Old Mar 27, 2005, 11:07 AM
Tug Lover is offline
Find More Posts by Tug Lover
Tugs & Bugs
Bronx NY
Joined Mar 2005
which way should the prop?
Which way should the prop spin?, i am not sure if its clockwise or counterclockwise, let me know anyone, thanks!
Tug Lover is offline Find More Posts by Tug Lover
Old Mar 27, 2005, 11:22 AM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
That depends on whether it's a right hand or left hand prop. A right hand pitch prop will turn clockwise to move the boat forward. In the picture, the prop on the left is a left hand pitch prop; the prop on the right is right hand pitch.
CG Bob is offline Find More Posts by CG Bob
Old Mar 27, 2005, 11:37 AM
Tugs & Bugs
Bronx NY
Joined Mar 2005
Thanks CGBOB, i have a left handed prop, so it should be spinning counterclockwise then, correct?...Ivan!
Old Mar 27, 2005, 02:50 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
United States, MI, West Bloomfield Township
Joined Dec 2004
Depends on whether you're observing from front or back!
If in doubt, look at the prop's blades and imagine them as threads on a screw (they also call props "screws", right?). As you turn the prop, which way makes it want to "screw" into the water in the forward direction?
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Mar 27, 2005, 02:52 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
easy way to tell, fit the prop, get it spinning in air, with the stick on all ahead full, and put ur palm of your hand 6 inches away from the stern of the boat, if you feel a draught, its the right way as its pushing air to the back of the boat, and so newtons law says the boat will move forwards
Ghost 2501 is offline Find More Posts by Ghost 2501
Overlord - which way should motor turn? borgs Flying Wings 2 Sep 15, 2005 05:48 PM
which way should the tail go??? ctshaynes Micro Helis 6 Oct 21, 2004 07:46 AM
Which way should my prop turn? Mr.Dickles Power Systems 2 Apr 19, 2003 12:35 AM
which way should prop turn Rugerman Power Systems 7 Dec 22, 2002 09:23 PM
Wingo Porter - which way should the engines spin? pgesler Parkflyers 1 Jun 15, 2002 10:53 PM
