Hi guys,
I just bought a new Phoenix 25, and on initial bench running, it seems to be getting awful hot very quickly. I've been flying my 2 AXI 2808/24s around with a Phoenix 35, and got tired of always switching the ESC between my two planes. I prop my AXIs with a APC10x6E prop, and that seems to give me 22A WOT (which isn't needed much in flight). I thought the Phoenix 35 was a little bit of overkill so I chose the Phoenix 25 as my second ESC.
Here's the test setup.
AXI2808/24 with APC 10x6E prop
Deans Ultra Connector on battery side of ESC
Kokam 3S 2000mAh (15C) or Apogee 3S 2480mAh (10.5C)
Medusa Power Analyzer in series between the battery and the ESC.
No servos connected to the receiver.
I initially had my ESC connected to the motor with Sermos Connectors. After the initial observation of a hot ESC, I tried soldering directly to the AXI leads.
I find that if I open up the throttle to read ~5A current draw on my power analyzer, the Phx25 gets almost too hot to touch after about 10-15 seconds of running. 5A corresponds to about 1/4 throttle on my setup. At one point I decided to try changing the programming to make sure the current limiter was "very sensitive" and to try different timings. With the ESC still quite warm, I removed power, moved the stick to full throttle, and reapplied power. The LED would flash, but there'd be no beeps to get me into programming mode. However, if I went to low throttle at this point, I could arm and start the motor. After leaving the ESC for a couple minutes to cool, I found that I could again get into programming mode properly.
As I mentioned above, I initially had connectors between my ESC and the motor. My connectors appeared to be fully engaged, and the motor behaved fine other than the ESC getting hot. In any case, I removed the connectors and tried soldering straight to the motor leads. The ESC still heats up pretty quick.
Just for comparison, I tried running the AXI at 5Amps current draw with my Phoenix 35. It stayed stone cold. I've had probably close to 100 flights with these motors and the Phx35 with good performance and endurance, which leads me to believe that the motors are probably Ok (i.e. no strange shorts in the windings, or high resistance).
I think I'm using fairly new firmware. Like I mentioned, I ordered the ESC last week, and it arrived Friday. It has the Auto-lipo LVC feature which my PHX35 does not have.
I read some of the other problem reports on the forum, and tried to pre-emptively answer most of the questions you guys ask
Does the ESC normally get hot when running at low throttle settings? I haven't flown this ESC yet, because I'm worried about an overheat/shut down in flight.
Thanks for your help.
Tom
