Hey, guys - one quick question. My Siren is showing up this Friday, and I could use a little info. I just picked up a sweet DX7 Tx, and I plan on using the AR6100 Rx - will I have any issues with this Rx due to the carbon fiber fuselage?
One other thing; I plan on using the below power system with (2) 2100mah 20C batteries - any ideas on prop size? Thanks so much!! http://www.horizonhobby.com/Products...odID=EFLM4025A God bless -"Rare" |
God bless - "Rare" |
Germany
Joined Jan 2007
I use the Hs81MG for the ailerons, I think they fit very well, best in combination with the servorahmen (see my post from Dec 11, 2007 ) I also use a DX7, but with a AR 7000RX, I've also drilled two pinholes in the fuselage, the external smaller receiver I've installed outside the fuselage behind the mounting screw for the wing. In the moment I have to repair my wing, two weeks ago there was a harder rough landing on the frozen ground, so the the right part of the wing was broken off at the junction between the outer and middle wing So I have to peel off the cover and do some laminating with epoxy resin. Wolfgang |
Joined Feb 2007
I was going to use an AR6100, but my buddy changed my mine. I am glad he did. For how fast mine climbs out of sight, I would rather have the added security of the AR7000.
I have never tried it on the 6100, so I can not give you a concrete answer. TO make me feel secure, the AR7000 is the way to go. I have never tried the Power 25 motor. Let us now how that works for you. |
Thanks for the answer, Liquidity - appreciate it. What about a standard 72mhz system? I'm using an HDX Dual Conversion Rx on my Easy Glider w/ great results - not a glitch, and I've had it up higher than I cared for. The only reason I thought the 2.4ghz would be better was because of the carbon, but if I can string out an antenna out the back w/out issue, I'll go for another HDX Rx. What do you think? God bless - "Rare" |
Bummer abut the crash, Wolf - no fun there. I just received my Siren today, and I'll keep the HS-81's in mind. Any advantage over the HS-65's in the ailerons? As for the tail servo, the review early on said epoxy wouldn't hold -how about hot glue? Ideas? Thanks! God bless - "Rare" |
use goop |
I really like hot glue for glueing the servos. It really holds great, have never had one come loose. Another benefit is that they can be removed much easier ( than goop ) at a later date if need be.
Bill Davenport AMA 28141 |
Latest blog entry: Disclaimer For All Purchases From...
Just a thought; what about running (2) 1850mah 20C 7.4V 2S batteries in series with my Eflite Power 25 870Kv motor? I just received my Siren today - what a beauty! - and I noticed how tight the fuselage is when it comes to batteries. I did a quick test fit, and it looks like I can easily get away with (2) of these 2S batteries stacked on top of each other. Amp wise, I'm within limits, and I know of another in this thread running a 1100Kv motor on 3S, so r.p.m.'s are within limits as well. My only worry is flight time with my batteries - 1850mah isn't much, so I'm not sure. If I can, I would like to avoid cutting the wood supports in the fuselage, so if anyone can validate my idea, I would truly appreciate it.
Any hints at flight time? I imagine w/ the power I'll have, I won't be on the throttle much! Thanks so much, guys - heli's are my profession, so these gliders are all new to me! ![]() Battery http://www.helidirect.com/product_in...oducts_id=4370 Motor http://www.horizonhobby.com/Products...odID=EFLM4025A God bless - "Rare" |
Germany
Joined Jan 2007
about the battery "discussion": I thought to use A123 cells in the future or maybe try a 4S Lipo with 3500mAh, 20C, so like the ebay item part 160191900200, but I'm not sure, bcause its titled as no brand... ok, its not too expensive but is it really worth ? I think the size and weight ( 135mm X 41mm X 32mm, 388gramm) should be ok. Wolfgang |
![]() Hey; where can I find props, hubs and spinners for this glider? I purchased my prop, hub and spinner for my Cularis at Hobby Lobby, but I'm not sure about size & application. Any ideas? Thanks and God bless - "Rare" |
| Thread Tools | |
| Article Great Planes Wright Flyer ARF Review | Michael Heer | Parkflyers | 22 | Feb 15, 2010 02:42 PM |
| Sold Great Planes Siren Hotliner ARF | Steve H. | Aircraft - Sailplanes (FS/W) | 1 | Sep 13, 2006 03:28 AM |
| Sold Great Planes Siren Hotliner Sailplane | glide | Aircraft - Sailplanes (FS/W) | 6 | Oct 08, 2005 01:20 AM |
| Sold Great Planes Siren Hotliner EP ARF 79" (NIB) | trw43 | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 03, 2005 07:20 PM |
| Great planes siren?? Hotliner or warmliner? | argarre | Electric Sailplanes | 3 | Sep 01, 2004 08:16 PM |
