Old Mar 24, 2005, 08:42 AM
1957chev is offline
Find More Posts by 1957chev
This is fun stuff
New Jersey
Joined Aug 2004
Small electric C/L flying
I've finally gotten some successful 1/2A size electric powered C/L flying done. I was surprised at how much power it takes for true aerobatic flying. After trying electric motors on some all sheet balsa planes that had been powered with a Norvel .061, I went to sheet foam construction, similar to the many small R/C planes around, for lighter weight and more wing area. I'm using 32' .008 lines and tried several variations of powerplants. These are simple sheet profile airplanes as I've always enjoyed that type for casual, fun aerobatic C/L flying. C/L timers are available, motors and batteries are available in all sizes, I'd say there's no doubt that electric C/L is here and we'll be seeing more and more of it.
1957chev is offline Find More Posts by 1957chev
Old Mar 24, 2005, 08:22 PM
rumadaaerowings is offline
Find More Posts by rumadaaerowings
Joined Mar 2005
I would say that electric C/L flying is here to stay also. I have done some experimenting with ECL but on a much smaller scale. Although, I been working with what is known as "rat racing" in my 1/2A electric control line. I am using custom, 15ft lines with an airplane that has a 18" wingspan, S280 direct drive motor w/ a 4-cell 650mAh NiCd pack on board. What size motor and battery pack are you using for your 1/2A electric? It is nice to know that others are interested in ECL.
rumadaaerowings is offline Find More Posts by rumadaaerowings
Old Mar 25, 2005, 05:49 AM
Rikidee is online now
Find More Posts by Rikidee
Muskoka
Joined Nov 2003
Lightweight powerful and not too expensive CD rom brushless conversions seem perfect for C/L use. Are you using battery on board or pack on the belt?
Rick
Rikidee is online now Find More Posts by Rikidee
Old Mar 25, 2005, 09:50 AM
1957chev is offline
This is fun stuff
New Jersey
Joined Aug 2004
I don't think power down the lines will ever be an option for real, lively aerobatic performance. It takes a lot of power for even a small aircraft, more power than can go down small lines, not to mention the line insulation problems. I think at least 35' lines are necessary for decent aerobatics. I don't think a CDrom type motor would be enough power. I'm flying 30" wingspan models with Razor or HiMaxx brushless motors in a GWS 350 gearbox, or a Motor Max brushless outrunner direct drive. Using 3-cell LiPo batteries. A motor setup that will easily hover a 16 oz R/C ship will barely fly a 10 oz C/L airplane.
Old Mar 25, 2005, 10:14 AM
Muskoka
Joined Nov 2003
I guess that would have to do with line drag?
Old Mar 25, 2005, 10:50 AM
1957chev is offline
This is fun stuff
New Jersey
Joined Aug 2004
I assume it's the line drag. Surprised me how much electric power was required for aerobatic C/L flying. But I am using low tech flat plate profile airframe construction. With a Norvel .061, such planes perform great. I'm flying the electrics on 35' .008 cable lines.
Old Apr 08, 2005, 02:25 PM
wcstoddart is offline
Find More Posts by wcstoddart
Knxville TN
Joined Sep 2002
Thanks '1957Chevy' for the two very informative articles in the May 2005 issue of Flying Models. Great information for what will be needed to fly control line in an urban environment. Hopefully some new C/L sites will come from this.
Chris Stoddart
wcstoddart is offline Find More Posts by wcstoddart
Old Apr 08, 2005, 07:34 PM
Ozprey is offline
Find More Posts by Ozprey
Fix all the things!
Ozprey's Avatar
Australia, ACT, Canberra
Joined Jan 2004
I saw ECL aerobat kit from http://www.buzzflight.co.uk/ , all their models are power down the lines as somone put it. I'm starting to learn CL, as I bought a small trainer with lines and a DC Sabre engine.
Peter
Ozprey is offline Find More Posts by Ozprey
Old Apr 09, 2005, 03:09 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
I've flown a couple of Buzzflight models. They only fly successfully on very short lines, around 6m (20ft). The trainer is brilliant for giving kids a first shot at C/L. They don't seem to mind that the lap times are a bit fast . But as Mr Chev implies you need much better reflexes than mine to fly anything like aerobatics on such short lines .
Steve
slipstick is online now Find More Posts by slipstick
Old Apr 09, 2005, 07:27 PM
Ozprey is offline
Fix all the things!
Ozprey's Avatar
Joined Jan 2004
Thinking of power down the wire ECL, another though has hit me. I did some RTP(round the pole) flying a few months back. My friend who was quite a veteran of that area explained that we just about needed double the voltage of the motors to get enough power to the motor, due to line resitance(enamel coated copper). Prehaps that's another major fator in the problems of down the wire ECL. Just another thought.
Peter
Old Apr 10, 2005, 03:31 AM
Staffs, UK
Joined Nov 2003
Yes it is and the two factors combine to make things worse for you. If you use thick enough wire to avoid too much volt drop you get terrible drag so you need more power. If you decrease the wire size you have less drag but you lose most of the power in the wires, so you need more power.
This has been discussed in this forum many many times now, but I always hope someone will come up with a new idea that might make it workable .
Steve
Old Apr 10, 2005, 08:56 AM
1957chev is offline
This is fun stuff
New Jersey
Joined Aug 2004
Copper wire obviously isn't strong enough for any serious C/L aerobatic flying, and stranded steel cable in our sizes won't carry much current. You can only go so high in voltage for safety and to work with commercially available motors and ESCs. And the insulation requirements. Today's brushless motors, ESCs, C/L timers, and LiPo batteries are so available and pretty easy to make weight competitive that I'd think it's just not necessary to wish for power down the lines. Electric C/L flying is here for those that want to do it. It may be considered expensive but the stuff is available.
Old Apr 23, 2005, 04:19 AM
SSwinner is offline
Find More Posts by SSwinner
Joined Apr 2005
This is the best I've seen so far. Those are some cool photos.
SSwinner is offline Find More Posts by SSwinner
Old Apr 28, 2005, 01:58 PM
D W is offline
D W
Find More Posts by D W
D W
I love you man.
D W's Avatar
United States, NY, Pelham
Joined Sep 2002
Where to get the timer/low voltage cut-off that is nec. for saving the LiPos? I threw together a Sterling trainer but the NiCad's proved too heavy. It may (or may not) work with LiPo's but have to prevent deep discharge.
I think EC/L will be the next big thing in our hobby.
Sent an E-mail to JM Piednoir as per your FM article. Awaiting reply.
-David-
D W is offline Find More Posts by D W
Old Apr 28, 2005, 06:07 PM
1957chev is offline
This is fun stuff
New Jersey
Joined Aug 2004
You can get the JMP timer direct from France or from his rep in the US, www.bsdmicrorc.com/
You can get the Z-tron timer from Windy at www.windyurtnowski.com
BUT you have to use an ESC to use either timer. Most ESCs have a low voltage cutoff, better ones are adjustable so you can set the ESC cutoff to protect a LiPo pack. The timers will not work without an ESC.
Discussion Simple timer for electric C/L choffman41 Control Line 11 Jun 24, 2007 11:54 AM
Electric C/L at the NATS. Mike Palko Control Line 5 Mar 01, 2005 02:45 PM
Electric C/L Schwemmer Control Line 1 Jan 12, 2005 03:28 AM
Yippee! Electric C/L video and update. Mike Palko Control Line 4 Nov 03, 2003 06:03 PM
Small C/L stunt engines and the 2-4 break Looooeeee! Control Line 0 Mar 29, 2002 11:52 PM
