Old Mar 23, 2005, 03:05 PM
rutat is offline
Find More Posts by rutat
Joined Mar 2004
A few things... nice idea to add the 3rd wire for the eventual brushless. Why not cut the rudder and elevator totally free - esp. if you are taping the hinge any way? WHy such small servos? And lastly, are you planning any pics of the prop mount? Gluing a prop on seems like a bad idea.
rutat is offline Find More Posts by rutat
Old Mar 23, 2005, 03:07 PM
sargentw is offline
Find More Posts by sargentw
"SARGE"
sargentw's Avatar
Fairfax Station, (Northern) Virginia
Joined Jun 2003
View of the rudder from the rear. Everything is straight.
sargentw is offline Find More Posts by sargentw
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
And again the EZ posing on the CG balance machine all ready to go.
So that's it for now. I know this is a huge continuing thread, however, I hope these posts are helpful, especially for new Flyers.
I'll post more as I make reportable changes/upgrades.
The EZ and a flying Wing will be going to Bethany Beach, DE this weekend. If it's calm enough I'll give it a fly out over the Ocean.
Please feel free to post comments, build ideas, and pictures.
Tad
Old Mar 23, 2005, 07:34 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
Why cut the rudder? The existing foam hinge is good by itself and holds the rudder right where it needs to be while being reinforced. Cutting the rudder off will require more alignment work.
The servos are standard on the Sky Scooter Pro II. They have been through $#$%@ and still work fine. The are very light and keep the RTF at slightly under 23oz. Extra weight has been wisely used reinforcing the rudder/elevator and tail boom. The EZ is more of a sailplane/glider than a hotliner. The Hs-55 should work fine.
Here are some pics of the prop adaptor. These prop adaptors clamp the prop shaft with a bolt and do not come off while flying, yet are very easy to remove. You can get them at aircraft World. For brushed speed 400 motors the shaft adaptor is 2.3 mm. Brushless adaptors for speed 400 brushless motors usually have a shaft of 3.2 mm. APC props would be fine. I like the Graupners better and while more expensive are fairly well protected in the EZ pusher configuration.
That's the stock prop in the picture for comparison.
Old Mar 23, 2005, 07:43 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
I forgot to disclose the reinforcement hinges on the elevator. The fiber tape hinges are on the bottom of the elevator. Also not the "Star" decals that have been placed over the nasty injection holes and keep the air flow smooth.
The hinges are placed evenly in the groove so there is no binding when the elevator is moved.
Tad
Old Mar 23, 2005, 09:24 PM
rutat is offline
Joined Mar 2004
Thanks! I have to get some of those prop adapters. I expect to use HS55's in mine.
Old Mar 24, 2005, 09:11 AM
Joe_Atlanta is offline
Find More Posts by Joe_Atlanta
this space available
Joe_Atlanta's Avatar
Atlanta, GA
Joined Dec 2004
Originally Posted by sargentw
One of the useful tasks you can work on while you ponder the next step is sand off the hundreds if injection marks on the wings, fuse, and tail feathers with a piece of 220 grit sand paper.
OH NO! You've removed the patented Multiplex turbulators©! It'll never fly now!
J/K. Nice pics and good tips. There was actually a discussion of the bumps in the early threads, with the idea that removing them might make the EZ a little less "floaty". Maybe not a good mod for the total beginner? AFAIK, no one has ever done a before and after test. Mine flies fine with them, I'll probably remove them when I build a flat airleron wing and go for the "warmliner" thing.
A note about CG. The factory suggested setting is a good starting point, but because of the variations in manufacturing and building, each EZ may have a slightly different sweet spot. On mine, I ended up with the CG 7mm forward of the recommended spot (gives me neutral trim at 1/2 throttle).
Joe
Joe_Atlanta is offline Find More Posts by Joe_Atlanta
Old Mar 25, 2005, 11:30 AM
BillLumberg is offline
Find More Posts by BillLumberg
Did you get the memo?
BillLumberg's Avatar
West LA, CA
Joined Jan 2005
I see you've got a side-by-side 7x2/3A cell KAN. Think I can fit an 8 cell side-by-side pack in there?
BillLumberg is offline Find More Posts by BillLumberg
Old Mar 25, 2005, 02:50 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
Thanks Joe,
A totally new beginner should get the RTF kit. They can make the rudder mod and smooth the airfoil after the fact.
The Terry Graupner/Tipsy have the same, what looks like, injection marks too. I can't imagine why they would be on those planes with high performance air foils except as part of the the manufacturing process. They count on the good modeler to provide the labor to remove them and keep the kit price down.
Bill,
You could get 8 in a line in there. I can't because my ole' Scooter HiTec AM rec is too big.
Tad
Old Mar 25, 2005, 03:56 PM
West LA, CA
Joined Jan 2005
Maybe the "turbulators" act as vortex generators, helping the airflow remain attached to the surface, hence less drag. It's a long shot, but if true then it would be beneficial to keep them.
On second though, vortex generators are usually placed where the flow is prone to seperate from the surface. The "turbulators" are everywhere so they would disturb the flow in critical areas (such as the leading edges of the wing, tail, etc). Sand away!
Old Mar 25, 2005, 04:09 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
They look like injection vent holes designed to release pressure evenly when the foam is injected in the mould. The concept kinda reminds me of leaving barnacles on the hull of a boat
Old Mar 26, 2005, 08:56 AM
flyingflipper is offline
Find More Posts by flyingflipper
flyingflipper's Avatar
Joined Sep 2004
Thanks for starting a comprehensive and well documented thread. The quality of the pics are excellent. Keep up the good work and please update everyone on any mods. I've been flying my stock EasyStar for about 2 months now and was considering a few mods myself. I will most likely buy another ES soon and use many of your ideas when building it.
flyingflipper is offline Find More Posts by flyingflipper
Old Mar 28, 2005, 05:44 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
I'm back from a long weekend @ Bethany Beach, DE. The weather was not great, but it's the beach and I did find time to do some flying on the fishing only beach. If you have 4wd you can drive out there too. Great place to fly, however, the ocean is not forgiving so it's good to have reliable and well built gear.
The first picture is of my radio/beach bag. Combat Wings Xe2, Unicorn Wing and the Easy Star. The planes are upside down so they don't fly away by themselves. It was windy at about 8 to 12 mph and cool at 48 degrees
Old Mar 28, 2005, 05:45 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
second picture is the gang again with the dune and the sign that says "stay off the dune" in the background.
Old Mar 28, 2005, 05:53 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
Here is a shot of the EZ at about 500 feet over the ocean. It flew well I used my 7.4 volt lipoly battery and it had no problem going up. With the throttle chopped the EZ did some great soaring off the wind and lift from the dune and beach. The photo is zoomed in so you can see the plane. Of course there were kids running around asking "hey mister you might crash in the ocean"
Discussion Sig Four Star 40 ARF Engine recommendations and Building Tips Daverp Beginner Training Area (Fuel) 24 Jul 12, 2009 02:38 PM
Discussion Finished building my easy star :) lee2005 Foamies (Kits) 2 Mar 02, 2007 05:10 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
Wattage F-22 Building Tips / Pictures rcfanatic Foamies (Kits) 9 Sep 08, 2001 02:25 PM
IFO Mark3: Any last minute building tips ? volt flyer Parkflyers 13 Jun 21, 2001 03:33 PM
