| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Laptop LCD screen problem
I have a laptop that has been WELL used. My daughter got a hold of it and was pushing the screen back and forth and now the screen only works when it is almost closed to about 45 degrees open. Any more and it goes blank. I opened it up thinking that it had some kind of switch to turn the screen on and off. I could find no switch at all except i the case of the computer where the close latch engages. Could the screen be damaged? Seems that if it was it wouldn't work at all. Anoyone have any ideas of anything to check? It is a Compaq 1240 Laptop with 15' LCD screen. Not a big loss, I'm just curious to see what is wrong.
#2 |
There is a ribbon connector from the screen to the board. Pretty delicate.
#3 |
I saw the connector, it goes through a fitting. Didn't think about that getting pinched though. Have to check that tomorrow.
#4 | |
The original Flyin Pigs Sqd.
#5 |
It may not be pinched, just has to be fatigued. If you have a multi-tester, you can check for continuity from pin-pin.
Dave |
#6 |
You will be assimilated!
I would bet the ribbon was just slightly moved out of place. I had a similar problem with my iBook a while back. Thankfully I was able to have it repaired for free.
| Thread Tools | |
| Help! Spektrum DX7 LCD screen problem | GotrekGurnisson | Radios | 14 | May 29, 2007 08:01 AM |
| LCD screen losing it - can I get parts? | Flyfan | Hitec/Multiplex USA | 5 | Jan 24, 2005 11:51 AM |
| Alert Futaba 9C LCD Screen Going Blank | dano310 | Radios | 6 | Nov 15, 2004 03:33 PM |
| wireless baby monitor with lcd screen | easy2fly | Aerial Photography | 1 | Aug 02, 2004 04:04 PM |
| Alert RoyalEVO screen problem | Txakal | Hitec/Multiplex USA | 1 | Jul 23, 2003 02:19 PM |
