Old Mar 28, 2005, 06:41 PM
ukgroucho is offline
Find More Posts by ukgroucho
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
How to measure head speed (on my own)
Want to measure the head speed on my Trex.
I have a head speed gauge - point it at the blades and it shows 10s of RPM.
Can I do this on my own or do I need an accomplice to hold the heli
i.e. could I just set a 0 pitch curve, spool up on the ground, and check the speed at different throttle settings? What should I be looking for at 50% throttle - or should I be interested in head speed at a different throttle setting (60%?).
If pitch is required then I guess I need to hold the heli down somehow.... any suggestions?
ukgroucho is offline Find More Posts by ukgroucho
Old Mar 28, 2005, 07:32 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
I have a "testing 2x4" that I put through the skids of helicopters when I tach them.
You'd need something smaller for a T-rex, though.
Be sure to weight both ends with something heavy, like a cinderblock.
Toshi
TMorita is offline Find More Posts by TMorita
Old Mar 29, 2005, 11:37 AM
OmegaDot is offline
Find More Posts by OmegaDot
Upstate NY
Joined Nov 2003
If I didn't have an "accomplice" to hold the heli, I would weight the heli down as Toshi said. I use a piece of 1 x 4 pine through the skids and a couple of bricks (out beyond the radius of the rotor). I also tape the tach to something and place it under the rotor so I have both hands free. Then I can stand at a safe distance from the heli with both hands on the Tx (ready to cut power if needed).
It would really stinks to lay on your belly holding the tach and then knock over the TX and have the throttle stick get jammed up!!!
BTW: I have an analog tach that doesn't have the greatest meter resolution, so I read under the blades and paddles and then divide the results by 2.
OmegaDot is offline Find More Posts by OmegaDot
Old Mar 29, 2005, 05:25 PM
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
Thanks, I tried this briefly today and was able to measure the head speed (I think).. not too happy with what I saw (only 1200 RPM if I believe the tacho!). Cannot help but think something was not right as it flies OK so must be getting more like 2000 rpm I guess.
Weather permitting I'll try again tomorrow.
Old Mar 29, 2005, 09:12 PM
dbcaster is offline
Find More Posts by dbcaster
Petaluma, Ca
Joined Nov 2004
You can test your tach by pointing it at a flourescent light. You should read 3600.
dbcaster is offline Find More Posts by dbcaster
Old Mar 29, 2005, 10:06 PM
Kai_Shiden is offline
Find More Posts by Kai_Shiden
Crazy Heli Technogeek
Kai_Shiden's Avatar
USA, WA, Seattle
Joined Sep 2004
It sounds like it may be setup for 3 bladed prop mode, that would put it at 1800RPM (1.5x1200RPM). dbcaster has a very good suggestion for checking.
-Kai
Kai_Shiden is offline Find More Posts by Kai_Shiden
Old Mar 30, 2005, 04:26 AM
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
I think it was set for 2 blades - it toggles 2 - 3 - 4 - off using the one button on it.
Flurescent light showed 3000 BUT I was maybe 8 or 10 feet from it (only flourescents are in the room of my garage) and I'm not sure if the 3600 thing changes if you're on 240 volts (UK)
Old Mar 30, 2005, 08:18 AM
Paul G is offline
Find More Posts by Paul G
I geta press the butt'n..
Paul G's Avatar
You may find it is 3000 in the UK as we're on 50hz mains as apposed to 60hz in the US which would give 3600 (or about a 17% difference).
Paul G is offline Find More Posts by Paul G
Old Mar 30, 2005, 09:11 AM
martinic is offline
Find More Posts by martinic
FPV Enthusiast
martinic's Avatar
New Brunswick, Canada
Joined Nov 2004
I just hold my trex firmly by the frame and hold it above head level (to avoid injury should something let loose) and then spool it up to my desired throttle point - I then check the RPM with the optical tach. This needs to be done outside (for the optical tach to read properly and just in case you accidently let go!).
I don't think that the stock Trex will lift off at much less than ~1600 RPM - if your tach is reading much less, then it's either the tach or your technique. Don't forget about the paddles - you want your tach on 2 blades to be measuring the blades, not the blades and paddles.
martinic is offline Find More Posts by martinic
Old Mar 30, 2005, 03:55 PM
ovaltine is offline
Find More Posts by ovaltine
Oz Micro Antenna Maker
Melbourne, Australia
Joined Jun 2004
please ignore
ovaltine is offline Find More Posts by ovaltine
Old Mar 30, 2005, 04:01 PM
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
Good thinking.. It was late when I posted, I worked out that different power might make a difference (110 V / 240v) but just had not thought about the frequency difference. Add up just right.
So... good news is the tacho works OK. Had to be technique 'cos the Trex definitely flies. Maybe if the weather is better tomorrow I can get outside and try again.
Discussion How to increase head speed on Trex? jmdombr Mini Helis 7 Apr 24, 2006 10:09 PM
hey Guys how can Increase performance on my GWS planes?ie diffrent motor etc? jayboy Parkflyers 10 Mar 19, 2003 10:52 AM
How do i put the brake on my Jeti ESC fuzz Power Systems 2 Nov 29, 2002 11:53 PM
Measure Head Speed with Cycle Tachometer wayne Electric Heli Talk 1 Mar 08, 2002 10:38 AM
Trying to learn on my own"HELP" Dandi6065 Electric Sailplanes 68 May 14, 2001 07:15 PM
