren’s handling, I’m sure I will push it pretty hard eventually, I want it to be strong enough, and I don’t want any surprises.
I’ve read that if you make the joiner stronger, then the wing itself will break. I think I’d rather have a broken joiner. If I glue the joiner into the wing and the joiner breaks, it will be very difficult to remove the remains. My thinking is that if the joiner fits nice and snug in the wing, it doesn’t need glue. Should I fiberglass the joint itself by removing some covering and gluing a strip there?
I realize this is an entry-level hotliner. I would like to hear some opinions on any and all mods I should definitely do. My TX is a JRX9303, so any input on AIL/EL mixing, SPOILER/EL mixing, differential, dual rates, flight/landing modes that you can share would be great. I’ll be installing an AR6250 Rx, and it looks like the best placement for the antennas is out the rear vent hole behind the wing.
Help me keep her flying.
John
gopherhunter is online now Find More Posts by gopherhunter   Reply With Quote
Old Nov 07, 2009, 05:41 PM   #685
The frigin Catalina wine mixer
flightmare's Avatar
Regardless if the wing brakes or the joiner brakes,your going to crash..
Yes,definately glue the joints as well as the joiners.Use epoxy on them,and you wont have a problem..My wing came apart on a hard landing..I just drilled a 5/16 hole and inserted a fiberglass rod,reepoxied the wing back together,and was back in business.
flightmare is offline Find More Posts by flightmare   Reply With Quote
Old Nov 07, 2009, 07:34 PM   #686
"Regardless if the wing brakes or the joiner brakes,your going to crash.."
I had that picture in mind as I wrote my last post, but there is the possibility of only a fracture prior to a complete failure at the weakest point, and I wondered where that would be with a beefed-up joiner. Flightmare, thanks for the input. You broke a wing on a hard landing, which is my style... any breakage while flying? You said "you won't have a problem". That's definitely encouraging, as I envisioned an inherent flaw in the Siren's wing joint engineering.
Thanks again.
Old Nov 07, 2009, 10:33 PM   #687
flightmare's Avatar
Ya Gopher,
If I remember right the "Stock" wing joiner consists of several pieces you need to laminate together to make the joiner..I used white glue,and clamped them together.Gave it a day to dry..Then I used 30 min epoxy to join the wing thirds.Take your time..
I did one side,and let it cure overnight,then did the other..The thing with epoxy is while it is "Going off",or curing,don't disturb it.
I apply blue painters tape to hold the joint tight while the epoxy sets..
The nice thing about the Siren is you dont have a grip of money tied up in the airframe if it goes in...
As far as the 9303 goes,Thats a good choice for sailplanes..Alot of fuctions for mixing and things like that..
Tons of good info out there too for the 9303..
Andy W did a review of the Siren ,and has some good tips on what to expect with the build...
http://www.rcgroups.com/forums/showt...t=siren+review
Old Nov 08, 2009, 08:02 AM   #688
Andy W's Avatar
This *is* the review thread! We've just got 688 responses to it so far..
As to the wing joiners, build them as the instructions tell you. If you don't glue them in place, it will fail. I used 30min epoxy to assemble the joiners, and (of course) to join the wing panels.
..a
Old Nov 08, 2009, 11:47 AM   #689
Andy thanks.
The excitement is building.
Any and all input is greatly appreciated.
ZOOM
John
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 21 Jun 22, 2008 07:13 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 04:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 02:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 08:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 09:16 PM
Bored? Want to fight?
Join the RCGroups clan!
