Old Apr 05, 2005, 11:31 AM
bykrdan is offline
Find More Posts by bykrdan
Joined Dec 2003
Printed Tissue Decals Questions
Hello - forgive some silly questions, please, but I'd like to get this right the first time.
I have some graphics prepared and printed on white tissue paper (through an inkjet printer) that I intend to layer onto Depron wings. This is just a "spot" decal - it doesn't cover the whole wing.
- I imagine I want to lightly seal the tissue before gluing, so moisture from the glue won't make the ink run. Can I use the water-based PU for that? I plan to go over the whole plane with it as the last coat. Should I spray both the front and back?
- Is Elmer's gel glue suitable for this purpose? I ask because I've found Depron resistant to some white glues...
- I used tissue paper in the inkjet. It worked okay, but it's a bit of a pain, and sounds awful grinding inside the printer like that! Would tracing paper also work, or for just a spot or two, regular typing paper?
Dan.
bykrdan is offline Find More Posts by bykrdan
Last edited by bykrdan; Apr 05, 2005 at 11:34 AM. Reason: Hit enter key too early!
Old Apr 05, 2005, 12:03 PM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
Dan,
Read this article on tissue over foam by Ralph Bradley, it was in the Inside Story:
http://www.rcgroups.com/links/index....at=232&id=4188
Not particularly about printed tissue, but some good info from a master builder.
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Apr 05, 2005, 01:07 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
For small decals you might get away with just very light paper, it comes in different weights. Cut them out and see if you can live with the weight.
Not much moisure inside if that is where you are flying.
More info her from Gordon:
http://www.rcgroups.com/forums/showt...ht=staggerwing
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Apr 05, 2005, 03:35 PM
bykrdan is offline
Joined Dec 2003
Thank you both; the article was excellent (nice looking wings, too!)
I'm actually building for outdoors - I don't have access to many indoor sites. I may just go ahead and use regular paper. The plane comes in around 2.5 ounces; what's a couple of extra grams.... I thought, though, that tissue might hug the foam better and give a more blended look.
Old Apr 05, 2005, 04:04 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Can you give us an idea what the insignia might look like? You can print to tissue. Then, peel it off, turn it over and spray 3M77 on the back side and stick it on your Depron. Now, take the piece of paper you cut the tissue out of, spray the back side with 3M77, pull it on and off a piece of corregated cardboard a couple of times to make it less sticky. Apply it over the wing where your insignia is. Place other paper around it as needed, and spray with Krylon clear coat. This should provide reasonable protection for outdoors.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Apr 05, 2005, 04:20 PM
sgtdirt is offline
Find More Posts by sgtdirt
Mentor, OH
Joined Dec 2004
when you run your tissue thru the printer, do you cover the whole sheet of paper with the tissue?
if i'm printing decals, i position the tissue in just the area were the graphic is. then i glue around the edges (approx an inch or so) with a glue stick this way i don't get that grinding sound. another thing, you have to leave enough room on the edges (of the paper) so the drive wheels of your printer don't grab the tissue.
(if you knew all this already then i'm sorry for wasting bandwith)
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Apr 05, 2005, 08:22 PM
Boston, Mass
Joined May 2001
I cover the entire sheet with tissue. I spray 3M77 on the sheet of paper, apply it and pull it off corregated cardboard about 5 times to make it less sticky. Then, apply the tissue paper to it, smooth out, and trim off around the edges. I don't have any problem with printer wheels. I find it easier to remove the tissue from the carrier sheet than with other types of glue.
Gordon
Old Apr 05, 2005, 10:01 PM
del is offline
del
Find More Posts by del
del
del's Avatar
north of Chicago
Joined Feb 2003
Instead of 77, you might want to try 3M "Spray Mount". It works fine for me,
even with small bits of very thin "gampi" tissue.
A friend has been using clear shellac to stick tissue to foam. He swears that
it doesn't attack the ink. I've got some but have yet to try it.
--del
del is offline Find More Posts by del
Old Apr 05, 2005, 10:30 PM
Boston, Mass
Joined May 2001
Del,
Actually I use either 3M77 or 3M Photo Mount Adhesive, and the Photo Mount Adhesive is my Preferred product. But, I generally mention 3M77 as it is cheaper and much easier for most people to find. Thanks for the suggestion.
Gordon
Old Apr 05, 2005, 10:51 PM
bykrdan is offline
Joined Dec 2003
I got lazy this time and just used a strip of masking tape across the top of a carrier sheet to pull the tissue through. The tissue was the same size as the carrier, but tacked only across the top of the paper. It worked okay, but the spray adhesive is the way to go. Much less crinkling...
I'm pretty protective with my only can of foam-safe 3M77! But that gives me an idea - I have been using it to make paint masks from cardstock, but I could probably use the newer foam-eating formula for that, since I only tack it on lightly for a moment, then save the foam-safe stuff for things like mounting tissue decals.
Old Apr 05, 2005, 10:53 PM
bykrdan is offline
Joined Dec 2003
I'm doing a themed Pitts, for the place that gives me so much Depron! Here's a small version of the insignia...
Old Apr 08, 2005, 11:32 AM
bykrdan is offline
Joined Dec 2003
How NOT to do it!
Well, so much for getting it right the first time
I could have sworn my can of 3M adhesive was the foam-safe formula, but I can now say conclusively that it is not!
Here's how the fiasco went: I generously sprayed the back of the tissue with adhesive (before cutting). To keep it moist while I cut, I laid it onto wax paper (a mistake). Turns out the stuff also dissolves and mixes with wax.
I cut out the tissue decals, then attempted to make a carrier sheet from the front using a piece of masking tape, stuck to a pant leg a few times (second mistake). Masking tape is far, far stickier than it feels, especially when applied to tissue!
I discovered this when I put the whole thing on the wing, and attempted to peel off the masking tape. The tissue was destroyed in the process. Then I noticed it was also starting to gnaw at the foam. I was able to wipe it off before much damage was done, and it was all contained under the decal area anyway, so the wing was saved.
After that, I just re-printed the decals on regular paper, cut out, and applied with gel glue brushed on to the wing, and around the back edge of the paper. This worked splendidly. I couldn't find Krylon, but Model Master top coat worked just fine.
One side effect: As the decals dried, they shrank, and pulled up my wingtips, ever so slightly. This would be kind of neat in any other plane (though I'm not sure I wanted it on my Pitts!)
Pager Staggerwing: Printed Tissue Tutorial/Build Gordon Johnson Scratchbuilt Indoor and Micro Models 47 Mar 03, 2013 02:53 AM
Printed Tissue Madness (Examples of Printed Tissue Planes) Gordon Johnson Scratchbuilt Indoor and Micro Models 26 Jan 27, 2007 10:28 AM
Is there Interest in a Profile Printed Tissue Thread? Gordon Johnson Scratchbuilt Indoor and Micro Models 24 Aug 01, 2004 10:32 PM
Dope & tissue covering Questions snoopy71 The Builders Workshop 11 Jul 15, 2004 07:11 PM
computer printed tissue Jim Drissell Scale Kit/Scratch Built 3 May 12, 2002 08:09 PM
