Old Mar 29, 2002, 01:28 PM
joey221 is offline
Find More Posts by joey221
suffering gravity surge
joey221's Avatar
Westminster, CO
Joined Oct 2001
"no-load current" -- what does it mean?
<newbie alert on>
If my soarer is soaring with the motor stopped and the prop folded, if the "no-load current" still flowing? Or does it mean that the motor draws x amps when it's running full-speed and spinning with nothing attached to the prop shaft?
This electric stuff just gets curiouser and curiouser!
<newbie alert off>
Joe
joey221 is offline Find More Posts by joey221
Old Mar 29, 2002, 02:04 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The second one.
No load means the motor is running with no load - no prop or other load attached.
..a
Old Mar 29, 2002, 02:54 PM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
The stopped motor should not draw current. The speed control and servos will continue to draw current however, if the receiver is on.
If the motor were to run without a prop, that amount of current will be considerd - no load current.
poobs is offline Find More Posts by poobs
Old Mar 29, 2002, 03:49 PM
joey221 is offline
joey221's Avatar
Westminster, CO
Joined Oct 2001
Thanks!
I have to say, that since I started lurking here, my attitude about fellow modelers has improved. Most every post I've seen on these forums has been informative and non-judgmental.
For that also, thanks!
Joe
Discussion :Full range"...what does this mean? Rusty-Gunn Beginner Training Area (Aircraft-Electric) 29 Apr 08, 2016 06:48 PM
When Axi says "with authority" what does that mean? MGBGTRacer Power Systems 6 Jan 18, 2005 04:00 PM
"D-tube wing structure" - what does it mean ? oded mazor Electric Sailplanes 2 Mar 05, 2002 09:56 AM
Question "balloon" what does this mean? omega blood Parkflyers 14 Jan 26, 2002 11:28 AM
Flashes inside S280 what does it mean? JoeR Power Systems 3 May 24, 2001 11:04 PM
