Old Mar 28, 2005, 09:33 AM
Bonez is offline
Find More Posts by Bonez
Bonez's Avatar
Moorpark, CA
Joined Oct 2002
How to get a smooth finish on foam?
I would like to have a smooth surface on my GWS foam planes. I have read about a few methods including covering with iron-on monocoat type material or glassing with fiberglass and Minwax. Both methods also offer strength enhancements. However, I use carbon fiber internally to add strength - therefore added weight of the above methods is not desireable.
What other method is there to fill in the foam texture to allow a nice smooth paint finish?
Thanks.
Bonez is offline Find More Posts by Bonez
Old Mar 28, 2005, 10:23 AM
kenny_dilger is offline
Find More Posts by kenny_dilger
United States, IN, Evansville
Joined May 2001
Have a look at the latest Concrusher thread. There is a post in there (last couple of pages) which describes using carbon fiber tissue with a mixture of water/welbond glue (basically white glue). Sounds promising...
Edit:
Here it is... http://www.rcgroups.com/forums/showp...&postcount=138
kenny_dilger is offline Find More Posts by kenny_dilger
Old Mar 28, 2005, 11:01 AM
tony postle is offline
Find More Posts by tony postle
Saint Cloud Municipal, Minnesota, United States
i just got done with a gws p-51,i used foam putty for train layouts,works very well and it is very lite.then i also added a few drops of water and painted it on,then just sand smooth with 320 or 400 grit.working in a hobby store i've tried many things,but the foam putty worked the best.
tony postle is offline Find More Posts by tony postle
Old Mar 28, 2005, 02:23 PM
Bonez is offline
Bonez's Avatar
Moorpark, CA
Joined Oct 2002
Tony
Do you have a specific foam putty product name and manufacturer?
Discussion Shrink wrap a fuse repair (or how do you get a smooth finish without sanding?) soholingo Composites Fabrication 6 Jul 06, 2006 09:31 AM
How to get the best finish on a foam model bluespier Foamies (Kits) 12 Jul 14, 2003 03:11 PM
How to get consistent power on the bench? ClayH Power Systems 5 May 18, 2003 08:51 PM
Smooth Finish on Foam? kepople Electric Plane Talk 6 Jan 16, 2002 12:59 AM
Getting smooth finish on Foam? kepople Scale Kit/Scratch Built 3 Jan 13, 2002 02:33 AM
