Old Nov 25, 2007, 02:51 PM
badbill is online now
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Originally Posted by Vantasstic
1.5 hours...with no rudder...Show Off!!!
It wasn't hard at all, think about it- It will climb straight up to almost out of sight in about 5-6 seconds or so. And w/ the two 2200's, you can get a BUNCH of climbs! Not to mention the fact that even without a rudder, the plane really thermals well.
Bill Davenport
AMA 28141
badbill is online now Find More Posts by badbill
Old Nov 25, 2007, 03:09 PM
wpnguy is offline
Find More Posts by wpnguy
wpnguy's Avatar
lakeridge VA.
Joined Jan 2005
Rare,
not many options in the build. The tail end has alot of CF and resin with a bolt on Horixontal tail. Elevator servo is mounted in the tail. I used an HS 56 servo. mostly for the side mounting lugs and since this was my fisrt hotliner, I liked the carbonite gears. it may be a bit of an overkill. Also, if you are shaving off grams, the pushrod could be a bit lighter and nylon bolts cut down a bit. but those changes really would not have helped my situation.
I found that a 35mm diameter outrunner will fit in the nose. I am not familiar with the eflite 15, but there is not much space along the sides of the motor.
There is more volume along the belly of the plane so mount the motor so the wires are pointing downward.
The plane has a light ply structure in the center of the fuse, it stiffens the fuse, but you will probably want to cut out part of it if you want to stick with a single battery pack, so you can slide it as far forward as possible. Everything forward of the wing is solid, no access hatches, so it can get a bit challenging trying to work in the front of the plane.
Badbill's time is about what I am seeing, But I only get about 2 hours at a time for flying so I usually have to land for other things besides battery time. I tend to like to climb up, power off, search around for lift and do a high speed dive, with some mild acrobatics, then blast back up again to a different part of the sky. I haven't tried continuous power on flight through a whole pack yet. With my battery set up, I am only pulling an 8-9C load at full power. If I understand the math, that should be about 7-8 minutes of full power and it only takes a few seconds to get to altitude so there is alot of climbs in that set up.
wpnguy is offline Find More Posts by wpnguy
Old Nov 25, 2007, 03:41 PM
fwolf15 is offline
Find More Posts by fwolf15
Germany
Joined Jan 2007
I've got the same problems with the too light outrunner (and the problems to reach the correct cg), so I put about 120g of lead in the front oft the plane, but this was not enough, so I spent the plane also a seperate 5 cell RX battery, this means the added weight is not really dead weight.
My flight battery is a 3S 2200mah lipo battery.
Wolfgang
fwolf15 is offline Find More Posts by fwolf15
Old Nov 25, 2007, 04:22 PM
S_Dave is offline
Find More Posts by S_Dave
Marx and Lennon
S_Dave's Avatar
NW Atlanta
Joined Jan 2007
All-up weight?
wpnguy,
Thanks for the interesting material you and the others are sharing about the Siren. I'm getting acquainted with my new Siren slowly--using brushed motor and NiMH batteries. Do you know how much your Siren weighs with the brushless and Li-Po set up you have? Thanks again and I hope all you guys enjoyed a Happy Thanksgiving.
Cheers,
Dave in Atlanta
"Georgia 31- Georgia Tech...xC$3zzSt...you're breaking up!"
S_Dave is offline Find More Posts by S_Dave
Old Nov 25, 2007, 05:26 PM
Rare Bear is online now
Find More Posts by Rare Bear
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Originally Posted by wpnguy
Rare,
Thanks so much, wpnguy - you've been incredibly helpful. 35mm will fit, huh? The Eflite 15 should fit then, but will it be a miserable nightmare to install? From the way things sound, (2) 2100mah batts should work well - I'm liking the idea of extra flight time, so the weight doesn't bother me. I have a Multiplex Easy Glider and a Cularis on the way, so those will be my thermal birds - I'm just looking for something a bit "hotter" and playful, and the Siren is really sounding good. Check the below specs and let me know what you think - would really appreciate your insight!!
Thanks and God bless - "Rare"
Eflite Power 15 Specs:
* Type:Brushless Outrunner Motor
* Size:15-size
* Bearings or Bushings:Ball Bearings
* Wire Gauge:16
* Recommended Prop Range:10x613x6.5
* Voltage:7.4 - 14.4V
* RPM/Volt (Kv):950
* Resistance (Ri):.03 ohms
* Idle Current (Io):2.00A @10V
* Continuous Current:34A
* Maximum Burst Current:42A (15 sec)
* Cells:812 Ni-MH/Ni-Cd or 3-4S Li-Po
* Speed Control:40-45A Brushless
* Weight:152g (5.4 oz)
* Overall Diameter:35mm (1.40 in)
* Shaft Diameter:5mm (.20 in)
* Overall Length:50mm (1.90 in)
Needed to Complete
40A - 45A Brushless ESC
8-12 Cells Ni-MH/Ni-Cd or 3-4S Li-Po
10x6 to 13x6.5 Electric Prop
http://www.horizonhobby.com/Products...odID=EFLM4015A
Rare Bear is online now Find More Posts by Rare Bear
Old Nov 25, 2007, 05:30 PM
John O'Sullivan is offline
Find More Posts by John O'Sullivan
John O'Sullivan's Avatar
Nova Scotia Canada
Joined Jan 2004
I've been using AXI 2826/12 with Graupner 14x9.5 folder on 4 cell 2100, 30 C Lipoly on a 100" RCM Northeast sailplanes Pike electric (not the high tech Moulded Pike).
53 amps without overheating and typical flights without thermals of over an hour.
Typical climbs are 10 seconds to 400 Ft plus (estimated 2400 ft/ min) Checked climb rates on 3S 2p 2100 was 1850 ft / min, but my LoLo logger has gone bust so I can't give precise figures for the 4s.
John O'Sullivan
John O'Sullivan is offline Find More Posts by John O'Sullivan
Old Nov 25, 2007, 08:40 PM
wpnguy is offline
wpnguy's Avatar
lakeridge VA.
Joined Jan 2005
Rare.
The power 15 should fit just fine. The extra weight of the motor will help with the CG as well. One note with the Eflite motors, you will have to follow the instructions that come with the motor to reverse the shaft, it is an easy process, should be no problem.
Dave,
if my scales are accurate, my Siren with a Eflite 10 and 2 3s 2100 lipos is around 43 1/2 oz
Old Nov 25, 2007, 10:25 PM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Rare.
Dave,
Thanks so much, wpnguy - you've really been helpful. I think I'll opt for the Eflite Power 15 when I go the Siren route - just wish I would have known that before I picked up my Eratix 3D plane; should be a blast, but the Siren sounds better!
I'll probably be harassing everyone here with more questions when I pick up a Siren in a bit, but for now, I'm glad to hear an outrunner will work. Thanks so much for the info!
God bless - "Rare"
Old Nov 26, 2007, 01:07 AM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
One last, quick question - for now, at least!
Overkill???
Eflite Power 25
* Size:Replacement for 25-size glow engine
* Wire Gauge:14
* Recommended Prop Range:11x8 to 14x7
* Voltage:12 - 16.8
* RPM/Volt (Kv):870
* Idle Current (Io):2.40A @ 10V
* Continuous Current:32A
* Maximum Burst Current:44A (30 sec)
* Cells:3S-4S Li-Po or 10-14 Ni-MH/Ni-Cd
* Speed Control:40A - 45A Brushless
* Weight:190g (6.7 oz)
* Overall Length:54mm (2.10 in)
Needed to Complete
3S - 4S Li-Po or 10 - 14 Cell Ni-MH/Ni-Cd
11x8 to 14x7 Prop
Old Nov 26, 2007, 01:43 AM
panzerd18 is offline
Find More Posts by panzerd18
panzerd18's Avatar
Melbourne, Australia
Joined Dec 2005
What size spinner did everyone use? Some say a 38mm is too small and a 40mm too big?
I found a MPJET 40mm spinner would that look bad?
panzerd18 is offline Find More Posts by panzerd18
Old Nov 26, 2007, 04:21 PM
sparrow1717 is offline
Find More Posts by sparrow1717
WOOOOsssSSSShhHH !!
sparrow1717's Avatar
Long Island , NY
Joined May 2003
Hxt 35-48A
Whats the feedback on these AXi2826 clones for Siren usage: http://www.hobbycity.com/hobbycity/s...idProduct=4910
Spar
sparrow1717 is offline Find More Posts by sparrow1717
Old Nov 26, 2007, 07:44 PM
wpnguy is offline
wpnguy's Avatar
lakeridge VA.
Joined Jan 2005
rare,
the early parts of this thread say the airframe is rated for 500 watts. The 25 still looks to be below that limit. So it should be no problem.
If you follow the hotliner discussions in the high performance electrics section, they generally think more power = more fun... right up until you rip the wings off
My 40mm spinner is just a hair larger than the fuse. but you have to look real close to notice
Old Nov 26, 2007, 10:43 PM
rcplanefubar is offline
Find More Posts by rcplanefubar
rcplanefubar's Avatar
St. Paul MN
Joined Jun 2007
I'll be getting one of these for mine for one I think they look cool and second to help keep the motor,ESC,and battery temp under control.
rcplanefubar is offline Find More Posts by rcplanefubar
Old Nov 26, 2007, 11:44 PM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
rare,
Thanks, wpnguy - if I go the power route, I'll try and keep the G's within limits!
God bless - "Rare"
Old Nov 27, 2007, 12:17 AM
panzerd18's Avatar
Joined Dec 2005
That 40mm looks great!
Would a 205 gram (7.3 oz) motor be good for balancing?
Are you guys running with a three cell or four cell lipo?
Also if I buy a 4200mah 3S lipo would it fit in the battery compartment or is it really cramped? What was the largest battery size you fitted and is it better to go for a lower mah battery to keep the weight down?
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
