Old Feb 06, 2007, 08:50 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Originally Posted by flyboyrvk
I sent the following question to this thread but have not yet heard a response from anyone. Is anyone out there using the AXI 2826/8 and what prop with 10cell NiMh?
"I have a Siren running an AXI 2826/8. I had been using a Aeronaught 13X8 folder with a Jeti 70A ESC on an 8cell Electrifly pack. I just changed batteries to a 10cell, 2000mah pack. The AXI literature reccomends a 12X8 prop for the 10cell pack. Will I be risking damage running the 13X8 prop? I seems to run fine on the ground with short throttle bursts, but I did not want to risk longer runs. Any suggestions would be appreciated."
Thanks, R
its fine
soholingo is offline Find More Posts by soholingo
Old Feb 07, 2007, 05:26 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I don't have an AXI. Outrunners are not as common in hotliner applications as regular geared motors, so probably fewer people can comment.
..a
Old Feb 08, 2007, 09:42 PM
flying evader is offline
Find More Posts by flying evader
Back in the game
flying evader's Avatar
United States, TX, Frisco
Joined May 2006
I'm guessing you can, fly it for a couple of minutes then bring it down and touch the motor..
i'm flying that same setup but with 3s
flying evader is offline Find More Posts by flying evader
Old Feb 08, 2007, 09:43 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
3s has more voltage than 10 cell, so he is fine...
Old Feb 09, 2007, 06:16 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Soho - the best voltage I get out of 3s is 12.6v, and I routinely see 14.8-15v from my 10 cells... 2/3a and sub c packs.
Not picking a fight -
JimNM
JimNM is offline Find More Posts by JimNM
Old Feb 09, 2007, 07:03 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
That's charged voltage, Jim, not voltage under load. Depending on the cells (both LiPo and NiMH), I can get more voltage from 3s or 10 NiMh's - i.e. hot GP2200's will deliver more voltage than 3s 2100 LiPo at 50A.
..a
Old Feb 09, 2007, 08:15 AM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
what Andy said...
I should have quaiified what I said, but I am getting lazy in my old age...
Old Feb 09, 2007, 09:15 AM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
Yep - posting before 5:00 a.m. is not a good idea - I should have considered the "under load" disclaimer as I'm sure Soho intended.
JimNM
Old Feb 09, 2007, 04:30 PM
flyboyrvk is offline
Find More Posts by flyboyrvk
flyboyrvk's Avatar
Charlotte
Joined Jan 2006
Thanks for the help, guys - I'll fly it with the 13X8 blades and just check the motor temp to be safe. I am not flying continous throttle anyway. The controller should handle it fine as it is rated for 70A. I also have a set of 11X8 which I may try for curiousity.
flyboyrvk is offline Find More Posts by flyboyrvk
Old Feb 20, 2007, 07:33 PM
sparrow1717 is offline
Find More Posts by sparrow1717
WOOOOsssSSSShhHH !!
sparrow1717's Avatar
Long Island , NY
Joined May 2003
Siren servos
what servos have you fellas used with your siren? Would a HS55 be enough? Or should get something more beefier?
Spar
sparrow1717 is offline Find More Posts by sparrow1717
Old Feb 20, 2007, 09:15 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I've read some have used HS-55s, but I think something beefier would be better. I used HS-81s on mine. The HS56 or 65 would also be a good choice, but more expensive than the 81s I think. Remember, the Siren is a warmliner...made to climb and do hi-speed passes. The faster you go the more aerodynamic load on the servo...that' be a bad time for a servo to stall/strip now wouldn't it...
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 20, 2007, 09:22 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
IN keeping with the inexpensive nature of the plane I would use hs81s... they fit, and they work.
Old Feb 21, 2007, 05:36 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I used 56's on the ailerons, and a 55 on the tail. I'd probably use 56's all around if I did it again, although I've had no problem with the 55 in there now..
..a
Old Mar 16, 2007, 02:08 PM
pletang is offline
Find More Posts by pletang
How fast can you crash it.
pletang's Avatar
Canada, QC, Gatineau
Joined Sep 2005
Got my Siren yesterday. Setup Axi 2820/12, esc 40A Eflite for now, 3 HS-81, lipo Flightpower 3S 2500. Is the cg at 70mm ok.
pletang is offline Find More Posts by pletang
Old Apr 11, 2007, 07:57 AM
Cockar is offline
Find More Posts by Cockar
Joined Feb 2007
Hi Guys, new to the site and just bought my first hotliner.....The Siren. Is there any advice on how best to thread the servo extension leads through the wing . I know there is a piece of string already threaded through centre wing ribs, but what is the easiest way to attach the string and thread the leads as the openings in the ribs are quite narrow.
Thx in advance for your replies.
Cockar is offline Find More Posts by Cockar
Article Great Planes Wright Flyer ARF Review Michael Heer Parkflyers 22 Feb 15, 2010 02:42 PM
Sold Great Planes Siren Hotliner ARF Steve H. Aircraft - Sailplanes (FS/W) 1 Sep 13, 2006 03:28 AM
Sold Great Planes Siren Hotliner Sailplane glide Aircraft - Sailplanes (FS/W) 6 Oct 08, 2005 01:20 AM
Sold Great Planes Siren Hotliner EP ARF 79" (NIB) trw43 Aircraft - Electric - Airplanes (FS/W) 1 Oct 03, 2005 07:20 PM
Great planes siren?? Hotliner or warmliner? argarre Electric Sailplanes 3 Sep 01, 2004 08:16 PM
