Old Apr 02, 2005, 11:15 AM
mauiguy99's Avatar
Kahului, Hawaii, United States
Joined Jul 2003
How do I charge a small nimh rx pack?
whats the best way to charge these tiny packs. say 110 nimh. how low a current should you use. what are some of the available charges that can do the job. Will the wall wart Says 50 mah but puts out more I think) kill the pack?
mauiguy99 is offline Find More Posts by mauiguy99
Old Apr 02, 2005, 04:15 PM
Upland, CA
Joined Mar 2004
Get a Sirius 200 charger. Built like a tank and completely hands off.
Sirius Charge 200
briandlg is offline Find More Posts by briandlg
Old Apr 02, 2005, 07:29 PM
Gadsden RC Flyers
Jack Stephens's Avatar
Joined Aug 2004
Mauiguy99
I have always had good results following the battery guidance provided by Radical RC at http://members.aol.com/davthacker/nimhfaq.htm. See the info at the bottom of that page titled "Your New Battery Pack".
No matter what fast/field charger you select, it probably should not be your only charger. In addition to my field charger (Astro Flight 110D), I use an Ace DDVC for my small packs to do the forming charge (C/10) and overnight charging where fast charging is not required.
Jack Stephens
Jack Stephens is offline Find More Posts by Jack Stephens
Old Apr 02, 2005, 08:32 PM
Registered Billy
Louisville, KY
Joined Dec 2003
I second the Sirius Charge 100 or 200, just plug in and no worries about overcharging.
bkopke is offline Find More Posts by bkopke
Old Apr 02, 2005, 08:51 PM
The lift is out there....
barefootbass's Avatar
Gunnison, CO
Joined Jan 2005
You can also go to the ezone site and under their FAQ's there are excellent answers to battery questions. 50 ma will not damage a 110mah pack too much. Any time you charge a pack you damage it somewhat. As a rule of thumb for trickle charging (slow) use a chage rate of 1/10 the pack capacity ie. a 110mah pack would slow charge at 11ma for approx 12 hours. For fast charging go 3x the pack capacity or 330ma for the 110mah pack which should take 15min to charge. Fast charging will shorten the life of the pack but is less likely to cause cell memory (nicad) or cell reversal and other nasty problems.
barefootbass is offline Find More Posts by barefootbass
Discussion How long to charge my NiMH pack? dalglish Batteries and Chargers 1 Jul 16, 2006 04:55 AM
Question How to charge NiMh Rx pack? abenn Batteries and Chargers 3 Jun 13, 2005 10:42 AM
How Do I measure resistance in a battery pack? Rob0101 Batteries and Chargers 8 Oct 24, 2002 02:52 PM
How to slow charge your NiMh packs? Tom Viper Electric Heli Talk 9 Dec 03, 2001 12:55 AM
