Old Apr 05, 2005, 03:41 PM
Levi Jordan is offline
Find More Posts by Levi Jordan
Levi Jordan's Avatar
Washington State
Joined Feb 2004
Yippee!
NEW 3DF SuperXtra 1.14m - Top Shelf Foamy
Friends..... Have I been busy here at the shop!.... I wanted to get you introduced to the newest, coolest, most advanced foamy in the world.....
Appologies for keeping you all in the dark for the last month while development has been going on.
This New Generation Foamy is a complete ground up redesign of the Extra 300LX and features some cool new Technology in it.....
There will be a limited production run of 100 kits. You will have the chance to pre-order yours (limit 2 per person) on Thursday 4/7/05. Prices are $59.95. Not for the beginer (there are cheaper airframes to crash) I'll have the full construction manual online for review later this evening.
I'll also be updating this here thread with some build pictures and specs.... I think you'll all enjoy the news to come....
Levi Jordan is offline Find More Posts by Levi Jordan
Old Apr 05, 2005, 03:46 PM
maeu2003 is offline
Find More Posts by maeu2003
Joined Apr 2004
WOW i want one. that looks great. You need anybody to test it for you . i will keep watching and hopefully get one.
maeu2003 is offline Find More Posts by maeu2003
Old Apr 05, 2005, 04:03 PM
Jaybugg13 is offline
Find More Posts by Jaybugg13
Joined Mar 2005
That's not the actually foamy is it????? I checked the composite-arf.com website and it says those sell for about a grand. nice picture though, but is that the actual plane?
Ooops sorry just saw the "based on".. Is the kit you are producing full fuse??
Jaybugg13 is offline Find More Posts by Jaybugg13
Old Apr 05, 2005, 04:08 PM
Washington State
Joined Feb 2004
Well, it looks like that.... but thats not actually it... That Composite-ARF above was the design and paint scheme basis...
Old Apr 05, 2005, 04:41 PM
j_z_123 is offline
Find More Posts by j_z_123
BOSS
j_z_123's Avatar
New Jersey (excl EWR), United States
Joined Apr 2002
...Full fuse?
Jon Z.
BTW, Nice talking with you at the WRAM show!
j_z_123 is offline Find More Posts by j_z_123
Old Apr 05, 2005, 04:52 PM
Washington State
Joined Feb 2004
Nope.... maybe someday.... I'm getting the files converted to show what it's all about...
Old Apr 05, 2005, 04:55 PM
Washington State
Joined Feb 2004
Specifications:
Weight: 10.5-17.7 oz
Span: 45”
Wing Area: 377.4
Loading: 4.0-6.7 oz/ft2
Radio: 4-5 ch w/ 4 micro servos
Old Apr 05, 2005, 04:56 PM
Washington State
Joined Feb 2004
The 3DF SuperXtra 1.14m was designed and manufactured by computer (CAD/CAM) for accuracy and construction ease. The level of engineering and laser cutting has been hailed by many as the highest in the industry. All parts have been precision cut on a CNC laser cutting system at the 3D Foamy Models shop. Not only are 3DF planes accurately manufactured, but they adhere to the full scale Extra 300 platform to IMAC guidelines. This makes your plane fly like the big planes do! It also makes it one of the best looking foamy’s out there, and a great trainer for aerobatics. It’s no surprise that competition IMAC pilots prefer our planes to practice competition routines.
The foam used in your kit is the best quality available. Don’t be fooled by cheap imitations of this incredible material. True Depron is only available from one place in the entire world! Depron is very forgiving and easy to paint. It is also easy to repair after mishaps. The composite laminate construction of the 3DF designs makes them one of the strongest performance foamy’s in the world.
Some unique construction techniques have been introduced by 3D Foamy models. The first is the G-Force PRO™ wing. It revolutionized the flight performance of foamy’s.
All foamy's are NOT created equal..... 3D Foamy kits are the first to offer this radical new wing design! The G-Force PRO™ wing is the heart of the aircraft. It is a core layer with beautiful lightning holes.... To top it off, servo bays and even the control horn slots are all cut, ready for the cool 3D Foamy 3D control horns. (included) The beauty of the deal is the top and bottom LE wing skins. It allows for slower airspeeds on the down lines, totally eliminates high speed "hunting" (not much to start with though) and improves the tracking to the point that you WILL NOT think you are flying a "Flat" wing... The top wing cap covers the servo and lightening cutouts... The bottom wing cap makes it all symmetrical... By sanding the LE round, it creates a good separation point for good clean snaps. The caps carry back to MAC, then transition back into the hollow wing section. This creates a small vortex down the rest of the wing, allowing better aileron control, less wing rock, and a little more "lift" for slower landings. This also helps out with the glide ratio.... It looks awesome too.... the aileron servos and wires are completely hidden in the wing. No more servo leads dangling in the wind! Direct Drive rudder and elevator linkage is part of the PRO kits.... The servos are located as close as possible to the flight surface. It uses a short carbon pushrod for control... The plane flies like a 40%er, and so now the controls are setup the same too!
The second unique construction technique is the composite laminate method of the entire airframe. This includes the lightened core layer of foam, and then outer sheet layers. This weight saving; strength increasing technology allows a larger airframe at the same weight of a smaller model. Incorporated into this technology is our Hinge Core™ design. Tapes are nice, but look bad and don’t last. Hinges are the natural choice, but requires accurate placement and drilling of 26 holes in foam. For most modelers this is a chore and leaves some frustrated. We fixed this with our new construction methods! It leaves you with perfect CAD/CAM manufactured hinging solution. No guessing, measuring, drilling or mistakes! Simply drop in the high quality Robart Hinge Points and you’re done. I hope that you are going to enjoy building and flying this plane as much as I have!
Old Apr 05, 2005, 04:58 PM
Washington State
Joined Feb 2004
A extremely complete, high end parts package is part of the new kits...
Part No. QTY. Dimensions Description
001201a 3 Laser Cut 3mm Foam Foam Kit Parts
001201b 7 Laser Cut 2mm Foam Foam Kit Parts
001202 1 .230” Dia. Carbon Main Carbon Spar
001203 2 .125” x 7.25” Carbon Wing Tip Spar
001204 1 .125” x 5”” Carbon Elevator Joiner
001205 1 6” x 2¼” x 1/8” Laser Cut Birch Motor Mount and Beveller
001206 1 Velcro Battery Mount Strap
001207 2 .040” x 48” Carbon Rod Aileron/Elev./Rud. Pushrods
001208 1 CD ROM Instruction/Plans CD
001209 4 Dubro EZ Connectors Pushrod Assembly’s
001210 4 Dubro Micro Clevis Set Pushrod Assembly’s
001211 13 Robart Hinge Points Hinging
001212 4 .030” x .121” Carbon Strips Fuse Spars
001213 1 .125” x 11” Carbon Tube Rear Wing Spar
001214 1 1/16”x 6” Plastic Tube Pushrod Guides
001215 4 CNC Machined Carbon Fiber Control Horns
001216 1 Laser Cut Plastic Velcro Strap Doublers
001217 1 8.5”x11” Decals
Old Apr 05, 2005, 06:53 PM
c312 is offline
Find More Posts by c312
Melbourne, Florida, United States
Joined Aug 2004
wow, thats looks sweeet, i want one!!!!
c312 is offline Find More Posts by c312
Old Apr 05, 2005, 07:29 PM
DUMBERTHUMBS is offline
Find More Posts by DUMBERTHUMBS
United States, FL, Hollywood
Joined Sep 2003
Where Do We Get Them From.........
DUMBERTHUMBS is offline Find More Posts by DUMBERTHUMBS
Old Apr 05, 2005, 07:43 PM
Washington State
Joined Feb 2004
I'll be putting the Pre-Order page up on the website.... (www.3dfoamy.com)
Old Apr 05, 2005, 08:05 PM
Tim H. is offline
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
Man Levi, you scared me for a minute! I was thinking those were pics the kits for $59.95 I was thinking, man... no way... Anyway, great news! Can't wait to see the bar that I have to live up to...LOL I just wish I had more time...
Tim H.
PS - any videos yet????
Tim H. is offline Find More Posts by Tim H.
Old Apr 05, 2005, 08:56 PM
Washington State
Joined Feb 2004
Ya, my head wasn't thinking that when I posted it.... but re reading the first line, sure makes it sound like that I'd have China sending me kits if that were the case....
Indoor Fly is tomarrow night. I'll take it there and do my best at putitng on a show for some videos. Weather here has been poor....
Old Apr 05, 2005, 09:35 PM
bamm is offline
Find More Posts by bamm
bamm's Avatar
Planet Jupiter
Joined Jan 2005
hey Levi do you sponsor??
bamm is offline Find More Posts by bamm
New Brushless motor - 1/3 scale model? allan Electric Plane Talk 12 Jan 10, 2008 06:37 AM
Discussion 3DF SuperXtra 1.14m - Top Shelf Foamy - Part 2 SchiessCo 3D Flying 757 Feb 08, 2007 07:50 PM
For Sale SuperExtra 1.14M kit, new CAFplanekid Aircraft - Electric - Airplanes (FS/W) 0 Mar 07, 2006 05:11 PM
NEW Sanyo 600AE - $1.40 each squelchF18 Aircraft - Electric - Airplanes (FS/W) 0 Feb 14, 2002 05:26 PM
NEW Sanyo 600AE - $1.40 each squelchF18 Aircraft - Electric - Airplanes (FS/W) 0 Feb 12, 2002 09:09 PM
