Old Apr 05, 2005, 11:50 PM
Blackhawk3D is offline
Find More Posts by Blackhawk3D
Dreamin' in 3D
Blackhawk3D's Avatar
Lodi/San Luis Obispo
Joined Oct 2003
Full Fuse Foamy Plans
Does anyone have plans for a full fuse foamy? I have 3 an 6mm depron and want to make a full fuse plane, they look so much cooler (and the extra stiffness is awesome). I like the yaks I've seen on here, but I couldn't find any plans for them. I saw some extras too but no luck on plans.
Nathan
Blackhawk3D is offline Find More Posts by Blackhawk3D
Old Apr 06, 2005, 12:01 AM
j_z_123 is offline
Find More Posts by j_z_123
BOSS
j_z_123's Avatar
New Jersey (excl EWR), United States
Joined Apr 2002
My Yak flys amazing. No coupling, fast roll rate, balanced perfectly, it'll do it all
It was based off the Yak Shock Flyer. I have templates, but don't have a scanner to get them onto the computer
You can also use the FoamyFactory plans, and make it into a full fuse kit...
Jon
j_z_123 is offline Find More Posts by j_z_123
Old Apr 06, 2005, 12:03 AM
Dreamin' in 3D
Joined Oct 2003
Could you post pics of how you did the fuse? I could figure it out if you did. That is exactly what I want, just a little bit bigger.
Old Apr 06, 2005, 12:04 AM
Dreamin' in 3D
Joined Oct 2003
I mean pics of the fuse inside, not all the way put together. How it is braced.
Old Apr 06, 2005, 12:07 AM
j_z_123 is offline
BOSS
j_z_123's Avatar
Joined Apr 2002
I don't have any... Sorry. I maybe be able to take a few pics looking in from the nose..
There is two fuselage sides, with one 3mm spar all the way down through the middle. Then the outside (around the canopy, battery hatch, etc.) depron is glued together. Really easy to make, they fly AMAZING, and they look great!
The pics will have to wait to tomorrow, going to bed!
Jon
Old Apr 06, 2005, 09:10 AM
Dreamin' in 3D
Joined Oct 2003
bump. Anyone else? I have seen numerous people building this style of foamy on this board. How do you brace the fuse inside?
Old Apr 06, 2005, 09:17 AM
airmcn_3 is offline
Find More Posts by airmcn_3
Moore, Oklahoma
Buddy, its actually pretty easy. if you want a boxy fuse then just cut out some rectangles that fit the profile. you will only need 3-4 of them and a fire wall. at the vertical stab the two sides of the depron should touch so you can attach a rudder. You can also run one top peice and one bottom peice to close in the box. with a couple bulkheads and the top and bottom it will require no carbon rod in the fuse. I hope this helps. Take Care Chris
airmcn_3 is offline Find More Posts by airmcn_3
Old Apr 06, 2005, 09:23 AM
Dreamin' in 3D
Joined Oct 2003
So one long piece running down the whole fuse tied into each set of "bulkheads", and just pieces of depron cut out to match the profile? How far apart should these pieces be?
Old Apr 06, 2005, 09:28 AM
airmcn_3 is offline
Moore, Oklahoma
if you make them around 1.5" the full fuse width should be around 1.9" thick so esentially at the firewall, make the full fuse width 2" and then slowly taper back.
Old Apr 06, 2005, 10:48 AM
Da V. is offline
Find More Posts by Da V.
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
Hi Jon,
It looks really good. What is the weight of your plane without any electonic components.
Da V.
Komodo Hobby
www.komodohobby.com
Da V. is offline Find More Posts by Da V.
Old Apr 06, 2005, 11:12 AM
Dreamin' in 3D
Joined Oct 2003
How many? How far apart? If I could just see a pic of one without the second fuse side on I could do it much easier.
Old Apr 06, 2005, 11:28 AM
airmcn_3 is offline
Moore, Oklahoma
well I guess I could build one tonight and take pics for you. but as I said it will not be until tomarrow that you will see it. you only need about 4 bulkheads say 3-5 inches apart. as the tail comes together its will not need one there.
Old Apr 06, 2005, 11:31 AM
milky2971 is offline
Find More Posts by milky2971
FLY PEMBREY (PFC)
milky2971's Avatar
Wales (UK)
Joined Aug 2004
These should give you the kind of idea
Id cut away the center of the bulkheads if doing it again also would make the sides out of 3mm and bulkheads out of 6 dont use any more bracing than you have to keep it as light as possible
Trev
milky2971 is offline Find More Posts by milky2971
Old Apr 06, 2005, 11:32 AM
Dreamin' in 3D
Joined Oct 2003
Okay, I want to build one around 32-38" span though. I'm thinking I can do it now. Anyway, another question, what is better, this style or like the Quiques now one? Where the top is pinched together.
Also, should the center full lenght spar be 6mm or 3mm? I was thinking 6mm for the spar, and 3mm for the skin and bulkheads.
Old Apr 06, 2005, 11:36 AM
airmcn_3 is offline
Moore, Oklahoma
As stated if he was to do it agian it would be all 3mm. you do not need to go crazy with the strenght. no matter what it will be stronger then flat. I would stick with the box fuse it is much stronger! Try to keep it as light as possible so all 3mm and where you see the wood sticks, replace that with 6mmx6mm peice of depron. Good luck. Take Care Chris
The Flash - Full fuse foamy j_z_123 3D Flying 395 May 11, 2007 10:18 PM
Discussion Free full fuse foamy plans!!! rc4metoo Foamies (Scratchbuilt) 5 Jan 30, 2007 07:56 PM
The Flash - Full Fuse Foamy! j_z_123 Bergen County Silent Fliers 2 Oct 25, 2005 12:22 AM
YAFFF - Yet ANOTHER Full-fuse Foamy theKAT 3D Flying 22 May 11, 2005 04:05 PM
Anomaly 3d - Room for 1 more full fuse foamy?! ryanl2006 3D Flying 54 Apr 25, 2005 11:00 PM
