Balsa is very easy to replair. And in most situations, with a little effort can be repaired to look as good as new, whereas that's really not possible with a foamie. Balsa planes can be every bit as sexy over round surfaces as foam... but most people go for the lighter plane that a covered open structure brings. The planes at Top Gun... as real as "realism" gets, and let me say that they aren't "foamies"
...just to make the point that it's not the medium that brings stringers and open frames to balsa models. If foamies could have a strong enough structure with an open frame, they'd be that way too. A lighter plane, is a happier plane.
I really didn't want this thread to veer off into the differences in repairability, but more, into a discussion on the flight differences between flying a balsa plane versus a foam plane. Like I said, I like the way the Switchback flies better than any other plane I have. How much of that is because it's made of balsa versus the basic design of the Switchback?
If were telling stories...
I flew my formosa at full power into a light post. Pieces falling everywhere. In a few days (equates to a couple hours) I had her up again looking and flying the same. I also had a GWS A-10 nose in ... spent a few minutes collecting all the pieces. After piecing her together like a puzzle, filling gaps with light weight spackle, she looked better than before. If you're interested, i can post a link to the before and after pictures. Now I have a MM P-38 (balsa) with a small proken tail seciont. So now I have to remove a seciont of covering, cut out the broken parts, make new pieces, and cover again. This is right next to the vertical stab, so it will not be an easy area to work on. And this happened on a rough 3 point landing... If it were foam, it would not have broken at all. I can tell you this is a debate that nobody will win on. If your a foam person, you will remain a foam person. If you are a balsa person, you will remain a balsa person. |
OK, I've said all I wanted to say about repairability. About flying... My only foamies are a Slow Stick, and a Tigermoth (and a Mini Speed Wing, but thats different). I've got 2 balsa birds. A Dandy Sport/GT and a SA Stella. Both fly like they are on rails and go where you point them. NO wing flex. I'm not afraid to put either of those planes into a dive and no worry about folding a wing. I would never do that with my tigermoth or Slow stick. I would generally say that a balsa plane would be lighter then a foam model of the same size if built right. There is my 2 cents
The reason the Switchback flies so nice compared to the others you've flown is that the Switchback is a much better plane then the others you've flown! Pure and simple- I prefer Balsa as I think it looks better, is stronger, and I like how it repairs as opposed to foam but it's just a preference, there are great flying foamys out there.
I told you you'd crash it!
| Thread Tools | |
| Discussion Flydroboat 1st Time Rc Flyer! | MARKSGOD | Foamies (Kits) | 0 | Aug 03, 2007 06:51 AM |
| Discussion Aileron Rudder Mixing fo 1st time 3d flyer | chewbaca | Beginner Training Area (Aircraft-Electric) | 4 | Jan 03, 2006 07:38 PM |
| Balsa versus Foam Poll...... | Cal | Parkflyers | 8 | Mar 26, 2005 09:39 AM |
| Question An opinion from a HET Typhoon 15/10 User needed. | Electric Newbie | Electric Plane Talk | 9 | Mar 07, 2005 04:47 PM |
| Cool 1st Time Building Scale Balsa Kit | Reagan505 | The Builders Workshop | 3 | Nov 23, 2004 08:04 AM |
