17 oz seems pretty wimpy. I need over 40 on my small 48" span PSS slopers. I calc'd out how much I needed for my DG-1000 and came up with about 30oz as a worst case number. You DG-600 is probably about the same. I always like to have a little extra as you never know what's gonna happen once you get the plane up.
You can use this servo torque calculator. http://www.csd.net/~cgadd/eflight/calcs_servo.htm You input the numbers and it calculates how much torque will be required. Make sure you put in a nice high number for the speed as the planes can really scoot when shoved into a steep dive. TFLG |
Zürich
Joined Feb 2003
Weight
Hello Fabrice
The few grams that you will save on servos will have very little effect of the DG. The correct setup is going to be a far more important factor. The sink rate is good when you allow it to fly a little faster with a good setup. The DG is very scale and thus the tailplane is really small, this makes highstarting a bit more tricky and it takes a little getting used to. On letting go the nose goes vertical before the plane can build up any speed (hook on the bottom of the fuselage and small surface area of the tail plane) It is in this initial phase that it is stalled for a split second before the tail pushes the nose back down and the airflow can become laminar. If the flow on one side becomes laminar before the other the dg will will want to break out to the side. Having said that, I never did any damage to mine, but it did go pear shaped a few times and it got quite close to the ground. It might be worth considering two hooks on either side of the fuselage just under the wings to reduce the initial asymetrical pull of the elastic. Here is a video that has been edited to cut out that first phase, but you will see at about 21 sec. that it is just coming out of its nose up position before it bites in and starts to climb http://www.lenger.de/cgi-bin/neu_web...=7517362_14715 The most noticable difference with winglets vs extentions is the roll rate, I flew mine mostly with the shorter span. regards Daniel |
Belle Mead NJ
Joined Mar 2005
Winch Hooks
Hi Daniel,
Indeed I also thinking of adding flaps on the DG at some point. I’ll probably not do it right away but that was an other reason to save weight. I’ve read threads on this forum about adding flaps on the DG-505 it seem to work very well, but the 505 has a different airfoil (HQ3/15). Have you done or heard about such modifications? What is true for most scale sailplane applies certainly for the small DG-600: winch/histart launch is safer with a bridle and hooks both side of the fuselage. (see ISSA ). Fabrice |
| Thread Tools | |
| Help! Servo choice help | Michael Richards | High Performance | 4 | Jul 15, 2007 08:16 PM |
| Servo Choice Help! HS-81 or HS-55? | vonJaerschky | Electric Plane Talk | 13 | Jun 26, 2004 07:28 AM |
| Help! Servo Choice for Bobolink? GWS or Hitec? | rvillegachapa | Hand Launch | 2 | May 16, 2004 07:21 PM |
| Help!!! Servo Choice for GWS Beaver or Moth | TJSlayer | Parkflyers | 2 | Jan 14, 2003 12:53 PM |
| Need help with Rx and Servo choice. | Richard2002 | Radios | 3 | Nov 13, 2002 05:34 PM |
