Old Mar 30, 2005, 08:47 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
My attempt at x plane (my own version)
Here is a couple of pictures of a scratch built jet Im working on. What do you think.
unclecrash is offline Find More Posts by unclecrash
Old Mar 30, 2005, 09:11 PM
killerkiwi5 is offline
Find More Posts by killerkiwi5
Beware of the Kiwi
killerkiwi5's Avatar
Chilliwack, BC
Joined Jan 2004
Very Nice! Specs? Motor/Battery?
killerkiwi5 is offline Find More Posts by killerkiwi5
Old Mar 30, 2005, 09:16 PM
Excogitate is offline
Find More Posts by Excogitate
The Young Man
Excogitate's Avatar
Joined Mar 2005
Very cool!
eX
Excogitate is offline Find More Posts by Excogitate
Old Mar 30, 2005, 09:31 PM
unclecrash's Avatar
white lake michigan
I probably will start with a Mega 2 turn and a T.P. 3s2p 4200mah. Then if it does alright I might put something in the way of 600watt. Heres another picture. The build will be slow its kind of been on hold now that spring is in the air got some steelhead to go catch and an F35 to test out. Plus Im going through a lot of family issues at the moment.
Old Mar 31, 2005, 07:33 PM
unclecrash's Avatar
white lake michigan
I did a bit of work on my plane. I rounded the sides off back to the ducts. and finished off the nose.
Old Mar 31, 2005, 08:53 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Nice! Kind of resembles the F-22.
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Mar 31, 2005, 09:38 PM
unclecrash's Avatar
white lake michigan
Thanks I had three planes on my mind when I drew it up The nose of the sr71 the ducting kind of like the skyray and the wing of the yf23
Old May 02, 2005, 09:34 PM
unclecrash's Avatar
white lake michigan
I have made a little progress on my plane putfan in,servos,wiring,and built the tail feathers.heres a couple pictures
Old May 02, 2005, 10:51 PM
duhaas88 is offline
Find More Posts by duhaas88
Las Vegas
Joined Jun 2004
How did you do that ducting? was it vacuum formed or the lost foam technique? it looks really good I can't wait to see this bird all finished
duhaas88 is offline Find More Posts by duhaas88
Old May 02, 2005, 11:11 PM
unclecrash's Avatar
white lake michigan
Thats just poster board. It wasn't easy. Its three sections I started at the fan and worked my way forward a lot of trial fitting and redoing. I started with a piece oversized and trimmed until it fit. I will start posting more pictures as I build. Its been on hold for a while had to get back to work so I could buy what I needed. Next I am going to cut some foam cores for the wings. Dave
Old May 16, 2005, 12:12 AM
unclecrash's Avatar
white lake michigan
Did a bit of work on my plane started on the canopy. planked the back hatch and a bit around the canopy so I could shape the canopy to it.
Old May 17, 2005, 09:48 PM
unclecrash's Avatar
white lake michigan
hey I just finished glassing over the foam on the canopy . I was thinking of melting the foam out. Never done the lost foam method . Im wondering if the balsa formers in picture 11will be ok after I melt the foam with gas? I guess it does not matter I can always make a new base and formers if I have to.
Old May 17, 2005, 10:48 PM
rcjetpilot is offline
Find More Posts by rcjetpilot
Bot's like to know where you live
Joined Sep 2003
Looking good!
Dunno how the wood would hold up, why not paint the canopy high gloss blue?
I might of missed this, whats the length / width?
Bob.
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Old May 17, 2005, 11:06 PM
unclecrash's Avatar
white lake michigan
Thanks Bob length 39in. width 26in. ya I guess theres really no need to melt the foam out there's plenty of room for all the batteries and components. Plus it probably will be pretty messy getting the foam out. painting sounds like the way to go.
Old May 19, 2005, 09:44 PM
Joined Sep 2003
Very nice!
I was looking through your posts and the fan location seems a bit forward. I was wondering if the CG might be hard to obtain? Though it looks like the area in front of the duct split gives you more room to shift things around.
Keep the pics coming
Bob.
Build Log Lindberg's PT Boat (my own version) revised 26/08/07 more pic shipcollector5 Scale Boats 80 Mar 16, 2015 11:58 PM
My first attempt at building and converting a Guillows to a RC plane gwong Scale Kit/Scratch Built 40 Nov 01, 2006 04:39 AM
My first attempt at my own plane JPA2002 Foamies (Kits) 14 Mar 07, 2004 09:33 PM
My first attempt at a fan-fold plane... EMFB Foamies (Kits) 8 Jun 06, 2003 12:30 AM
My first attempt at weathering a plane flipnidaho Scale Kit/Scratch Built 8 Jan 18, 2003 01:51 PM
