This thread is privately moderated by Michael Heer, who may elect to delete unwanted replies.
Old Oct 09, 2007, 06:30 PM
Splat762 is offline
Find More Posts by Splat762
Offical Lightpole Magnet
Whidbey Island, WA.
Joined Feb 2007
Beautiful P-40!!!
Splat762 is offline Find More Posts by Splat762
Old Oct 10, 2007, 06:25 AM
basha53 is offline
Find More Posts by basha53
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Sweeeet P-40
basha53 is offline Find More Posts by basha53
Old Oct 10, 2007, 12:10 PM
RickAvery is offline
Find More Posts by RickAvery
Moorpark, Ca.
Joined Apr 2004
I figured I'd throw my 2nd A-10 into the mix.
Rick
RickAvery is offline Find More Posts by RickAvery
Old Oct 10, 2007, 01:55 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Rick,
Good looking A-10, I should have gone with the Razor back mouth.
Gary
Old Oct 10, 2007, 04:24 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Thanks for the comments guys.
Rick, I've always admired your A-10 scheme. Especially the warthog teeth!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Oct 10, 2007, 11:47 PM
Moorpark, Ca.
Joined Apr 2004
Thanks for the encouraging complements guys! My first shot at freehanding something like that on a plane. I found a fine point water based pen and kept at it until it looked right. The water base made it easy to take a damp paper towel and wipe away the lines until It looked right. Then I took a ultrafine sharpie and drew in the lines that were to stay, and then just paint between the lines. Happy flying.
Rick
Old Oct 14, 2007, 01:33 AM
ala722 is offline
Find More Posts by ala722
San Jose, CA
Joined May 2004
Well, since A-10's seem to be in season... Here is mine as well.
Wattage Retracts, original edf-50's (brushless and removable),
TP 1320 3S, 2 Phoenix 10's, and full weapons load plus full length
pilot (carved).
AUW = 16 oz. Flys like an A-10. Looks like an A-10.
A
ala722 is offline Find More Posts by ala722
Old Oct 14, 2007, 02:58 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
A,
That's a beautiful A-10. I especially like the weapons load and pilot. How well do the Wattage retracts hold up?
Pat
Old Oct 14, 2007, 10:53 PM
ala722 is offline
San Jose, CA
Joined May 2004
Originally Posted by crxmanpat
A,
Pat
Thanks Pat,
The wattage retracts are great (and no longer made )..
Wish I could buy a few more sets.
The struts are rather soft and tend to bend with a good bounce. This absorbs most of the energy and saves the actual retracts. I have had
them in there since day one and she has seen a lot of airtime.
The motor pods are also removable and each has a hatch for fan removal
as well. The EDF-50 is held in with allen screws from the bottom.
Arnold
Old Oct 16, 2007, 10:21 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
pilot (carved).
A
I see that you are running cc 10's, did you change the settings on the ESc's? If so what did you set them to? I haven't maiden as yet.
Thanks, Gary
Old Oct 17, 2007, 04:09 PM
ala722 is offline
San Jose, CA
Joined May 2004
Thanks, Gary
Hi Gary,
First, one question... Are you running the EDF-50 or EDF-55 version?
Regarding the CC P-10's, Nothing special. I use the Phoenix "Link" USB
adapter to set them up. Just make sure they are both the same
firmware revision (usually the case if purchased at the same time).
I went for durable vs. all out performance. I wanted a reliable and low
maintenance bird. The only thing I have ever replaced is one Thunder
Power Gen II pack with a Thunder Power "prolite" Gen III pack. Not
too bad for well over 100 flights. Very consistent and basic "charge
and fly" bird that always gets noticed. Twin EDF-50's make a sound
that is hard to describe. She sounds like you are stepping on TWO
cat's tails...
A
Old Oct 17, 2007, 10:34 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Hi Gary,
cat's tails...
A
I bought the EDF-55's with Himaxx 2015-4100 the CC-10's came as a package deal from e-flightline.com. Just wondering what you programmed the cutoff for?
Old Oct 17, 2007, 11:12 PM
ala722 is offline
San Jose, CA
Joined May 2004
Before you fly it, find a watt meter and verify the amp draw A P-10 may
be a little light for the edf-55's on 3S (11.1V). I would put p-25's on
that setup just to make it stay lit.
I set the cutoff (LVC) to 9V on both (3S Lipo std.) and used a "Y" cable (including the power wire) to the rx. You might want to consider putting
the ESC's behind the motors for maximum cooling. It takes a little extra
wire but, Heat is a bad thing. I do not pull anywhere near 10A and mine
stay cool inside the fuse (verified).
A thermal shutdown on a P-10 is a bad thing. The A-10 does not fly
well without power to the RX.
We can continue this discussion via PM if you want... Just send me your
email address etc.
Arnold
Old Oct 24, 2007, 01:52 PM
SMRTIC is offline
Find More Posts by SMRTIC
SMRTIC's Avatar
Joined Jan 2007
Just finished painting my GWS Corsair. I wanted to go with something different than the standard blue corsair and think I found it in Cook Clelands "Lucky Gallon". I had one heck of a time finding good documentation for this one. I think it will look great against the blue sky.
SMRTIC is offline Find More Posts by SMRTIC
Old Oct 24, 2007, 03:59 PM
pd1 is offline
pd1
Find More Posts by pd1
pd1
United States, MA, Haverhill
Joined Jun 2006
I also like the racing Corsairs.
Nice choice and nice job.
Here's my Gws planes.
Paul
pd1 is offline Find More Posts by pd1
Beaver, a GWS model guapoman2000 Parkflyers 49 Apr 01, 2011 05:28 PM
Post your GWS model's notes and pics here Vol II Michael Heer GWS (Grand Wing Servo) 502 Apr 05, 2005 09:00 PM
Piper J3 Cub, a GWS Model guapoman2000 Parkflyers 81 Nov 30, 2002 12:51 AM
Or, GWS Tiger Moth vs Bleriot III... Driftway Parkflyers 3 Oct 15, 2001 12:00 AM
NEW - gws Tiger Moth -vs- Bleriot III - Will pico Pack work? mrebman Parkflyers 1 Jul 01, 2001 12:24 AM
