Old Mar 29, 2002, 11:11 PM
J R Purcell is offline
Find More Posts by J R Purcell
Longview, Washington, USA
Joined Sep 2000
Frozen engines
What would be the best liquid to soak a frozen engine in to free it up.
Thanks in advance
John
J R Purcell is offline Find More Posts by J R Purcell
Old Mar 29, 2002, 11:50 PM
Steve H. is offline
Find More Posts by Steve H.
Zebulon, NC
Joined Aug 2000
If its just frozen from fuel residue, put it in the oven at around 150 for a few minutes, it will free it right up.
Steve H. is offline Find More Posts by Steve H.
Old Mar 30, 2002, 01:13 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Just soak it in glow fuel for a few hours or overnight. This should free it up enough to get it apart. Clean the bearings thoroughly before running and make sure they spin free.
DaveSawers is offline Find More Posts by DaveSawers
Old Mar 31, 2002, 12:12 AM
Dsegal is offline
Find More Posts by Dsegal
Dave Segal
Philadelphia PA USA
Joined Jun 2001
Check out the April issue of Model Aviation for how to use lacquer thinner to free up an engine.
Dave Segal
Dsegal is offline Find More Posts by Dsegal
Old Apr 10, 2002, 04:20 PM
Taylorcraft is offline
Find More Posts by Taylorcraft
Gravity "vacuumizes"!
Taylorcraft's Avatar
Sweden
Joined Mar 2002
I agree with Cue.
I've seen a couple of stuck engines over the years, heat will loosen the grip. Then, when you get the engine out of the oven, offer it a generous ammount of WD-40 to really dissolve the goo and then dismantle and check the bearings.
While you're at it, clean all parts with WD-40 and ensure all the goo is gone before assembly. When putting it back together, use WD-40 to lubricate the piston/sleeve and all other parts that will rub against eachother.
This ought to solve your problem.
Solvents also do a good job, but ensure you have a well ventilated workspace when using them! *nag, nag, nag*....
BRG
Taylorcraft
Taylorcraft is offline Find More Posts by Taylorcraft
Discussion Frozen Engines KOBRA Engines 6 Jan 17, 2007 04:59 PM
