Old Mar 26, 2005, 09:00 PM
mdttb is offline
Find More Posts by mdttb
mdttb's Avatar
United States, CA, Stanton
Joined Jan 2004
Sneak Peek for what's next from SP
An aluminuim horizontal fin bracket for the T-Rex. Nothing fancy well maybe have them anodized. Still in the works.
mdttb is offline Find More Posts by mdttb
Old Mar 26, 2005, 09:54 PM
Hoverup is offline
Find More Posts by Hoverup
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
More goodies. HoooooHaaaaa.
Hoverup is offline Find More Posts by Hoverup
Old Mar 26, 2005, 11:22 PM
Mod-junkie is offline
Find More Posts by Mod-junkie
You win again Gravity!
Mod-junkie's Avatar
AZ
Joined Dec 2004
Ohh Boy more bling
Mod-junkie is offline Find More Posts by Mod-junkie
Old Mar 27, 2005, 01:34 AM
wildstallion is offline
Find More Posts by wildstallion
wildstallion's Avatar
Joined Dec 2003
I found using the little hook at the end saws through the cf rod due to mild vibrations, I had to cut mine off.
wildstallion is offline Find More Posts by wildstallion
Old Mar 30, 2005, 11:46 PM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
Here's a Polished one. Anodized coming soon est April 6th
Old Mar 30, 2005, 11:59 PM
tomi is offline
Find More Posts by tomi
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
YES!! finally!!! I hate the plastic ones. They keep on breaking. I'm hate buying the tail feather replacements just for that little peice. I now fly without the boom brace but I really want that aluminum one...sweeeeet!
-Tomi
tomi is offline Find More Posts by tomi
Old Mar 31, 2005, 12:11 AM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
-Tomi
Tomi sent you a PM
Old Mar 31, 2005, 01:54 PM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
Limited supply of non anodized T-rex Tail Fin Mount
Old Mar 31, 2005, 02:15 PM
dogon1013 is offline
Find More Posts by dogon1013
Watts Rule, Glows Drool
dogon1013's Avatar
orlando, FL
Joined Mar 2003
Any chance you can put that small drilled hole in there too. (just above the hook, like the original piece). I use that hole for my Antenna.
Also might want to think about Lightening the design some too. I'm not to keen on adding weight to the tail area. Since it's aluminum you should be able to thin it up some. (don't know if you can lighten it much though)
dogon1013 is offline Find More Posts by dogon1013
Old Mar 31, 2005, 02:17 PM
will p3 is offline
Find More Posts by will p3
Joined Aug 2003
If this part actually had an effect, it would proably be more suited to being made out of delrin as aluminium and carbon rubbing against each other is not a good comination for friction reduction.
Also being metal against metal(the boom), that will be the first place the boom snaps or breaks when pressure is at its maximum.
I feel this this is more bling than ding, my 2 cents worth!.
will p3 is offline Find More Posts by will p3
Old Mar 31, 2005, 02:23 PM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
dogon
It's actually thinner then the stock piece.
Old Mar 31, 2005, 02:30 PM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
Will
I had alot of request to make this part out of aluminium because people were breaking the stock one and had to buy the whole tail fin package, only to have to replace it again when it broke. The weight differrence is a gram. I've had booms bend at the place in question using the stock plastic piece.
Your entitled to your opinion.
Old Mar 31, 2005, 02:52 PM
will p3 is offline
Joined Aug 2003
Thanks! as you, and yes this is a nice looking part but does it actually do anything ?other than hinder the pushrod, if the pushrod is to flexy then maybe lighter and more effectice to way solve this problem would be with a thicker pushrod.
I,m not against shops making money at every available twist and turn but it seems the punters really are hooked if they are buying an upgrade to a part that has no effect in its stock form anyway or even maybe considered a hinderance.
I notice on the trex the designers have incoperated some "bigger heli feature" like the fake screw knobs on the skids and this part also i suspect!, for the length and strength used in this chopper i would highly doubt that the pushrod needs any support as the strength in the rod is vertical and this part if performing a function would only serve to confuse the gyro.
If the people want them by all means make them, i am just using the topic as a extension to my hobbie as its the way these things work that interest me.
I dont think i will be using mine.
Old Mar 31, 2005, 03:06 PM
mdttb is offline
mdttb's Avatar
Joined Jan 2004
From dogon1013
Seems to have a purpose for him.
dogon I sent you a PM about the hole.
Old Mar 31, 2005, 03:16 PM
will p3 is offline
Joined Aug 2003
LoL!.you got me there!.
Help! Have an Alula, what's next for small lift? rkhoo Slope 12 Aug 23, 2006 11:37 PM
Discussion What s next from airfoilz/3DX? leblanc 3D Flying 5 Jul 13, 2006 01:41 PM
Discussion So.. From BCX... What's next?? garylee33 Electric Heli Talk 9 Jun 22, 2006 11:33 AM
What's next from MPX? merengue Radios 8 Sep 22, 2005 02:52 AM
Moving on from the Slow Stick..what's next..Tiger Moth? Opinions? YeOldeStonecat Beginner Training Area (Aircraft-Electric) 19 May 29, 2004 07:05 PM
