Old Mar 26, 2005, 02:53 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
$24 brushless motor - $49 with speed control part II
continued form here: http://www.rcgroups.com/forums/showt...07#post3508007
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Mar 26, 2005, 03:11 PM
lift off is offline
Find More Posts by lift off
HELL no you cant fly it!
lift off's Avatar
Joined May 2004
cool part 2
lift off is offline Find More Posts by lift off
Old Mar 27, 2005, 10:04 PM
voodoosoup is offline
Find More Posts by voodoosoup
Farfromloopin'
USA, IN, Fort Wayne
Joined Jun 2002
Okay- I ripped the wing off of my GWS Corsair trying to pull off a downwind outside loop from level flight. I had the BP-21 installed with the speed control from Balsa Pr.
Need less ot say the wing ripped out of the fuse when I was just coming around to inverted. After the wing depearted the plane the fuse nosed into a paved parking lot at what seemed to be 40+mph. Not pretty!!
The good news is the motor still works. The prop shaft is bent to heck.
And I can't seem to get this thing dissasembled to stick a new shaft on.
I removed the e-clip at the back, and I've tried to pull the stator out but it only moves about 1/8th" up and down. I've tried to remove the large nut at the front of the bell but nothing will budge. Can someone help me before I break something!!!
Voodoo!!!!!
This is a gret motor BTW. It pulled the Corsair around amazingly well on 2 cells and an APC 8x3.8.
voodoosoup is offline Find More Posts by voodoosoup
Old Mar 28, 2005, 06:33 AM
Which_way_is_up is offline
Find More Posts by Which_way_is_up
Which_way_is_up's Avatar
Carrollton, TX
Joined Feb 2003
Voodoo!!!!!
Unless you've bent the shaft so badly that it can't turn I'd say that you are having problems because of the flat washer behind the c-clip. I did the same thing the first time I tried to remove the bell and shaft. I didn't take the flat washer off the shaft and it would slip into the slot where the c-clip goes and stop me from removing the shaft. Don't bother with the shaft nut on the front of the bell.
That's the only thing I can think of.
Which_way_is_up is offline Find More Posts by Which_way_is_up
Old Mar 28, 2005, 08:44 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
GWS 8/6 Prop on 2S for 32 minute Flights 1/3 throttle
Did this on a Wattage Hawk and TP 1900 mah gen 1
hall woo is offline Find More Posts by hall woo
Old Mar 28, 2005, 10:59 AM
BrianRickman is offline
Find More Posts by BrianRickman
United States, PA, Hatboro
Joined May 2002
Another success story:
BP21 with Jeti 18 amp ESC, 8 cell Kan 1050 battery, 8x4 GWS prop, Ace Whisper "Speed 400 size" glider. RTF weight about 23 ounces. Goes almost streight up at full throttle. Gets small after 20 - 30 second motor run. Poor glide due to lack of folding prop, but 30-50% throttle power on flight time was close to 15 minutes.
BrianRickman is offline Find More Posts by BrianRickman
Old Mar 31, 2005, 07:52 PM
rocketree2000 is offline
Find More Posts by rocketree2000
Germansville, PA
Joined Sep 2004
After part one of this thread I ordered a BP18 ESC for my lab students to use so I could get mine back from their project. It didn't get 2 turns on the impeller blade on a tested motor and system before we noticed a hot smell! System still works with old ESC so it was a bad unit, not motor!
2 emails to them with no reply and 2 weeks since I sent it back. Has anyone else had problems with Balsa Products responding to them? Is it my Penn State email that they don't like????
rocketree2000 is offline Find More Posts by rocketree2000
Old Apr 01, 2005, 06:25 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Rocket , BP in the past has been very good about responding , email JIM ... he's the return guy ...
gpw is offline Find More Posts by gpw
Old Apr 01, 2005, 10:22 PM
Mat is offline
Mat
Find More Posts by Mat
Mat
The ground jumped at it!
Mat's Avatar
Ohio
Joined Jun 2004
How do you remove the c-ring thing at the back which holds the axle on?
Mat is offline Find More Posts by Mat
Old Apr 03, 2005, 09:30 AM
hall woo is offline
Permanently Banned
Joined May 2003
use tiny jewelers screwdriver
Old Apr 03, 2005, 01:16 PM
WillowPtarmigan is offline
Find More Posts by WillowPtarmigan
Lagopus lagopus
WillowPtarmigan's Avatar
Houston Hobby, Texas, United States
Joined Jul 2003
Good deal right there.
WillowPtarmigan is offline Find More Posts by WillowPtarmigan
Old Apr 03, 2005, 01:20 PM
Mat is offline
Mat
Mat
Mat's Avatar
Ohio
Joined Jun 2004
When removing the c-ring thing do you try to bend the ring off or pop it off?
Old Apr 03, 2005, 03:23 PM
Mat is offline
Mat
Mat
Mat's Avatar
Ohio
Joined Jun 2004
Will the BP12 Ever exceed 10 amp durring normal use and testing with the recomended dd8x4 prop?
Old Apr 03, 2005, 04:36 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Now what about the new BP 10A Bl esc??????oughta be perfect for cd motors eh?
Old Apr 07, 2005, 06:34 PM
Mat is offline
Mat
Mat
Mat's Avatar
Ohio
Joined Jun 2004
I noticed on my BP12 that the ring which the power leads are sodered onto is loose and moves left and right. Is this a problem? Would super glue fix it?
Sold Hyperion Z2205-34 Brushless Motor and Phoenix 10 Speed Control Gary Hoorn Aircraft - Electric - Power Systems (FS/W) 3 Aug 13, 2007 11:53 AM
Discussion What Brushless motor, Lipo's, Speed control & Prop for my kit built Electrostreak garryarm1 Power Systems 7 Jun 05, 2006 05:52 PM
24 dollar brushless motor 49 dollars with speed control! 68Strat Foamies (Kits) 691 Mar 26, 2005 02:54 PM
astro 020 brushless motor with speed control jeffery arthur Aircraft - Electric - Airplanes (FS/W) 5 Feb 21, 2005 07:16 AM
Brushless Motor with Speed control for $89 shipped CONUS BrunswickOH Aircraft - Electric - Airplanes (FS/W) 7 Apr 18, 2004 07:07 AM
