Old Oct 31, 2007, 09:35 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
I would go 65s all around (hs81s definitely work as that's what I used)
Axi 2826/10 w/ 13x7 gives vertical performance.
soholingo is offline Find More Posts by soholingo
Old Oct 31, 2007, 09:54 AM
ROV Pilot
jijohans's Avatar
Norway
Joined May 2002
Ok..
But what FP pack? The Evo 30 3s 3200 is 152mm x 48mm x 20mm.
jijohans is offline Find More Posts by jijohans
Old Oct 31, 2007, 10:33 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
That will fit, but it might be a tight squeeze unless you remove the tray. Try it and see. I am more concerned that you may not get it to balance..
..a
Old Oct 31, 2007, 10:42 AM
Not enough...
Jönköping, Sweden
Joined Oct 2007
Hey guys! New to Rc-groups, loving it! I went and ot myself a Siren and probaably got for this setup:
Feigao 380XL 8T Kv: 2900ish
4:4:1 Planet Gearbox
Polyquest 3S 4500mah 30-50C
OEMRC Pentium 80A
Hitec HS 81´s
14X10 Cam naybee?
Weight of setup will land aroud 800grams/29 oz. To much?
Anybody have problems with the Carbon fuse disturbing the reicever/transmitter signals?
/Jonathan auf sweden
Jonathanlg is offline Find More Posts by Jonathanlg
Old Oct 31, 2007, 12:55 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I run my antenna outside the fuse..
..a
Old Nov 02, 2007, 06:13 AM
Germany
Joined Jan 2007
Originally Posted by jijohans
Jusy ordered a Siren from Tower..
Have read some threads about it and have some quick questions:
Will the FP evo 30 3S3200 pack fit?
Will Hs 85bb servos fit in the tail and wing? Or should I go for Hs65's
Thinking about using a Axi 2826/10 with a CFK 13 x 7" prop, will this give vertical performance?
Best starting point for CG?
Hello,
I use a AXI clone from UH with a Aeronaut 13x7, its very strange to mount the axi that the wires are not "rubbed" from the motor. I use two HS81MG in the wings, and a smaller one in the tail, the HS 81 is too big (also too heavy) in the tail, if you want to use it in the tail, you must cut off a lot of the carbon around the mounting hole.
The problem is for every more weight in the tail, you need a lot of more in the nose to compensate. I use a 3s lipo with 2250mah, the weight is about 170gramm, to reach the CG I've insert about 170gramm lead plus a external 5 cell receiver battery with 105 gramm.
The vertical performance ends about 30meters, so I want to try some different props next time. The speed is ok for me at the moment.
Perhaps I try 3 or 4 A123 cells in the future.
rgds
Wolfgang
fwolf15 is offline Find More Posts by fwolf15
Old Nov 02, 2007, 09:39 PM
Marx and Lennon
S_Dave's Avatar
NW Atlanta
Joined Jan 2007
Hello Andy,
Finally flew my Siren and it did well with the 7-cell NiMH 2200's you gave me at the CCRC swap meet. Not vertical of course, but flew nicely and for a good while. You guys are all right about the Siren floating indefinitely in ground effect. Got to enable the flaperons next time--or course, the exercise is healthy, walking a half-mile to retrieve the plane...
Cheers,
Dave
S_Dave is offline Find More Posts by S_Dave
Old Nov 03, 2007, 06:57 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Glad it worked well for you! Remember it's spoilerons, not flaperons (ailerons up)..
..a
Old Nov 03, 2007, 07:04 AM
ROV Pilot
jijohans's Avatar
Norway
Joined May 2002
What is the best starting point for CG? Some say 60mm, others 65 and others again 3", don't know what to belive..
Old Nov 03, 2007, 07:40 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I know the recommended CG is off, I believe 60-65 is correct but I can't find where I posted it..
..a
Old Nov 03, 2007, 08:33 PM
Marx and Lennon
S_Dave's Avatar
NW Atlanta
Joined Jan 2007
Spoilerons and elevator mixing amount?
Andy,
Flew the "Siren" this afternoon (beautiful day) and flipped in spoilerons at 200' and wow! did it pitch down!
Do you have a baseline recommendation about how much up elevator to mix in when you activate spoilerons? Thanks!
Dave
Old Nov 04, 2007, 06:19 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
No, but you can start with a couple of mm and then test it up high with your Tx in programming mode so you can adjust it in-flight (it's best to have a helper.)
It sounds, however, that you're using a switch for spoilerons, which implies you've still got throttle on the left stick. If this is the case, I strongly recommend that you move the throttle to a switch - preferably a spring-loaded toggle or button - and use glider programming to have spoilerons on the left stick, so they can be dialed in gradually..
..a
Old Nov 07, 2007, 02:39 PM
Marx and Lennon
S_Dave's Avatar
NW Atlanta
Joined Jan 2007
Great suggestion, Andy, thanks!
Dave
Old Nov 08, 2007, 12:07 PM
rcplanefubar's Avatar
St. Paul MN
Joined Jun 2007
Can anyone tell me if this would be a good combo?
Great Planes Silver Series 45A Brushless ESC 5V/2A BEC
Great Planes Rimfire 35-48-1000 Out-Runner Brushless
FlightPower LiPo 11.1V 1500mAh 25C EVO25 3S Balance
( X2 Parallel ) (so I can use them in my other planes )
Hitec HS-65HB Micro Servos
Also has anyone tried using a 2.4 radio in one of these yet ?
And I forgot. If this is a good combo what would be a good prop size for it. Thanks
rcplanefubar is offline Find More Posts by rcplanefubar
Old Nov 08, 2007, 04:23 PM
AMA - 734492
EricClark's Avatar
United States, MT, Butte
Joined Mar 2007
I converted mine to a sloper and use 2.4 technology.
EricClark is offline Find More Posts by EricClark
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
