Old Mar 26, 2005, 05:34 PM
southern soarer uk is offline
Find More Posts by southern soarer uk
fly high ,land well
southern soarer uk's Avatar
Yateley ,England
Joined Jun 2004
balsa loc
The adhesive i normally use is called sig stix it for glassing but i can`t get any at the moment so i`ve got balsa loc instead and found it to be waterbased unlike the stix it are all balsa loc`s the same
southern soarer uk is offline Find More Posts by southern soarer uk
Old Mar 30, 2005, 03:44 PM
bergfalke4 is offline
Find More Posts by bergfalke4
Germany
Joined Apr 2003
The only Balsa Loc I know of comes in a little plastic jar, is waterbased and used to apply covering like Litespan and similar stuff that lacks adhesive on the back.
What do you want to use it for?
- David
bergfalke4 is offline Find More Posts by bergfalke4
Old Apr 01, 2005, 04:21 PM
fly high ,land well
Yateley ,England
Joined Jun 2004
i use it to glass wings apply the balsa loc then put the glass clothe on top before it dries and apply another layer of balsa loc when dry it gives plenty of strength and helps with the adhesion of your covering less weight than tape i`ve since been told wehter water based or sig stix it it doesn`t make any difference
