This thread is privately moderated by Michael Heer, who may elect to delete unwanted replies.
Old Jun 16, 2007, 10:10 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Roger
I zoomed in on the pilot's face. Man he has a big grin there! Glad to see "Bad News" has survived the initial flights to sort out the new power plant. When I bring mine out to the field, folks come over and say "That's a Formosa??!" The combination makes for a fast, nimble plane that really slows well. No bad habits.
Regarding the multi-blade props, I agree, they look cool, but just don't get the job done. I tried a new 9050x3 on my GWS 190 with the 3008 motor and went back to the two blade prop. I have an Art-Tech P-51 with a beautiful four blade prop. It looks stunning on the ground and on the ramp spinning up but is the slowest Mustang in the air. There have been lots of threads and discussion on the merits of multi blade props from folks who are far more experience than I. For me, unless the aesthetics dictate a multi-blade prop, I'm going to stick with a two blade.
When is "Bad News" going back up?
Jim
jamesdr is offline Find More Posts by jamesdr
Old Jun 16, 2007, 11:13 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Been up today Jim. Although my holiday field is safe and only sees a few people walking round the boundary and I'm heavily insured I'm always somewhat nervous knowing that the neighbours are all strangers in the event of something going pear-shaped. Back home the farmer's cut and baled his hay so for the time being I'm back with "my" field.
I noticed today that even with the HD prop I'm getting flutter/howl in a dive like I used to get on my first, stock, Formosa in a power dive with a 9070 SF prop. I may have to try an APC 9075 which is certainly stiffer. Also, although it flies very fast at 50% WOT I was using full throttle more today and the 20C 1000 battery, which isn't ventilated, was definitely warm when I took it out. Not hot, but well warm.
Roger Lombard is offline Find More Posts by Roger Lombard
Old Jun 16, 2007, 11:28 AM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Roger, I fly my Formosa with an APC 8x4 and 15c 1500mAh battery. I had a data logger in it back when I was settling in on a system and was drawing 200 watts - I'll bet your 9075 is going to pull more. The wind is howling today so the opportunity for flying is not good but I want to try an 8x6 to see if the additional pitch is worth the extra draw on the system.
I had a GWS 9070 on my GWS190 and it used to howl like a banshee in a dive. I had to change it out because folks thought I was abusing my planes.
Jim
Old Jun 16, 2007, 11:53 AM
Confused? Who, me?
Joined Jan 2005
I can certainly try an APC 8060 - come to that I've got an 8080 APC - some pitch speed there.
Saw a great T shirt logo today "Keep on flying till the last bit stops moving" - could adopt that as my motto!
Old Jun 16, 2007, 04:45 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Roger
Next step it to shoehorn (and I really mean shoehorn) the 2409-12 into a GWS Spitfire. It will pull away from the other warbirds of similar size like they are tied to tree stumps. I flew the heck out of mine until the 8x4 folding prop had a catastrophic failure and destroyed the cowl, motor mount and took a chunk out of the wing. I repaired her but she wasn't ever "right" again and finally spun out of the sky on a low pass. But when she was new, she ruled!
Jim
Old Jun 16, 2007, 05:54 PM
The Bandit is offline
Find More Posts by The Bandit
The art of Crashing
Joined Dec 2006
Originally Posted by jamesdr
Roger
How did that work out for you? I had that motor in the spitfire, but yanked it out due to the battery size needed to feed that motor. What battery are you flying it with?
The Bandit is offline Find More Posts by The Bandit
Old Jun 16, 2007, 06:29 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
I was using a CommonSense 1250 3s 10c. Judicious use of the throttle kept it from puffing. I could crack it WOT for some short and intense speed bursts but most flying was at 2/3 to 3/4 and it was still plenty fast. As I recall, I had to do some carving out of the battery box but had no other problems. In retrospect, a 15c would bave been a better match. I'll do that for the Corsair build.
Jim
Old Jun 17, 2007, 12:30 AM
Confused? Who, me?
Joined Jan 2005
My Spitfire carries a 1200 3S 20C anyway and I think I've had a BP motor in a Spit in the past so that wouldn't be a problem. Will you just stop doing this to me Jim??
You don't happen to wear a fancy red suit and hood with a pair of horns just above the ears the ears do you?
Old Jun 17, 2007, 01:00 AM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Just whispering into your ear, maybe a nudge or two.
Jim
Old Jun 17, 2007, 02:43 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
jamesdr & Roger
I assume it was the left ear .
Ken
kensp is offline Find More Posts by kensp
Old Jun 17, 2007, 05:16 PM
Confused? Who, me?
Joined Jan 2005
Been sloping today with the 190 and fortunately ace photographer Steve Bentley was there with his long lens to capture some shots for me. Actually they're too good really - I can see I need to touch up the paint a bit and also the ballast velcro'd to her belly is showing up - I really need to do something cleverer than that.
Don't be misled by the foreshortening effect of that 400mm lens - some of these look as though they were flying past Steve's nose but they're mostly actually up to 200 or more yards out
Old Jun 18, 2007, 11:47 AM
ipjodan is offline
Find More Posts by ipjodan
Gloves are awkward
ipjodan's Avatar
Preston, UK
Joined Dec 2004
Hello,
Heres my FW190
ipjodan is offline Find More Posts by ipjodan
Old Jun 18, 2007, 12:01 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Look nice - ParkZone is going to start wondering why they are having a run on FW190 spinners.
Jim
Old Jun 18, 2007, 12:04 PM
ipjodan is offline
Gloves are awkward
ipjodan's Avatar
Preston, UK
Joined Dec 2004
He He, get them while you can.
Old Jun 18, 2007, 02:20 PM
Stevepilot is offline
Find More Posts by Stevepilot
aka : SteveBB..
South Yorkshire,England
Joined May 2007
No pictures, no pictures!! Glad you like em mate.
Stevepilot is offline Find More Posts by Stevepilot
Beaver, a GWS model guapoman2000 Parkflyers 49 Apr 01, 2011 05:28 PM
Post your GWS model's notes and pics here Vol II Michael Heer GWS (Grand Wing Servo) 502 Apr 05, 2005 09:00 PM
Piper J3 Cub, a GWS Model guapoman2000 Parkflyers 81 Nov 30, 2002 12:51 AM
Or, GWS Tiger Moth vs Bleriot III... Driftway Parkflyers 3 Oct 15, 2001 12:00 AM
NEW - gws Tiger Moth -vs- Bleriot III - Will pico Pack work? mrebman Parkflyers 1 Jul 01, 2001 12:24 AM
