Old Mar 28, 2005, 12:14 AM
tsunami is offline
Find More Posts by tsunami
tsunami's Avatar
United States, CA, Victorville
Joined Apr 2004
Converting coordinate data onto cad
im not shure were this would go but i want to know how to convert the dat #'s onto a quick cad file for easy .dxf use. how do i use the numbers to do this?
as an example here is the dat from MArk's AG 36 foil
AG 36
1.000003 0.002671
0.993991 0.003641
0.983912 0.005266
0.972030 0.007181
0.959208 0.009247
0.946050 0.011369
0.932962 0.013479
0.920159 0.015543
0.907668 0.017556
0.895474 0.019522
0.883699 0.021360
0.870771 0.023227
0.857975 0.025012
0.845188 0.026795
0.832275 0.028596
0.819232 0.030415
0.806149 0.032241
0.793050 0.034067
0.779976 0.035891
0.766906 0.037713
0.753833 0.039537
0.740771 0.041359
0.727741 0.043176
0.714758 0.044986
0.701919 0.046776
0.689366 0.048527
0.677377 0.050200
0.664649 0.051879
0.652447 0.053315
0.640918 0.054568
0.628145 0.055906
0.615243 0.057187
0.602241 0.058477
0.589040 0.059787
0.575726 0.061108
0.562405 0.062429
tsunami is offline Find More Posts by tsunami
Old Mar 28, 2005, 08:33 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
This may not be exactly the help you're looking for but it works great and is real easy.
The program is awesome, really awesome and for the money you won't find anything else better, it's like $15.
All you do is select the airfoil you want, select export to .dxf, go to your CAD program then select import and you're done.
Curtis
Montana
PS I'm not affiliated with Profili.
http://www.profili2.com/eng/default.htm
Curtis Suter is online now Find More Posts by Curtis Suter
Old Mar 28, 2005, 03:32 PM
tsunami is offline
tsunami's Avatar
Joined Apr 2004
ill look into it but i wanted to know if theirs a way to do it without a mid prgram, alos since my pc is already getting cluttered with programs i rarly use, i want ot be able to just sit down and do it for a few hours so i have them in dxf format
Old Mar 28, 2005, 05:14 PM
ScottLister is offline
Find More Posts by ScottLister
Lebanon, Maine
Joined Nov 2004
Those are just x-axis and y-axis coordinates. Just type them into you cad system as points then create curves or use a polyline to outline the airfoil. When you need it just scale it up to the correct chord length.
Scott
ScottLister is offline Find More Posts by ScottLister
Old Mar 28, 2005, 06:52 PM
tsunami is offline
tsunami's Avatar
Joined Apr 2004
i see, thanx ill try it tonight
Old Mar 31, 2005, 02:22 AM
wildshark is offline
Find More Posts by wildshark
wildshark's Avatar
Roma, Italy
Joined Jan 2004
take a look also on RCSD March magazine
http://www.b2streamlines.com/RCSD-2005-03.pdf
Bye
wildshark is offline Find More Posts by wildshark
Old Mar 31, 2005, 04:34 PM
bgriggs is offline
Find More Posts by bgriggs
Make something. Anything!
bgriggs's Avatar
Syracuse Hancock, New York, United States
Joined Jul 2003
Tsunami,
Basically this is how it is done.
The left hand column of numbers are percentages along the airfoil, starting at the trailing edge. The numbers as you see them will allow you to plot a 1" airfoil if you plot them exactly as described.
The numbers proceed along the top of the airfoil to the leading edge (numbers in the left column begin to approach zero) they then proceed bottom of the airfoil towards the trailing edge (numbers in the left column approach 1). To get a bigger airfoil scale the foil up in cad.
Bill
bgriggs is offline Find More Posts by bgriggs
Old Apr 13, 2005, 07:37 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
My way:
I open table (dat file with airfoil coordinates) in WordPad. I change space between coordinates with comma, using Find&Replace command.
Then I wrote Pline on the top of the first row.
Then I save this file as name of the profile.scr (as txt file)
I open AutoCad.
I close "Osnap" not to be active.
I type the command: Script
I browse to the airfoil file name of the profile.scr
This command will read the data of this scr (script) file and draw a nice airfoil. To smooth the airfoil, you can use "Polyline Edit" command and choose "Fit Curve" option.
Then I scale up (or down) the airfoil to lenght that I will use further, depending of the wing...
Of course, not to forget to save airfoil drawing eather as wg od dxf file type
It is simple and easy solution.
The scr file should look as shown bellow:
Pline
1.000003,0.002671
0.993991,0.003641
0.983912,0.005264
.....etc....
Mitja
ultralajt is offline Find More Posts by ultralajt
Old Apr 13, 2005, 10:45 AM
dborros is offline
Find More Posts by dborros
Fort Wayne, Indiana
Joined Jun 2004
Ultralajt,
Thanks for the input! I was wondering if there was an easy way to do that with the data file for autocad. I'll give it a try!
Doug
dborros is offline Find More Posts by dborros
Old Apr 13, 2005, 11:23 AM
tsunami is offline
tsunami's Avatar
Joined Apr 2004
wow. that sounds like a much eisier way to do it. thanx, im at school right now so i cant try it maybe at lunch.
Old Apr 18, 2005, 05:11 PM
tsunami is offline
tsunami's Avatar
Joined Apr 2004
O-o hnn, doesnt seem to work with Qcad, Script prompt doesnt start a subsytem, and i tired looking for a way to insert the file with no luck
Old Apr 22, 2005, 07:37 PM
Hogwash is offline
Find More Posts by Hogwash
Devon UK
I think this is what your after.
ConCord
Its a small free program. It will convert airfoil data to and from many formats.
Ive used it many times to produce DXF etc for Solidworks and Autocad.
Vince
Hogwash is offline Find More Posts by Hogwash
