Old Apr 01, 2002, 01:55 AM
ALVES is offline
Find More Posts by ALVES
Ramstein AB, Germany
Joined Dec 2000
Setting up gov mode on smile 40-6-12
Can someone help me with the set up of the Kontronik 40-6-12 speed control for my voyager. Is this possible with a JR 652 radio. I tried to use the stunt trim but it does not allow me to adjust the rpms, it just goes to full throttle, thanks.
Derrick
ALVES is offline Find More Posts by ALVES
Old Apr 01, 2002, 10:17 AM
frebou is offline
Find More Posts by frebou
frebou's Avatar
St-Hilaire,Québec,Canada
Joined Sep 2001
I don't know the 652 but you have to ajust the ATV of the channel you use... thus, limitting the travel.
you can put, as exemple 75% atv, so when you switch your flight mode, it's like giving 75% throttle
maybe this channel of your radio is not capable of doing ATV but... I would think it can... otherwise use another channel
frebou is offline Find More Posts by frebou
Old Apr 02, 2002, 07:15 AM
ALVES is offline
Joined Dec 2000
Thanks, I figured it out. I'm using my stunt trim switch, works great.
Derrick
Old Apr 02, 2002, 08:24 AM
frebou is offline
frebou's Avatar
Joined Sep 2001
Good! happy you find it by yourself. It more rewarding for you
have a happy flying
Old Apr 02, 2002, 07:55 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Not sure if the ATV will work since you must set up the ESC with 100% travel.
After setup you adjust to the % you want for flight HS.
If you use the ATV for that, the ESC will not see 0% and will not arm.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Apr 02, 2002, 08:37 PM
frebou is offline
frebou's Avatar
Joined Sep 2001
I don't know for the JR 652, but it could let the lower atv at 0% and adjust only the high point one...
hope he will be able to use de governor function... it's some much better with it
Old Apr 03, 2002, 02:13 AM
ALVES is offline
Joined Dec 2000
The governor function is working but now I am getting a violent tail bobbing(oscillation). I am using an Ikarus "profi" heading lock gyro and it doesn't seem to matter where I set the sensitivity, it won,t stop banging up and down. Oh, and by the way I am using a Hacker C40 11S and stock pinion on 8 cells. Any suggestions?
Derrick
Old Apr 03, 2002, 08:48 AM
frebou is offline
frebou's Avatar
Joined Sep 2001
The sensitivity on the profi gyro (as well as every other jumper) are read once when you power up. After this if you modify the sensitivity, you have to turn it off, wait couples of second and apply power again to retest.
You can have remote gain on this gyro if you have a spare channel.
BTW: It's not a super-duper gyro... I put it away because I was not thrusting it while going backward...
I'll put it on a smaller heli like my hornet
Whoops! Voltage Cut-off on Smile 40-6-12 rocky79 Batteries and Chargers 3 Oct 05, 2005 11:16 PM
I need help setting up Kontronik Smile 40-6-12 esc soholingo Power Systems 5 Dec 19, 2002 12:54 PM
Disabling bec on Smile 40-6-12 GoodTill Electric Heli Talk 4 Apr 30, 2002 12:18 PM
Kontronik Smile 40-6-12 / Mega ACn22/20/4 Govenor Mode Problem gstew Electric Heli Talk 29 Feb 28, 2002 04:53 PM
Smile 40-6-12 Set-up Help ccaren Electric Heli Talk 24 Feb 19, 2002 10:02 PM
