Old Jan 13, 2008, 12:26 PM
Liquidity is offline
Find More Posts by Liquidity
YardGoat lives with mama
Joined Feb 2007
Here is my battery setup.
Liquidity is offline Find More Posts by Liquidity
Old Jan 14, 2008, 01:12 AM
Rare Bear is offline
Find More Posts by Rare Bear
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Liquidity - thanks so much! I think I might try (2) Thunder Power 2200mah 25C batteries below - they should fit. Let me know if you think otherwise. Thanks again!
http://www.helidirect.com/product_in...oducts_id=5290
God bless - "Rare"
Rare Bear is offline Find More Posts by Rare Bear
Old Jan 27, 2008, 05:52 PM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Hey, guys; I was hoping someone could help me w/ prop selection for my Siren. I have my power system set, so all I need is prop, spinner and any other items necessary to complete the prop setup - any ideas? I want to go w/ a CAM style prop via Hobby Lobby or something, so if someone can fill in the blanks, I would appreciate it!!
My Motor:
http://www.horizonhobby.com/Product...rodID=EFLM4025A
(2) 2200 25C Batteries
God bless - "Rare"
Old Jan 27, 2008, 06:34 PM
CV580drvr is offline
Find More Posts by CV580drvr
Super Secret Agent
CV580drvr's Avatar
Sink City, USA
Joined Oct 2007
We had a club member who's brand new...maiden flight Siren disintegrated in flight today. Wing just blew apart at speeds within reach of a BoT.
Anybody else seen issues with the spars at the outer wing panel joints?
Just curious. I'm not sure this puts the Siren on my "A" list...
CV
CV580drvr is offline Find More Posts by CV580drvr
Old Jan 27, 2008, 07:02 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Nope. I've hammered mine over and over, and also seen the Great Planes guys put the Siren into dive, followed by a loop tighter than I'd ever risk with any of my composite ships, the wings was bent like a banana - no issues. In fact, they ended up crashing that same model, damaging the fuselage, and using that same wing on a replacement (they came to the event with spares!)..
Originally Posted by Rare Bear
bad link..
..a
Old Jan 27, 2008, 07:08 PM
Super Secret Agent
CV580drvr's Avatar
Sink City, USA
Joined Oct 2007
No biggee....just curious.
Lots of things can conspire to kill a model from the time the box is opened until the maiden flight.
Old Jan 27, 2008, 08:19 PM
rcplanefubar is offline
Find More Posts by rcplanefubar
rcplanefubar's Avatar
St. Paul MN
Joined Jun 2007
Yeah, I wouldn't use anything less then 30 minute epoxy on those joints. Then add a inch and half of covering over it.
rcplanefubar is offline Find More Posts by rcplanefubar
Old Jan 27, 2008, 08:31 PM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
bad link..
..a
Thanks for the heads up, Andy - give this a try. Eflite Power 25
http://www.horizonhobby.com/Products...odID=EFLM4025A
Specs
* Type:Brushless Outrunner
* Size:Replacement for 25-size glow engine
* Bearings or Bushings:Ball Bearings
* Wire Gauge:14
* Recommended Prop Range:11x8 to 14x7
* Voltage:12 - 16.8
* RPM/Volt (Kv):870
* Resistance (Ri):.03 ohms
* Idle Current (Io):2.40A @ 10V
* Continuous Current:32A
* Maximum Burst Current:44A (30 sec)
* Cells:3S-4S Li-Po or 10-14 Ni-MH/Ni-Cd
* Speed Control:40A - 45A Brushless
* Weight:190g (6.7 oz)
* Overall Diameter:35mm (1.40 in)
* Shaft Diameter:5mm (.20 in)
* Overall Length:54mm (2.10 in)
Needed to Complete
40A - 45A Brushless ESC
3S - 4S Li-Po or 10 - 14 Cell Ni-MH/Ni-Cd
11x8 to 14x7 Prop
God bless - "Rare"
Old Jan 27, 2008, 08:51 PM
S_Dave is offline
Find More Posts by S_Dave
Marx and Lennon
S_Dave's Avatar
NW Atlanta
Joined Jan 2007
Extended use report: detachable wings
Andy,
Just wanted to report that I've had a dozen or more flights on my Siren--built with detachable wings--and no problems to date. We built it with end-grain balsa laminated on all 4 sides with carbon fiber instead of the stock spars and glueing. I use a short steel pin to locate the wing pieces at the rear (it's a nail cut off and sharpened to a point--diameter about 3/32). Gentle loops and shallow dives so far, so I haven't TRIED to blow it up. Hope this info is helpful.
Cheers,
Dave
p.s. you're right about spoilerons being better at slowing than flaps, thanks!
S_Dave is offline Find More Posts by S_Dave
Old Jan 27, 2008, 09:10 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
rare,
when you say (2), do you mean 2-cells? That is a 3 or 4 cell motor.
..a
Old Jan 27, 2008, 09:52 PM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
rare,
..a
(2) 2200mah 3S 11.1V Batteries
God bless - "Rare"
Old Feb 03, 2008, 09:25 AM
Jonathanlg is offline
Find More Posts by Jonathanlg
Not enough...
Jönköping, Sweden
Joined Oct 2007
Hey Guys!
Can i fit two 143x45x11mm 2s packs on top of each other?
How much motor/gearbox weight is good for a 200-300g lipo? What setups do you guys got?
Best regards, Jonathan
Jonathanlg is offline Find More Posts by Jonathanlg
Old Feb 03, 2008, 11:44 AM
fwolf15 is offline
Find More Posts by fwolf15
Germany
Joined Jan 2007
Originally Posted by Jonathanlg
Hey Guys!
I think the width (45mm) is very close to the maximum... I will do a measurement this evening and than I know more about the maximum width.
Edit: Here is the result: the the maximum open space is 40mm, so I think is not very comfortable to insert the two packs, the maximum space between the preinstalled wood (for the battery) and the uper edge of the fuselage is 26mm, so the height would not be the problem, but the width.
About the second question: It depends also of the length from your motor/gearbox combo, because if its too long, you can't shift the battery so much forward as required.
I think it should be between 250 and 280g, but as I say, it depends of the maximum space you have left between end of motor/gear combo and the cg.
I use a outrunner without gear with about 160g, an external RX battery plus more than 100g lead. I use a 3s2200mah battery, so you see its better to have a bigger motor/gear combo, so you need not so much additional dead weight to reach the CG.
rgds
Wolfgang
fwolf15 is offline Find More Posts by fwolf15
Old Feb 04, 2008, 11:24 AM
Not enough...
Jönköping, Sweden
Joined Oct 2007
Thanks for your reply Wolfgang
I have now puchaset a Feigao LX 380 motor with gearbox with weight about 270grams
I think i will go for a 4cell pack with a weight of about 250grams
I hope the motormount wont get angry att my 800watt setup:S
Old Feb 09, 2008, 07:58 AM
vitek0206 is offline
Find More Posts by vitek0206
Joined May 2007
Hello Guys,
can i make in my new ,,SIREN'' ,wings with three separate parts,cause 2 m. too long even for transport,and storage,it is possible?
rgds
witek
vitek0206 is offline Find More Posts by vitek0206
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 03:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 04:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 02:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 08:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 09:16 PM
