| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#16 |
The Siren doesn't use or need any aileron differential. If you read the thread from the beginning - part 1 http://www.rcgroups.com/forums/showthread.php?t=281738 and this being part 2 http://www.rcgroups.com/forums/showthread.php?t=330518 - a person or two started out trying it but quickly changed back to no differential. It is stated in the plans / instructions that none is needed.
#17 |
That sickening crunch..
None is needed, but it does seem to benefit from it if you have the capability. I started at 50% and haven't found a need to change it.
..a |
#18 |
servo attachment
good review, and I will refer to it during the building of my Siren which I received only yesterday. On the elevator servo, I likely will use the method of servo attachment recommended by this review as this is my first carbon fiber fuselage. However I am not surprised by the failure of epoxy, as it is brittle and the carbon fiber or fiberglass is more flexable. I would more likely use a silicone adhesive such as Permatex Clear RTV Silicone adhesive sealant. It is the same thing as GE Clearseal.. I have used these with good sucess in fibergalss fuselages as well as wood. You do not want these products to come into contact with the electronics due to corrosive nature of the solvent, but I have had no trouble with the solvents penetrating the servo case. This method really helps in models with limited room for servo mounting. The material can be cut loose from the servo when needed, and retains its rubbery consistency, making for some shock /vibration protection.
#19 |
I've used silicone myself, but had it come loose. I usually use GOOP for securing servos..
..a |
#20 |
Has anyone ran the airplane in stock form with a brushed motor? All my airplanes are brushless but this will be my first hotliner. I just want to make sure its somthing i want to invest alot of cash into and these motor esc and battery packages are not cheap for this model. Has anyone ran it with a brushed t-610 motor and how was the preformance?
#21 |
There is information in the other threads on the signal. Arbo had a signal and flew it with a brushed motor. Performance was acceptable to him. It would not acceptable to me... Its worth getting a brushless setup for this plane.
#22 |
curmudgeon in training
Yes, I flew one on brushed power. Not the GP setup, but a Kyosoho Magnetic Mayhem. On 7 old 1700mah NiCads. It flew fine. No speed demon, but I'm not sure even a big brushless system would make it a speed demon. I could climb up and thermal around a bit. But as noted by some, the plane just doesn't have the energy retention you'd expect.
The most impressive flying I ever saw it do was on our local slope. With 40+ MPH winds and loads of slope lift, it got in it's groove. |
#23 |
Servo arm question for Siren.
I got my Siren kit back when they first came out early this year. Well after moving half way across the country and getting married, i'm ready to get it flying. I orginaly got it because I wanted a powered glider that I could go fly on the front range of colorado. that would be eaiser just to go fly compaired to getting all my heli crap together.
So now I'm back to the sticky point that i was at eirler this year with the servos. I got some Futaba S3108 microservos (suggested by tower hobbies) Well the damn servo horns are so small that I cant put the linkage rod through them. I havent been able to find some larger servo horns. So what should i do? Just glue some larger pieces of plastic on the existing horn so i can drill a hole that will accept the rod. I just have a brushed motor so I'll get some video of a brushed motor when I get it in the air. Britt |
#24 |
I would not mess around with the servo arms.. I'd get some larger servos - you're not going to notice the weight..
I didn't see 3108's suggested on Tower's site? ..a |
#25 |
looks like the say the 3107 now (maybe did then too) but the 3108 are identical (except for th horn maby?)
3107 http://www2.towerhobbies.com/cgi-bin...?&I=LXDTB5&P=M 3108 http://www2.towerhobbies.com/cgi-bin...?&I=LXFKZ9&P=0 Humm... what to do, what to do? |
#26 |
I noticed the 3107's are in the manual, so you can't be blamed for going with them. Haven't used them myself, so I can't comment on the size of the horns, but perhaps comparing to pics in the manual might help?
The 56's I used for aileron have larger horns than most micro servos, and they worked out well - you can see the size of the horns and that there was ample material for the large hole needed to accomodate the provided pushrod in the pictures in the review. You have to be careful how you set them up, it's a little tricky to get the full range of aileron throw needed for spoileron operation. A 55 was used in the tail, didn't have any issue there.. ..a |
#27 | ||
Feedback from a reader here (received by email)..
#28 |
siren cg
forgive me if this shows up twice. I am having trouble with the cg. I flew at the recommended cg and had to give a lot of up trim. I have now moved the cg back to within 1/16 of its limit and still have to give some up trim.
Should I keep moving it back, even if its beyound the recommended cg? It flys very well and lands great, with air brakes. I just don't understrand why I have to move the cg so far back. Is it normal to have to give up trim? I have flown it upside down and the nose fall there too. Thanks for your time. Sanford, ccrc |
#29 |
Sounds more like an incidence problem?
..a |
#30 | |
Remember that the CG is incorrect in the manual... Sanman, Slide the CG back until you can fly without uptrim in the model, it will reward you with a pretty decent flight. Jay |
| Thread Tools | |
| Article Great Planes Wright Flyer ARF Review | Michael Heer | Parkflyers | 21 | Jun 22, 2008 07:13 PM |
| Sold Great Planes Siren Hotliner ARF | Steve H. | Aircraft - Sailplanes (FS/W) | 1 | Sep 13, 2006 04:28 AM |
| Sold Great Planes Siren Hotliner Sailplane | glide | Aircraft - Sailplanes (FS/W) | 6 | Oct 08, 2005 02:20 AM |
| Sold Great Planes Siren Hotliner EP ARF 79" (NIB) | trw43 | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 03, 2005 08:20 PM |
| Great planes siren?? Hotliner or warmliner? | argarre | Electric Sailplanes | 3 | Sep 01, 2004 09:16 PM |
