Old Apr 04, 2005, 09:37 AM
wrenwright is offline
Find More Posts by wrenwright
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Pushing the limits of FFF - Part 2
Continuation of the first thread:
http://www.rcgroups.com/forums/showthread.php?t=240599
Here are some of the best bits from the first thread:
Plans (single sheet)
http://www.rcgroups.com/forums/attac...hmentid=248136
plans (tiled)
http://www.rcgroups.com/forums/attac...hmentid=248333
http://www.rcgroups.com/forums/attac...hmentid=248334
Video of the first insulator
http://www.bluefinmicro.com/movies/insulator.wmv
Here's a vid of [joecrash's extremely fast] Camo Insulator - http://joecrash.rchomepage.com/MOV00464.MPG
It's 32M, so lookout if you're on dial up.
Plans for the seaplane version
http://www.rcgroups.com/forums/attac...d=267283&stc=1
wrenwright is offline Find More Posts by wrenwright
Old Apr 04, 2005, 09:59 AM
jimsky is offline
Find More Posts by jimsky
Trying to defy gravity...
jimsky's Avatar
USA, NY, East Northport
Joined Dec 2003
Wren,
Review the threads about putting a small amount of dihedral in the original sized, flat plate wing. I've never flown one, but it sounds like it helped alot according to what people said.
By the way, your private mesage InBox is full and is not accepting anymore PM's.
Jimsky
jimsky is offline Find More Posts by jimsky
Old Apr 04, 2005, 04:13 PM
Saeed is offline
Find More Posts by Saeed
Saeed's Avatar
Salt Lake City
Joined Jul 2003
Cd Rom motor for this insulator
Would you guys please post the specs for the Cd Rom motors that are making these insulators scream? I have the GBv1 kit 22.7 mm stator, N45 5X5X1 magnets, 3 mm shaft, 26 g magnet wire, phoenix - 10 speed control, and 3 cell 11.1 V, 700 mah battery. What prop can I use? I have built a 15 Turn Wye. Can I use it with a 4025 prop, and 11.1 V 3-cell battery? Am I going to have the same screaming performance? Is it a safe set up for my Battery/phoenix - 10? Your suggestions/help is appreciated.
Regards,
Saeed
Saeed is offline Find More Posts by Saeed
Old Apr 05, 2005, 12:00 AM
kahnxx is offline
Find More Posts by kahnxx
Kahn
kahnxx's Avatar
Melbourne, Australia
Joined May 2004
I have a 13 turn (newbie kit) GB CD-ROM motor turning a GWS 5X2.5 prop with an E-Tec 1200 mAAHr 3S Li-Po, and my Insulator will go unlimited vertical, and has a very good turn of speed in level flight.
I have also run an APC 4.1X4.1 on this setup - it will go faster when level but will not go unlimited vertical, and is more of a handful on launch.
kahnxx is offline Find More Posts by kahnxx
Old Apr 05, 2005, 12:18 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Regards,
Saeed
Just ran it up on a 15t
That's a pretty light load, it'll be mild:
4x2.5, 10v, 2.9a, 17115, 3oz, 41mph
I'd suggest 4.5x4:
10v, 4.6a, 15665rpm, 5.8oz, 60mph
Maybe 12-13t would be better for a 4025 prop on 3s. It's 9.2a on a 10t...
Gene Bond is offline Find More Posts by Gene Bond
Old Apr 05, 2005, 12:20 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
5x2.5???
Old Apr 05, 2005, 12:50 PM
Saeed is offline
Saeed's Avatar
Salt Lake City
Joined Jul 2003
Gene,
I've got the following props: 4025, 4040, 4530, 5030, except the one you suggested (4540). What would I get by using the 4530? Thanks for all your help.
Saeed
Old Apr 05, 2005, 02:32 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
I used a 14 turn motor with a 2s 730mah battery, and a 5.5x6 (a cut-down GWS 7x6)
Can someone edit one of the first posts on this thread to include some pictures, plans and links to videos? It makes it much easier than searching through 500 old posts for the useful bits.
RobinBennett is offline Find More Posts by RobinBennett
Old Apr 05, 2005, 05:29 PM
sr71fan is offline
Find More Posts by sr71fan
Flying...Pushing Air Down
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Screamer Motor
Saeed,
From the first post of the first thread...
motor- 15 turn Delta config, 26 gauge, 26,000rpm static, 5.5 amps WOT
Esc- Phoenix-10
Radio gear- 2 ea. Cirrus 5.4 servos, GWS 4ch reciever
Wingspan- 19.5"
AUW- 4.76oz
top speed- yet to be determined...my untrained eye says "really fast!"
plans- unavailable, yet all that is needed to reproduce this plane is an imagination, a sharp blade and maybe a ruler.
I believe Robb had a GWS 3/3 (3030) prop on it during the video flights.
Gary
sr71fan is offline Find More Posts by sr71fan
Old Apr 05, 2005, 06:04 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Gene,
Saeed
Figures, I don't have a 4530
I've got to order some on my next order....
I'd try the 4040, 4530 and 5030... Somewhere in there you should find a happy spot...
Old Apr 05, 2005, 06:53 PM
Saeed is offline
Saeed's Avatar
Salt Lake City
Joined Jul 2003
Gene,
As always thank you so much for your time, help, and kindness. People like you make this hobby as intersting as it gets.
Regards,
Saeed
Old Apr 05, 2005, 09:41 PM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
Saeed Gene,As always thank you so much for your time, help, and kindness. People like you make this hobby as intersting as it gets.
I whole-heartedly agree with that statement. People like Gene, GPW, Jerbear, etc., etc. make this hobby great. I really appreciate how much you all give. I would not of had near the success or fun that I have had (not to mention all of the planes) without you guys. Thank you!
Daddy-O
Daddy-O is offline Find More Posts by Daddy-O
Old Apr 05, 2005, 10:46 PM
bass3587 is offline
Find More Posts by bass3587
bass3587's Avatar
Arlington,Texas
Joined Jan 2005
I second that statement. I have so many ideas and planes in my head from these guys it's just amazing and gratefull to you all. Keep it the good work
bass3587 is offline Find More Posts by bass3587
Old Apr 06, 2005, 01:57 AM
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Robin,
If you PM me the links, I'll edit my first post of this new thread to reflect that information.
Old Apr 06, 2005, 06:41 AM
weather_man is offline
Find More Posts by weather_man
semper ventosus
weather_man's Avatar
Sasebo, Japan
Joined Jun 2004
Insulator in Spain
Here's my insulator. It's been too windy for a maiden, hopefully it will fly this weekend. I used the j250, and foam from Balsapr.com. Check it out.
weather_man is offline Find More Posts by weather_man
Pushing the limits of FFF blueman Foamies (Scratchbuilt) 505 Apr 04, 2005 09:38 AM
Jim Bourke's Moving Sale Part 2 -- Brushless motors jbourke Aircraft - Electric - Airplanes (FS/W) 1 Aug 07, 2001 03:00 AM
Hornet CP .... finally ... part 2 cyhyam Electric Heli Talk 90 Aug 05, 2001 10:40 PM
MIA's 12" House FLY Sub-Micro! NEWS!!! (Part 2) MicroRotors Electric Heli Talk 10 Jul 27, 2001 04:19 PM
Pushing the limits on 1406 2y? Steven D Electric Plane Talk 2 Jul 01, 2001 06:53 PM
