| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
COZY Mk IV Canard Semi-Scale Foam Scratch Build
Hi all,
I've maiden my scratch-built COZY Mk IV Canard plane on 5th of March 2005, it is an all-foam construction except balsa canards. 2 units of 0.7kg/cm torque blue arrow aileron servos and one 1kg/cm torque canard(elevator) bluebird servo, main wing is 2 pieces of 5mm compressed foam from a local art shop with 5mm dia. CF tube embedded across inside. Powerplant: Himax 2025/4200kv BL motor mated to Tamazo 4:1 gearbox, Aeronaut 9.5X6 white prop Amps draw = 13.2amps WOT Etec 1250mAh 3S li-po battery(92 grammes) Unbranded 18amps Brushless ESC. Cruises at 50% throttle, mildly aerobatic ![]() Flight duration = 11 minutes plus AUW without flight battery = 728 grammes 1st Video below: http://www.rcgroups.com/gallery/show...cat=500&page=1 2nd video below: http://www.rcgroups.com/forums/showt...33#post5080300 FREE Plans Download Here TILED and NON-TILED versions are also found here http://www.parkjets.com/cozy.html --------------------------------------------------------------------- Hi all, i've also finished drawing the Velociraptor (Long-EZ) and someone have built and flown it over at this thread:- http://www.rcgroups.com/forums/showthread.php?t=428393 Last edited by Steven Wong; Feb 22, 2006 at 12:30 PM. Reason: Re-edited the video. |
#2 |
some more pics...
that's my 10-yr-old daughter Daena with the Cozy and F-15 (Jetset44's design)
#3 |
inverted passing by the moon
AUW = 760 grammes, Cozy's happy just being white
#4 |
Excellent job, Steven! Looks very scale! Congratulations on your maiden.
Ron |
#5 |
Great work on the planes. The photograhy is top notch also. Are there any plans for this cozy available?
#6 |
Very nice looking plane. Any plans, or at least dimensions?
#7 |
Unicorn Pilot
I would be very interested in plans, dimensions, CG. And a question if you don't mind... do you have your canard set positive incidence from main wing?
#8 |
Thanks for the encouragement, seriously i didn't even think it could fly!
![]() Canards set at zero incidence, main wing also zero incidence, made of 2 pieces of 5mm depron foam with 5mm dia. C.F. hollow tube inside. Main fuse also made mostly of 5mm foam. Last edited by Steven Wong; Apr 05, 2005 at 08:23 AM. |
#9 |
Canards are made of 2 halfs of 5mm thick soft balsa CA'd and then sanded down to shape.
Blue Bird mini servo used for actuating canards, it's a full flying canard so it's not scale like the real one. Dia. 4mm CF hollow tube used for canards, running thru' dia. 5mm aluminium bearing tubes on both sides of front fuselage. A standard-sized futaba servo horn used, CA'd into place as shown in pic, another cut-down servo horn placed on the right side and CA'd too, to stop the CF rod moving about too much, 1/2mm of freeplay is ok. Will update more build pictures soon, Thanks for viewing
#10 |
In Thrust We Trust
Steven, beautiful plane! Wonderful job putting it together, craftsmanship and detail shows. I think building planes is therapeutic to you, an art where you take your time and contemplate every step. Just guessing, but a persons work reveals alot about the man himself. Congratulations!
#11 |
wow. nice plane. could use a plane like that. you have to visit Indonesia some time.
the guys would faint seeing that model. looks like you adopted jetsets construction method. ![]() adriel |
#12 |
Thank you for your kind words WaterDog
Yes Adriel, i adopted Steve Shumate's (Jetset44) construction technics Steve's a brilliant chap! Indonesia? why would they faint? (LoL!), yes Indonesia is just south of Singapore. Lovely country, beautiful place to go for a holiday though
#13 |
Cutting of main wings, in total 4 pcs of 5mm thick depron foam wing halfs were used, packing tape were laid inside the grooves cut by penknife so that the CF tube would spread out the load onto the foam.
Main wings were then sprayed with 3M Super 77 Spray glue, left for about a minute and placed gingerly together, this is the most tedious part,i must say Finally weight down with whatever i could find at that moment (chuckles!) 1/4 oz/sq. yard fibreglass cloth with finishing resin were then used to cover bottom of main wing and bottom of fuselage for added strength, rigidity and landings on grass, i'm not adding the scale landing wheels as i'm flying/landing on grass. If you could get any fibreglass cloth lighter than mine please do use it
#14 |
a peek into the installation of the canard servo arm, as well as the back of the fuse.
Foam cooling intake nacelles were added to the aft of the fuselage for cooling the ESC and motor. |
#15 |
The winglets construction, 5mm thick soft balsa on the outside, 2 pcs of 5mm thick foam on the inside,glued together with 3M Super 77 can spray, sanded down to form a curved inner surface, just like the real Cozies
30 mins epoxy used for glueing winglets to end of main wing. |
| Thread Tools | |
| Mini-Review Long EZE (Velociraptor) Foam Canard Pusher Scratch-Build | Steven Wong | Foamies (Kits) | 259 | Feb 06, 2010 11:26 PM |
| Build Log My First Foam Scratch-Build "Wisdom" | romranger | North Coast Electric Flyers | 10 | Apr 19, 2007 06:39 AM |
| Video COZY MK IV Canard Pusher | Steven Wong | Airplanes - Electric Videos | 1 | Oct 05, 2006 10:10 PM |
| Video Cozy MK IV Foam scratch-built 2nd Video | Steven Wong | Airplanes - Electric Videos | 9 | Mar 06, 2006 11:50 AM |
| Question Fokker DR1 - Scale model (Scratch build) | 0tigershark | Scale Electric Planes | 17 | Mar 04, 2004 05:38 PM |
