Valenta Fredy building manual
Hi
Has someone the building manual (drawing) for a v-tail Fredy. It would be nice if someone can scan this and send it to alex@halde.ch thx and best regards Alex |
I have it at home, but may not be there for several days. Also, I have a scanner that I've never hooked up, that is a hand-me-down, so I may have some trouble there, but will try to help you out when I get a chance. Target |
Latest blog entry: Stork 4 Pro X-tail from...
Here's some pics of the plans. I will send you the full size files to the above email addy.
T |
Good luck with the build!
And be advised that one of the better slope racers here with a Fredy is running with his CG somewhere back at the 70-73mm range. T |
Alex: Here is where that info came from: http://www.soaringusa.com/products/p...ategory_id=257 Some of the manufacturers seem to err on the side of caution, and I think Valenta is no exception, based on my experience with the Swallow. The CG on that is considerably further aft than on the plans. What I would(and will) do, is maiden the plane with the stock CG, or slightly aft of 55mm, but make certain that you can remove some nose weight to shift the CG to at least 70-73mm. Let me know what CG you end up using, and I'll do the same if I maiden first. Target |
Zero-Zero,
No problem, there. I may even post a few pic of my ballast set up and fuse/ tail linkage. Is your plane a flapped, 4 surface wing? Mine is, and I will most likely go with seperate servos for each half of the v-tail, I like the redundancy, even if I don't use the rudder stick(which I finally am starting to use). Target |
Here's some pics of what I'm doing to my Fredy-
1. 2-piece 1/8" ply keel to get a better fit in the fuse top and bottom. 2. Ballast tube and slugs. 5 x 4 oz.... 3. Slot for ballast tube. I'm trusting Bill DelHagen's 73mm CG spot, I hope it's right, so that I won't have to make spacers. Target |
I wouldn't use more than 5mm up, 7mm down on the tail. On the ailerons, try 15mm up, 10mm down if you like them "hot", and 9mm and 6mm, if you like them tame.
GL, T |
| Thread Tools | |
| Idea Icare Carbon D-light building manual/Instructions | rvillegachapa | Sailplane Talk | 1 | Apr 24, 2006 06:02 AM |
| Discussion XeroG 600EP building manual | yahtzee | Electric Heli Talk | 7 | Jan 29, 2006 09:13 AM |
| Sneak Preview - ZagNutz Building Manual | CenTexFlyer | Foamies (Kits) | 5 | Jun 29, 2002 06:00 AM |
| English building manual for LRK high-torque/no-gearbox diy motors | Ron van Sommeren | Power Systems | 0 | Mar 09, 2002 06:42 AM |
