Combat Models F-16/18 pusher
Hey guys, has anyone built a Combat Models F-16 or F-18 and powered it with a Jet .50 or YS engine?
What sort of difficulties did you encounter with the pusher configuration? Did you run it forward or mod the engine to run it reverse with a forward prop? how is the performance with a nice engine and what nitro did you run? Top end speeds/climb? There used to be a nice F-18 kit with a glass fuse made by a guy in the Pac Northwest, but I haven't seen his ads lately. Also wondering how his F-18 compared to the CBM foamie and glass. Thanks- Ed |
Latest blog entry: The Gas Turbine Engine (with images)
Jefferson, WI
Joined Jan 2002
CBM F-16
Eddie,
I built the F-16 with a YS (side exhaust). The engine is mounted just as the instructions recommend, using a 10x7 pusher prop and a Performance Specialties Ultrathrust muffler. The Ultrathrust muffler is supposed to give you an extra 2000 rpm and a whole lot easier to set up when compared to a tuned pipe. I ran 15% nitro and get 18,000 RPM when measured on the ground. I've only had three flights on my plane and I'm not impressed by the performance. I do notice a change in engine performance when in the air, only I haven't determined what it is or what could be causing the engine to sag. The F-16 looks incredible in flight and was very fun to build, but the performance was a let down. I plan to pull the engine and mount it on another plane to get more run time. Hopefully that will help. I also will strip the paint off the F-16 and repaint it, trying to reduce weight. The suggested painting method can easily get heavy. Over-all, its a real head turner. Email me if you need more information. rkurlins@execpc.com |
Larry - Hey man, you're not gonna out me on the ezone, are ya buddy?!
Just kidding! I started out in glow, and I think I'll always at least want one or own one or two, though I sold all my glow stuff a few years ago to finance my sartup electric doo dads.Bucshot - Thanks for the information. I'm a little dissapointed about the performance too. I figured they would scream. But then again, I always seemed to have problems keeping my glow motors running smoothly through a whole flight, the whole season. Some weeks I'd be on, and other weeks I'd be in the pitts screwing around with the engine. That's why I got into electrics (aside from wanting to do multi's). By the way, what was your all up weight? Does this include a full tank, and if not, what size tank did you use and what were the flight times? What sort of retracts do you have and did you have to add any lead for CG? I'd really be into getting a glow engine with auto lean and ignition that didn't cost a fortune! Thanks all- Ed |
Larry- Thanks buddy, HA HA
Bucshot- I wasn't thinking of doing the F-16 in electric. I think the A-10 is the only really good e- conversion on two MiDi fans and Hacker B50's, but for a price. I do think the F-16 could be done in a pusher setup on electric, but I wasn't really looking at that. I sold my YS .45 pumped engine about 8 years ago. The biggest glow mistake ever, that engine ran wonderful in a Great Planes P-51 kit (not arf) with retracts. They say you can go up to a .61 sized engine in the CBM kits. Seeing that you had to add so much lead in the nose with your setup, possibly the .45 or .50 would be the best bet. That being said, have you seen any other CBM models flying that have had better performance? How much weight did the paint add? I would figure a light coat of lacquer paint would add next to nothing, but the heavy clearcoat for fuel proofing may. I'm spoiled not having to worry about fuel proofing lately ![]() You don't have a picture to post of your two Vipers do you? Ed |
electric jet F-16
The F-16 has been electrified too, here is a link
http://www.rcgroups.com/forums/showt...+models+pusher |
| Thread Tools | |
| Discussion The "Other" Combat Models F-16 project | Eddie P | Pusher Prop Jet Models | 26 | Jul 26, 2008 06:45 AM |
| Combat Models F-16 First Test | friday | Pusher Prop Jet Models | 75 | Jan 19, 2008 12:44 PM |
| Combat Models F-16 | AMTJIM | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 23, 2003 06:57 PM |
| Combat Models F-16 or F-15? | Grimlok75 | Sport Planes | 3 | Jul 16, 2001 03:33 PM |
| Combat Models F-16 or F-15? | Grimlok75 | Electric Ducted Fan Jet Talk | 0 | Jul 10, 2001 11:48 PM |
