Old May 24, 2005, 01:32 AM
Corra is offline
Find More Posts by Corra
Hi Gerard
YES , variable incidence
YES
YES , 2 Lipo 450mA cells and the 5V tension regolator
FANTASTIC :-)
NO , task not to never use the ballat in Italy termal conditions
it is soon in order to draw conclusions :-)
Regards
Corra is offline Find More Posts by Corra
Old May 24, 2005, 02:16 AM
Corra is offline
Hi all
we have inserted the article and the photos, are not complete , but it can be useful
Regards
Corra
Old May 24, 2005, 01:04 PM
g.guasch is offline
Find More Posts by g.guasch
france
Joined Feb 2004
article in italian ...
I don't read at all Italian...
So, photos are very clean and explanation aren't veryuseful with them,
but for "in the air" feed back, if you could put some infos in English,
it should be very smart.
Enjoy your beautiful Taboo GT.
With ful flying elevator,
I guess it's perhaps the best DLG on the market...
Bye,
Gerard.
Originally Posted by Corra
Hi all
Regards
Corra
g.guasch is offline Find More Posts by g.guasch
Old May 25, 2005, 01:07 AM
Corra is offline
thanks for compliment , we would want to put of notes in English but the job is too much and we do not have much time to dedicate to us
in the next few days I will insert other photos , I am completing the system of implantation of the cover of the fuselage
regards
Corra
Bye,
Gerard.
Old May 25, 2005, 01:16 AM
g.guasch is offline
france
Joined Feb 2004
fly feedback
Cora,
Do you think that your Taboo is a better ship than the TURBO, in alround
waeather (dair air, windy days, and so)
I have a Turbo.
265 g DLG.
Very smooth, but I think that a little more dihedral angle should allow
cleanest "holding" small thermals.
And perhaps a little longer root chords.
Anyway, I prefer TURBO than Fireworks III,
because F III is a typical windy ship but a diificult DLG in calm days.
So, how is the climbing launch height of your Taboo ?
Near the same than Turbo ?
And the return in the wind ?
Thank's alot,
Bye,
Gerard.
regards
Corra
Old May 25, 2005, 02:32 AM
MGerstgrasser is offline
Find More Posts by MGerstgrasser
Austria
Joined Oct 2003
Gerard,
can't say anything about the Taboo but about your words on Turbo/Fireworks. I have flown several versions of both on contests and am still not sure, which one I prefer. Both are extremly good DLGs but with different strengths. Their possible performance is determined by piloting skills and preferences only. In my opinion, it is not possible to really say this one is better than that, because different pilots and conditions favour different properties.
If the Taboo is on the same level of perfection, then I would take any better/worse statement of a single person with a grain of salt.
Regards,
Matthias Gerstgrasser
MGerstgrasser is offline Find More Posts by MGerstgrasser
Old May 25, 2005, 04:16 AM
Corra is offline
Matthias has reason , does not exist the better model , but exists better pilot+model
the TabooGT is sure between the best ones to the world , perhaps in some conditions it is the best one , in others not
I have not still tried it in all the conditions , therefore I do not want to write mistaken things
Corra
Cora,
I have a Turbo.
265 g DLG.
Thank's alot,
Bye,
Gerard.
Old May 25, 2005, 05:53 AM
g.guasch is offline
france
Joined Feb 2004
You're right both
Yes, Matthias and Cora, you're right.
Feeling is very important with these top performance DLG.
But I wonder if 244 g Taboo GT climb nearly at the same high than these two winners, F III and Turbo ?
Here, it's not a feeling question, no ?
I know that high launching is not the key to have long flight,
but it's alway better to beguin a flight the most high possible...
Anyway, have-you noticed that one day a DLG model is great, and another day, with NEARLY the same weather conditions, the same model is just good, but not as great than this past day ?....
Hard to explain....
Or perhaps just shape and pilot concentration, in fact ?
Thank to you for these interesting discussion,
Bye,
Gerard.
Corra
Old May 25, 2005, 06:08 AM
Austria
Joined Oct 2003
Hi Gerard,
ahh, I misunderstood your question first. You were worrying about the launch height of such a light model, right?
I really doubt the common whisper about high weight giving high launches. It is not that simple [1]. The highest launch, I have measured so far with the logger with any of my planes was a 242g plane, thrown to 56m by my son David.
[1]: Higher weight will only give you slightly(!) higher launches, if the release speed can be held constantly high with increasing weight. As soon as your launch speed decreases because of not beeing able to accelerate the heavier model to the same speed, any possible benefit from the better drag/weight ratio will be rapidly eaten up by the square velocity term in the kinetic energy formula. I argue, that there is an optimum launch weight for a DLG that differs from person to person. In my case, it seem to be pretty low, maybe around 250g or below.
Old May 25, 2005, 06:45 AM
Corra is offline
In the next weekend I will try the drop heights with the RAM2 , my better heights with the FW3 and the XP4 are of 48mt ( FW3 260gr , XP4 280gr ) ..... I will make to know you
unfortunately the only direct comparison that I have had is with the Absalut , the TabooGT is better in all the conditions
I have flown little with the TabooGT , while it is the XP4 that the FW3 I know them very well
the first impression is that the TabooGT goes up in thermal better than all the models that I have tried , of this of they are sure , but us some month will want in order to know this model well and to be able to make of the obbiettive appraisals
Corrado
Old May 26, 2005, 11:58 AM
g.guasch is offline
france
Joined Feb 2004
elevator spring mounting ?
Cora,
Please, could-you put some pic(s) about the stainless rod ( 3/10 ?) return
pre-loaded spring mounting of your all moving elevator system ?
Have-you got the Blaster system directly from Vladimir Gravilko ?
All the best,
Gerard.
Old May 27, 2005, 12:53 AM
Corra is offline
the system is the same one of my XP4
http://www.f3k.it/2005/index.php?set...bum.php&page=5
yes directly from Vladimir Gravilko
regards
Old May 27, 2005, 05:34 AM
g.guasch is offline
france
Joined Feb 2004
elevator spring mounting and tail drawing
Thank's a lot, Cora.
The internal hole of the Blaster system fit exactly with the external Taboo GT boom ?
If I decide to order a Taboo GT not soon, but not in a very long future,
and decide to do the same tail mounting like you,
do-you think that it'll be possible to get your elevator and fin drawing ?
It should be very smart from you
regards
Old May 27, 2005, 06:23 AM
Corra is offline
we continue the conversation in private , it sends your address email to me
corraconti@yahoo.it
regards
Corrado
HP-14 Feed Back SoCalGliderFlyr Scale Sailplanes 64 Nov 21, 2013 05:02 PM
Nesail: Tuff-E, EPP PLANE (feed Back , Videos???) Extra 3D 3D Flying 0 Aug 12, 2004 08:12 PM
Feed back on lipos dave morris Batteries and Chargers 1 Jul 25, 2003 02:57 PM
any feed back on Kokam 1200hd dave morris Batteries and Chargers 4 Jun 26, 2003 12:55 PM
desktop cnc , feed back before purchase gruntdog The Builders Workshop 9 May 04, 2003 06:53 AM
